Old 11-17-2009, 12:56 PM   #1441
dag32's Avatar
Trader Rating: 100 (100%+)
Originally Posted by sosidge View Post
Does the TB-03 allow square case lipos (I run IP5000) to sit flush in the chassis without modification?
Square case lipos will fit but will not sit flush. I have a SMC 5200 lipo in mine, held in with tape, that battery does not budge!
★ David Garcia ★
dag32 is offline   Reply With Quote
Old 11-17-2009, 01:15 PM   #1442
sosidge's Avatar
That's a shame... I hope that if/when the "R" comes out Tamiya redesign the chassis mould a little. Even Japan is moving to LiPo now.
Old 11-18-2009, 07:06 AM   #1443
Where are people getting their 3mm spacers from when fitting the alloy suspension mounts?
I was reluctantly going to use a few random plastic ones I had in my parts box (before I realised I didn't have an extra pair of the little ball ends for the front suspension pins!) but figure there must be some suitable alloy ones out there?
Cheers,
Mike
Oh - and can anyone confirm whether I'm supposed to use the original 1mm plastic spacer AND the 3mm spacer, or just the 3mm spacer?
mikekey is offline   Reply With Quote
Old 11-18-2009, 07:58 AM   #1444
Trader Rating: 83 (100%+)
I just built my first onroad and y first TB03. I am planning to run a pretty fast motor since i am just bashing around my culdasac. I want to run a motor that will perform well and run fast with my thunder power 40c 2s 5000 lipos and my mamba max pro ESC. I ned to know two things, what motor do you reccomend? Should I grab a mamba 5700, 4600,etc? Or go with a 5.5-8.5 turn type? #2) What pinion should I run with the stock spur gear to get best performance and temps? Any help is appreciated.
bigbeej is offline   Reply With Quote
Old 11-18-2009, 07:08 PM   #1445
Been successful with the TB03 in the 17.5 class. But having problems against cars that have the Tekin RS with the new software. They can pull away on straight with ease.
Any good ESC/gear setup for a KO BMC/Trinity DUO? Want to have that "High end car killer" title again.
redbones is offline   Reply With Quote
Old 11-18-2009, 07:28 PM   #1446
reenmachine's Avatar
Trader Rating: 26 (100%+)
Racecrafter has the hookup for you for sure. That's basically what he runs and his car is whoop-ass fast. This coming from a Team Tekin guy...
Pete Waydo
2010 Big Fat Turkey Race Mini Cooper AAA Main Champion
*** currently in stasis ***
reenmachine is offline   Reply With Quote
Old 11-18-2009, 09:17 PM   #1447
Any help?
Old 11-19-2009, 09:05 AM   #1448
Racecrafter's Avatar
Trader Rating: 25 (96%+)
For a stock BMC go to profile 5
Duo 1 with a FDR of 3.5 should get things kicking for you.
If you are running 5 minute races it will be tough to beat them on a long straight. 7 minute races in RCGT are easy because most guys over time their motors and speedos and around the 4:30 mark start to heat up and fade away.
Jimmy Wright
www.trackstarrc.com ~ www.facebook.com/TrackStarRC ~ Home of the 2x's Stock Nationals Champion TS-Gold & TS-Black tire sauce, TS-1+ lubricants, TS-Precision bearings, XRG Xtreme Racing Grease, Scale Auto Engineering, ElevenTech, WRD2, Carbon 12, Stiff Products
Racecrafter is offline   Reply With Quote
Old 11-19-2009, 12:12 PM   #1449
Hebiki's Avatar
Jimmy.. i sent you an email. hope you can help. thanks!
man its awfully quiet in here now that Timmie is gone.
- Chris
Hebiki Design Works
Custom R/C Vinyl Graphics & Apparel: Your gear, your way!
Web Design - Web Development - Logo Design - Graphic Design
www.facebook.com/HebikiDesignWorks
Hebiki is offline   Reply With Quote
Old 11-19-2009, 05:07 PM   #1450
- Chris
I can help. You need to respond though to let me know if my "help" will work for you.
Jimmy Wright
Old 11-19-2009, 06:51 PM   #1451
Thanks for the info!
Going to experiment with various gear ratios from 4.3 to 3.6 with 0 timing and middle hole, timing 5 and 6. Wanted to get a lower ratio, but that's all I have for now. The base profile will be the Drew Ellis one, 0 drag brake.
Won't have the lap counter that day, so I'll just have to play it by temps. Our mains might be extended to 8 min, so things might work out a little different. Will report back later.
inpuressa is offline   Reply With Quote
Old 11-19-2009, 10:49 PM   #1452
Default tire suggestions?
Hi there,
Just building a TB-03D but want to use it for street bashing and speed runs as well as drifting. What tires would you suggest for bashing and running on asphalt (nothing very smooth)?
Any other specific setup changes I should do to the TB-03D before running this way as well? Motor will be a Sidewinder 4600kv likely on 2s lipo.
Thx
Steph
stephpar is offline   Reply With Quote
Old 11-21-2009, 08:57 PM   #1453
What pinions does his car use? Is there a better option do do with the pinion spur? I need a 26-28 tooth pinion to run with the stock spur but not sure what to look for.
Old 11-22-2009, 02:30 AM   #1454
Moole's Avatar
Default My TB03
hi folks
just want to show you my TB03:
Traxxas Slash - Mamba Max 5700
Tamiya F103 RM - Yeah Racing Brushless
Moole is offline   Reply With Quote
Old 11-22-2009, 05:26 AM   #1455
Callahan_88's Avatar
Mine is now ready!
Go big or go home! :)
Callahan_88 is offline   Reply With Quote
Selling Schumacher Mi2, Tamiya M02, Tamiya TA04-S, Tamiya TB Evolution 3 Surikarn Ltd st_rob Australia For Sale/Trade 4 12-23-2008 06:37 PM
Tamiya 415 MSX, legacy 2.0, NIP Type A tires, Tamiya towel for sale or trade Fastburn R/C Items: For Sale/Trade 16 09-05-2008 11:45 PM
FS: Tekin Rebel 2 ESC w/ Tamiya GT Tuned Motor & Tamiya AM Radio & Receiver wrxnfx R/C Items: For Sale/Trade 6 06-10-2008 05:40 PM
Tamiya M03 / Trinity Brushes / Muchmore Battery Cooler / Tamiya M Chassis Wheels bluejays R/C Items: For Sale/Trade 2 12-16-2007 08:31 PM
Hpi rs4, tamiya tt01, tamiya tg-10, tamiya sprint! MORE!!!!! Genuinekid R/C Items: For Sale/Trade 10 09-10-2007 03:21 PM
