Old 09-30-2009, 04:10 PM   #1306
tech5's Avatar
Timmie you missed out on sevenstock! So many rx's! lots of 4 rotors, fb's,fc's and fd's! and the rc race was awesome also! You gotta plan for next year!
TRACKSTARRC.COM
Track Star Racer Services / DE racing / TKO Bearings / AKA Racing / WRD2 / KO Propo / Fantom Motors and Batteries / M2C Racing / Scale Auto Engineering/EKD designs/STRC
"FROM THE BENCH TO THE TRACK, WE GOT YOUR BACK!"
tech5 is offline   Reply With Quote
Old 09-30-2009, 04:27 PM   #1307
Trader Rating: 4 (83%+)
Does anyone have the 3Racing Graphite Conversion kit on a TB-03D? I don't there is much difference between the TB-03 and the TB-03D.
I am thinking about getting it as my next mod. Does it come with everything I need? I think I just have to transfer everything over shouldn't be to hard.
I just don't want any surprises. I plan on sticking on my TB-03D.
DriftWoof is offline   Reply With Quote
Old 09-30-2009, 08:43 PM   #1308
dirtyboo's Avatar
Thumbs up
Originally Posted by Timmie View Post
Whoa brother, you cooked that good!
You need to run the aluminum diffs if you want to have that much power
http://www.speedtechrc.com/store/ebp...id=716&id=8053
The plastic diffs can't hold the diff rings in place without twisting out and melting running that much power. The aluminum ones can handle a 4turn with 2s lipo no problem as I have run that setup in my TB03 no problem. Along with the aluminum diff upgrade I highly recommend getting ceramic diff balls as well
http://www.speedtechrc.com/store/ebp...id=619&id=7735
thx Timmie,
i will take ur advice. getting the aluminum diff. n ceramic ball bearings n wil
post of the outcome.
mugenseiki mbx-6, mugenseiki mbx-6t, hpi savage x 4.6, hpi savage flux, tamiya tb-03, kyosho v-one rrr evo 2 wc edition, kyosho dst
tt raptor 50 titanium, align 450 sports, e-sky honey bee
dirtyboo is offline   Reply With Quote
Old 09-30-2009, 09:06 PM   #1309
dirtyboo's Avatar
Thumbs up
Originally Posted by kerk View Post
Hi dirtyboo,
I think you are right about the power from your motor! Yeah, you should get the alu diff joint.
Even so, with so much power, it is important to have your drivetrain very well build. Check all gear meshings (between your bevels and diffs, motor pinion to spur). Make sure the plastic shoe on the UJs are thick with enough meat. If not, the pin on the UJ will eat into your alu diff joints.
These are some of the basic items you should take care of when you are running low turn motors. The enjoyment will last much longer!
Cheers!!
thx kerk, wil do that.
Old 10-01-2009, 01:35 AM   #1310
Hi guys,
first of all sorry for my poor english, as I'm Italian,
second important question, is any body using such model with 10,5T?
any suggestions, as i purchesed one for mainly use in the italian Tamiya Cup
equipped with a 12T, but them my idea is to use it with 10,5T as the most popular category here in Italy.
Tnks in advance for yr help.
Max
mtaddei is offline   Reply With Quote
Old 10-01-2009, 06:48 AM   #1311
Timmie's Avatar
I know I really wanted to go this year. But being right after the TCS nats I couldn't afford to fly back out. I know I would be really distracted with all the Mazda's to drool over haha. I am planning on making it next year for sure...even if I have to curb my eating habits some to save the extra loot
:: Serpent America ::Desoto Racing :: Track Star Racer Services ::Skyrocket Racing::TOP::
Timmie is offline   Reply With Quote
Old 10-01-2009, 09:18 AM   #1312
Timmie's Avatar
Originally Posted by mtaddei View Post
Hi guys,
Max
Hi Max,
I think Kerk has used a 10.5 in his before. I have used a 13.5 and a 4 turn in mine with no problems. You will need to get the aluminum diff, aluminum drive cups for the drive shaft, and the drive axles to support the power reliably. Other than that the car handles the power pretty well.
Old 10-01-2009, 09:22 AM   #1313
Racecrafter's Avatar
Trader Rating: 25 (96%+)
Hi Max,
Max,
I ran 10.5 at the Mazda cup with no problems. My car worked very well. (I was supprised because it was in RCGT trim, Tamiya RX7 body and xpattern tires)
But as Timmie mentioned, you will need to upgrade the drivetrain.
Jimmy Wright
TRF
Jimmy Wright
www.trackstarrc.com ~ www.facebook.com/TrackStarRC ~ Home of the 2x's Stock Nationals Champion TS-Gold & TS-Black tire sauce, TS-1+ lubricants, TS-Precision bearings, XRG Xtreme Racing Grease, Scale Auto Engineering, ElevenTech, WRD2, Carbon 12, Stiff Products
Racecrafter is offline   Reply With Quote
Old 10-01-2009, 12:07 PM   #1314
Glinzo's Avatar
Gnaa.
I knew that i forgot something. Upgrading my drivetrain will be necessary to run my 6.5T
Still not running...
Glinzo is offline   Reply With Quote
Old 10-01-2009, 12:33 PM   #1315
Hi timmie and racecrafter, tnks a lot for yr replay which are much confortable, presently i'm owning a team magic e4rs, but last sunday on my first race with it
I had lot of problems and i'll not use it any more.
It means that for the italian tamiya cup i will use it with the only hop up allowed (servo saver and hex), but then i was thinking to purchase the hop up suggested in the tamiya usa tech corner to add when i'lll race 10,5T.
Ciao
Max
Old 10-02-2009, 12:53 AM   #1316
dirtyboo's Avatar
Default hop-ups
hi guys,
after cooking my diff joints, decided to 'pimp my ride'. here r the list of hop-ups that i would like to share wit u guys:-
1. aluminum diff joint set(front n rear)
2. 3mm tungsten-carbide diff ball set
3. aluminum universal propeller shaft
4. aluminum rear upright(1 degree)
5. 44mm universal swing shaft(front n rear)
6. clamp type aluminum wheel hub(4mm thick)
7. trf damper special blue
8. carbon bumper support
9. carbon battery plate set
the set-up is stock, hav not tested it yet. hope everything wil go well, here r some pics....
Tamiya TB-03-img_2173.jpg   Tamiya TB-03-img_2159.jpg   Tamiya TB-03-img_2105.jpg   Tamiya TB-03-img_2161.jpg   Tamiya TB-03-img_2183.jpg
Old 10-02-2009, 01:14 AM   #1317
I am almost closer to maxing out my steering. The 42mm Swing Shafts for the TB-03D stopped the vibrating and gave me slightly more steering.
I need a longer servo horn. Mine is just to low to give me the little that I need. I am at odds at which servo horn I should get. I am not familiar with them. I need it a little taller. then I can make stuff happen. What would you guys recommend?
ALSO: Do you guys Lube/Grease the Front One Way(54057)? If so what grease/Lube do you use?
Old 10-02-2009, 12:11 PM   #1318
Hey dirty you forgot to get the steering, is the first hop up I got and the best one , its day and night. Its Just an idea for your next pimping session.
Group B Monster is offline   Reply With Quote
Old 10-02-2009, 02:43 PM   #1319
fat500's Avatar
Trader Rating: 29 (100%+)
tb03 pics
fat500 is offline   Reply With Quote
Old 10-02-2009, 07:08 PM   #1320
fat500's Avatar
+ YouTube Video
sweet arta
Selling Schumacher Mi2, Tamiya M02, Tamiya TA04-S, Tamiya TB Evolution 3 Surikarn Ltd st_rob Australia For Sale/Trade 4 12-23-2008 06:37 PM
Tamiya 415 MSX, legacy 2.0, NIP Type A tires, Tamiya towel for sale or trade Fastburn R/C Items: For Sale/Trade 16 09-05-2008 11:45 PM
FS: Tekin Rebel 2 ESC w/ Tamiya GT Tuned Motor & Tamiya AM Radio & Receiver wrxnfx R/C Items: For Sale/Trade 6 06-10-2008 05:40 PM
Tamiya M03 / Trinity Brushes / Muchmore Battery Cooler / Tamiya M Chassis Wheels bluejays R/C Items: For Sale/Trade 2 12-16-2007 08:31 PM
Hpi rs4, tamiya tt01, tamiya tg-10, tamiya sprint! MORE!!!!! Genuinekid R/C Items: For Sale/Trade 10 09-10-2007 03:21 PM
