Old 09-24-2009, 07:54 PM   #1246
subaru73's Avatar
Trader Rating: 41 (100%+)
Originally Posted by Racecrafter View Post
What speedo, motor and battery are you running? Are you running slicks or xpatterns (RCGT)?
speedo lrp sxxtc montor fantom 17.5,tires,jaco blue,battery fantom 5000 40c 2 cell.
thanks
Tamiya Ta07 Tamiya evo5 ms,Tamiya Ta05r Tamiya FF04 rm01 Tamiya Ff03R
Futaba 4Px radio lrp speed control
Cfx paint works Fantom Racing apex Rc tq hobbies acer racing Hebki design works
subaru73 is offline   Reply With Quote
Old 09-24-2009, 08:31 PM   #1247
Trader Rating: 4 (83%+)
Do you guys have any input on what some good light durability upgrades would be?
They don't make a full hopup conversion for the TB-03 like they do for the TT-01 do they?
Are yeah racings, 3racings, gpm good? Or will they leave play? I have hunch i should stick with genuine tamiya. For the steering column and what not. Better to go genuine tamiya, the others might leave play. Or they are all the same dimensions to the point?
Will the 3racing tb03 graphite conversion fit the tb03d?
DriftWoof is offline   Reply With Quote
Old 09-24-2009, 09:06 PM   #1248
reenmachine's Avatar
Trader Rating: 26 (100%+)
I'm done fighting with my scanner not working with Vista so here is my attempt to write it out.
Most of you already know I run the stock blocks, shims and spacers per kit instructions.
TRF shocks with the thin spring collar. 3 hole pistons with 550 Kyosho all 4.
Built to 61.5mm in length. full rebound for most tracks (except bumpy ones)
Blue springs front, yellow or red for rear depending on bumps and traction. Red mostly.
push rods at 14.5mm and #2 arm position all around
Shock position #2 on rear tower
Front: #4 camber position w/3mm shim.
Rear: #4 w/2mm shim and #2 on hub.
TA05 sway bars. Usually yellow front, red rear. Recent changes in front diff I took the front bar off.
Droop: I take the tires off and set the chassis on a flat surface. Then I take my calipers and measure from the top of the axle to the surface. All 4 axles I set to .950 inch. (24.1mm)
Ride height: Here I use a gauge under the chassis. Most of the time I run 6-6.5mm on all tracks. At Cam I was looking for more steering without sacrificing stability so I went to 5mm in front with 6mm rear and took .25mm of droop out in front. (24.4mm)
Anything else let me know....... :
Great info and very generous of you to share. I'm going to try much of this setup on my IFS-R and see what happens.
Is 550 Kyosho oil equivalent to 55 wt. silicone?
Pete Waydo
2010 Big Fat Turkey Race Mini Cooper AAA Main Champion
*** currently in stasis ***
reenmachine is offline   Reply With Quote
Old 09-24-2009, 11:27 PM   #1249
I have had good experience with 3 racing, everything fits well. For the steering and drive-train upgrades i would go with tamiya, since it deals with moving parts.
I had the 3racing steering column, it looked cool but had just as much play as the stock one. For that definitely go with tamiya.
Right now i got the 3racing's graphite rear shock tower, metal suspension blocks, and their graphite chassis, and everything else are tamiya parts. I like it.
Ay Way Way is offline   Reply With Quote
Old 09-25-2009, 06:40 AM   #1250
bluesxman's Avatar
What changes?
bluesxman is offline   Reply With Quote
Old 09-25-2009, 06:49 AM   #1251
bluesxman's Avatar
No. The 550 is in CST (centistokes) which is a metric unit. CST is a linear system while WT is not. If I remember right, at the low end, they are somewhat close, but as you get thicker, they diverge enough to really matter. When I say low end, I mean like 20 WT / 200 CST.
If you are having a hard time finding a set of oils rated in CST, Tower carries Muchmore which is a well respected shock oil.
Old 09-25-2009, 07:32 AM   #1252
Originally Posted by bluesxman View Post
What changes?
I figured it has something to do with the front "slipperential" he mentioned.
No. The 550 is in CPS which is a metric unit. CPS is a linear system while WT is not. If I remember right, at the low end, they are somewhat close, but as you get thicker, they diverge enough to really matter. When I say low end, I mean like 20 WT / 200 CPS.
If you are having a hard time finding a set of oils rated in CPS, Tower carries Muchmore which is a well respected shock oil.
Thanks for the info!
Pete Waydo
Old 09-25-2009, 08:33 AM   #1253
Racecrafter's Avatar
Trader Rating: 25 (96%+)
thanks
First of all great choice in battery and motor!!
Run "0" degrees of motor timing and gear at 3.5 to start. Take temps. Though indoors you wont run into higher temps as in out doors unless you are waaaayyyy over geared.
Lap times are going to be your deciding factor. If your time get faster by gearing up by all means do so. These motors will run very happy up to 180* safely. However indoor carpet that would be too much.
Jimmy Wright
Jimmy Wright
www.trackstarrc.com ~ www.facebook.com/TrackStarRC ~ Home of the 2x's Stock Nationals Champion TS-Gold & TS-Black tire sauce, TS-1+ lubricants, TS-Precision bearings, XRG Xtreme Racing Grease, Scale Auto Engineering, ElevenTech, WRD2, Carbon 12, Stiff Products
Racecrafter is offline   Reply With Quote
Old 09-25-2009, 08:38 AM   #1254
Pete,
No. It's closer to 45 Associated or 40 Losi.
Newer Associated fluids have the CPS value on the bottle as well as Wt.
Jimmy
Jimmy Wright
Old 09-25-2009, 08:40 AM   #1255
What changes?
I built a "slipperential" for the front which took away some off power steering.
Jimmy Wright
Old 09-25-2009, 09:31 AM   #1256
bluesxman's Avatar
Default Shock Oil Viscosity
I'm probably going overboard here, but here's more on shock oil viscosity for anyone that cares:
http://www.twf8.ws/php/index.php?opt...per&Itemid=175
Earlier I wrote that the metric oil ratings were in CPS (centipoise) and that's not quite right. They're rated in CTS (centistokes) which happens to be very close to having values equivalent to CPS in the case of silicon oil.
Old 09-25-2009, 12:15 PM   #1257
Hebiki's Avatar
Pete,
Jimmy
if you would have used TRF or Much More oil.... you would have gained 0.1/sec per lap.
Hebiki Design Works
Custom R/C Vinyl Graphics & Apparel: Your gear, your way!
Web Design - Web Development - Logo Design - Graphic Design
www.facebook.com/HebikiDesignWorks
Hebiki is offline   Reply With Quote
Old 09-25-2009, 01:29 PM   #1258
I asked because I have about every weight of AE silicone oil.
You're right, in the small print on each bottle is the centistoke rating.
40 wt. AE=500 CST
45 wt. AE=575 CST
I usually run the 40 or 45 so I guess I wasn't that far off.
Pete Waydo
Old 09-25-2009, 01:31 PM   #1259
I'm a Mech E...I live for this stuff!
Pete Waydo
Old 09-26-2009, 06:26 AM   #1260
CSaddict's Avatar
Well, funny thing. I was having issues fitting the 46mm swing shafts in my car. It was discussed in this thread about widening up the car with some C or D blocks. I ended up stripping a front hub so I bought aftermarket front knuckles and C hubs. Now the 46mm swing shafts fit great. They must widen it up a bit. They were 3racing parts.
TLR 22
Losi SCTE
Blitz Open
Xray T3 RCGT
www.rcmadness.freeforums.org
CSaddict is offline   Reply With Quote
Selling Schumacher Mi2, Tamiya M02, Tamiya TA04-S, Tamiya TB Evolution 3 Surikarn Ltd st_rob Australia For Sale/Trade 4 12-23-2008 06:37 PM
Tamiya 415 MSX, legacy 2.0, NIP Type A tires, Tamiya towel for sale or trade Fastburn R/C Items: For Sale/Trade 16 09-05-2008 11:45 PM
FS: Tekin Rebel 2 ESC w/ Tamiya GT Tuned Motor & Tamiya AM Radio & Receiver wrxnfx R/C Items: For Sale/Trade 6 06-10-2008 05:40 PM
Tamiya M03 / Trinity Brushes / Muchmore Battery Cooler / Tamiya M Chassis Wheels bluejays R/C Items: For Sale/Trade 2 12-16-2007 08:31 PM
Hpi rs4, tamiya tt01, tamiya tg-10, tamiya sprint! MORE!!!!! Genuinekid R/C Items: For Sale/Trade 10 09-10-2007 03:21 PM
Currently Active Users Viewing This Thread: 2 (1 members and 1 guests)
ErikJan
