Old 09-26-2009, 09:57 AM   #1261
Originally Posted by CSaddict View Post
Well, funny thing. I was having issues fitting the 46mm swing shafts in my car. It was discussed in this thread about widening up the car with some C or D blocks. I ended up stripping a front hub so I bought aftermarket front knuckles and C hubs. Now the 46mm swing shafts fit great. They must widen it up a bit. They were 3racing parts.
I run standard suspension arms, front blocks 1A/1A, standard C hubs and knuckles, front 1-way. I have no problem using the 46mm UJ.
Could be the dimenison of the outdrives then.
Cheers!!
K.I.S.S.
Keep It Simple Stupid
kerk is offline   Reply With Quote
Old 09-26-2009, 02:47 PM   #1262
Trader Rating: 4 (83%+)
My Castle Creations Sidewinder 4600kv ESC/Motor is damaged I think. I sluggish compared to when I first got it.
I have a Novak Havok Sport 5000kv ESC Motor System. It's awesome but I use the Castle because it's simpler: Less wires, smaller esc, wires can be disconnected from motor, less mess, and in my opinion it looks better. Also, my Havon Sport glitches randomly no matter how far I get the wires/electronics away and I don't want another bulky capacitor sticking out since I need Novaks glitch buster to sort it out as in the instructions.
Can anyone recommnad me a simple combo? Not looking to spend more then 180.
http://www3.towerhobbies.com/cgi-bin...&I=LXVAG2&P=FR
http://www.amainhobbies.com/product_...r-Combo-4800kV
EZrun?
DriftWoof is offline   Reply With Quote
Old 09-26-2009, 03:05 PM   #1263
bluesxman's Avatar
EZrun?
I'd wager you just toasted your motor and the ESC is fine. What about just buying a new 4600kv? Sounds like the cheapest option, at least.
bluesxman is offline   Reply With Quote
Old 09-26-2009, 06:58 PM   #1264
I kinda want a new motor but I think I may get another sidewinder. I'm not digging the choppy startup on the sidewinder though, and the choppy RPM loss. What are some other good combos?
Old 09-26-2009, 08:36 PM   #1265
Sensored based models will provide you with smooth start ups but they do cost more. Its a compromise you'll have to decide for yourself.
Another thing, make sure your batteries are in good condition and properly charged. It is when the voltage to the brushless esc (sensored or sensorless) is too low, it causes the motor to cog (stutter).
Cheers!!
K.I.S.S.
Old 09-26-2009, 09:16 PM   #1266
SerpentCT4S's Avatar
Trader Rating: 94 (96%+)
Send a message via AIM to SerpentCT4S
I am looking to get a TB03.
Which of the kits have the IFS?
SerpentCT4S is offline   Reply With Quote
Old 09-26-2009, 09:28 PM   #1267
reenmachine's Avatar
Trader Rating: 26 (100%+)
All of them!
Pete Waydo
2010 Big Fat Turkey Race Mini Cooper AAA Main Champion
*** currently in stasis ***
reenmachine is offline   Reply With Quote
Old 09-26-2009, 09:30 PM   #1268
Originally Posted by reenmachine View Post
All of them!
I see the TB03 drift kits arent IFS.
Old 09-26-2009, 09:32 PM   #1269
Oh, perhaps. I must admit I don't pay much attention to the drift stuff.
Pete Waydo
Old 09-26-2009, 10:02 PM   #1270
Racecrafter's Avatar
Trader Rating: 25 (96%+)
The drift kit (TB03D) is the only one without IFS.
Jimmy Wright
www.trackstarrc.com ~ www.facebook.com/TrackStarRC ~ Home of the 2x's Stock Nationals Champion TS-Gold & TS-Black tire sauce, TS-1+ lubricants, TS-Precision bearings, XRG Xtreme Racing Grease, Scale Auto Engineering, ElevenTech, WRD2, Carbon 12, Stiff Products
Racecrafter is offline   Reply With Quote
Old 09-27-2009, 02:36 AM   #1271
I've tried everything to fix my steering on my TB-03D so it will turn all the way to the stopper even and smooth on both sides with no binding.
It's not my controller, it's not my servo. The dog bones will bind when the car steering is turned. And it wont let it hit the stopper. I got a front one way shaft in there.
I am at odds and because of this I am looking to go back to my Yokomo SD.
I ordered this. Thought it would stop the binding, thought it would fit. It was too long.
I just don't anymore. What do you guys have on your setups that make the steering knuckles hit the stopper without binding?
Old 09-27-2009, 02:56 AM   #1272
Quick Update: I just noticed my car also vibrates when I drive it on the front steering knuckles because of binding. It vibrates fairly heavy. The same binding as in the post above that doesn't allow my steering to turn all the way to the stopper.
Will these fix my problem?
https://www.tamiyausa.com/product/it...oduct-id=54076
https://www.tamiyausa.com/product/it...oduct-id=54078
https://www.tamiyausa.com/product/it...oduct-id=53500
I am trying to conquer my steering problem.
-I have a TB-03D
-Tamiya Front One Way with stock shimming
-Tamiya Direct Coupling in the Rear Stock Shimming
44mm too long? 46mm?
Old 09-27-2009, 10:28 AM   #1273
-I have a TB-03D
DriftWoof,
The vibration you are encountering is normal with a spool. I'm still not sure what your binding issue could be without seeing the car.
Where ae you located? I'd like to help you get this resolved as I see you are buying parts here and there to fix your situation. Let me know.
Jimmy Wright
Jimmy Wright
Old 09-27-2009, 11:25 AM   #1274
Originally Posted by Racecrafter View Post
DriftWoof,
Jimmy Wright
I am in Pacifica CA.
All I want to do I stop my steering dogbones from binding with the side of this cups so the steering knuckle can make a full turn all the way to the stopper. I figured the parts I listed above will solve that. I just don't know 44mm or 46mm?
The vibration seems to be from the steering when i throttle it and look at it the same time I can see the dogbones push the cups out and over the bindings when the car servo is turned all the way right/left.
DriftWoof,
Jimmy Wright
In the photo you can see i have my steering maxed out. I want the knuckle to hit all the way to the stopper. This is why my steering radius is so large.
Binding
http://www.youtube.com/watch?v=DBKrCmdgIyY
http://www.youtube.com/watch?v=E6mJj8ACRR4
Old 09-27-2009, 03:37 PM   #1275
the stock dogbone are not good. You need to switch to 44 universal. At first I use 46 because the kit said it , but 46 is too tight specialy if you put some camber they will bind with 1A-1A mount , so I got a 44 for the front and its fit nicely. (46 fit in my rear)
Running too much radius with stock bone will result in this:
Also you said your knuckle hit the c arm when you turn. I just check mine and the servo stop before that so, something wrong with your C arm maybe. How are your turnbuckle for the camber in the front? Are they straight or the outter cup (c arm ) are more toward the front of the car? Try to switch the c arm around.
Group B Monster is offline   Reply With Quote
Selling Schumacher Mi2, Tamiya M02, Tamiya TA04-S, Tamiya TB Evolution 3 Surikarn Ltd st_rob Australia For Sale/Trade 4 12-23-2008 07:37 PM
Tamiya 415 MSX, legacy 2.0, NIP Type A tires, Tamiya towel for sale or trade Fastburn R/C Items: For Sale/Trade 16 09-06-2008 12:45 AM
FS: Tekin Rebel 2 ESC w/ Tamiya GT Tuned Motor & Tamiya AM Radio & Receiver wrxnfx R/C Items: For Sale/Trade 6 06-10-2008 06:40 PM
Tamiya M03 / Trinity Brushes / Muchmore Battery Cooler / Tamiya M Chassis Wheels bluejays R/C Items: For Sale/Trade 2 12-16-2007 09:31 PM
Hpi rs4, tamiya tt01, tamiya tg-10, tamiya sprint! MORE!!!!! Genuinekid R/C Items: For Sale/Trade 10 09-10-2007 04:21 PM
