Old 09-17-2009, 10:39 AM   #1186
Trader Rating: 4 (83%+)
That be nice but price is a bigger thing for me. http://www.3racing.hk/products.php?products_key=4044
http://www.3racing.hk/products.php?products_key=4048
Are all the Tamiya ones 5mm x 5mm for shocks? What about turnbuckles?
DriftWoof is offline   Reply With Quote
Old 09-17-2009, 10:40 AM   #1187
Racecrafter's Avatar
Trader Rating: 25 (96%+)
Whether you use the steel or the aluminum make sure they are the Tamiya original parts.
Tamiya units fit together better than anything aftermarket. Nothing like spending all that money to have brand new parts not fit correctly.
(ie too much slop)
Jimmy Wright
Jimmy Wright
www.trackstarrc.com ~ www.facebook.com/TrackStarRC ~ Home of the 2x's Stock Nationals Champion TS-Gold & TS-Black tire sauce, TS-1+ lubricants, TS-Precision bearings, XRG Xtreme Racing Grease, Scale Auto Engineering, ElevenTech, WRD2, Carbon 12, Stiff Products
Racecrafter is offline   Reply With Quote
Old 09-17-2009, 09:01 PM   #1188
What size do i need for the shocks?
5x5 or 5x8???
I ordered these for my front/rear shocks. https://www.tamiyausa.com/product/it...oduct-id=53968
Old 09-18-2009, 01:46 PM   #1189
Timmie's Avatar
Ok got my new TB03 video posted up to YouTube I will be making some more in the future showing what the car can do with more and more power I've got a few people to set straight on some things hehehe. Enjoy!
http://www.youtube.com/watch?v=U3exonc6Jzo
+ YouTube Video
Just noticed that its still updating so video quality may be poor for a bit till its finished.
:: Serpent America ::Desoto Racing :: Track Star Racer Services ::Skyrocket Racing::TOP::
Timmie is offline   Reply With Quote
Old 09-19-2009, 12:54 AM   #1190
here is a vid of my TB03 in action. Sorry for the crappy quality. My car is the red one battling against the white car which is a TA05MS. Like Timmie said, the TB03 is a formidable contender in 17.5 against any high end model.
+ YouTube Video
inpuressa is offline   Reply With Quote
Old 09-19-2009, 07:30 AM   #1191
tns
Thanks for posting the videos guys! Always great to see TB03s in action!
timmie - that's 17.5T BL? That's pretty fast - what was your FDR and were you using lipos?
I'm giving serious consideration to taking part in my first RC competition in a couple of weeks. It'll be a 11.5t (BL)/23T open stock race. We can use any car (tires are controlled though) Some of the people who signed up are running TRFs, cyclones and X-Rays - not quite the amateur race I was hoping it would be
If I do take part, I'll likely to be running brushed (Tamiya superstock RZ) as I'm reluctant to be spending on yet another BL motor at the moment. What will be a good FDR for this? Any recommendations? I'm be using 6-cell NiMHs, if that makes a difference...
Cheers!
tns is offline   Reply With Quote
Old 09-19-2009, 09:42 AM   #1192
Hi TNS,
I think a general starting point FDR for a 23T motor should be around 5.5. Aggressive gearing can bring this down just below 5, but this is really border line case for your esc or motor.
From there, you really should base your next step on the motor and esc temperature. For motors, if you can keep it in the 70*C region, its ok. Region of 80*C can do for short term, but will shorten motor life quite a bit.
With no regards to weight, Lipo will maintain better voltage through out your run in contrast to NiMh. Maybe those really nice racing/match cells can compare (they have to be brand new too).
Good luck to your race!
Cheers!!
K.I.S.S.
Keep It Simple Stupid
kerk is offline   Reply With Quote
Old 09-19-2009, 06:53 PM   #1193
5x5 or 5x8???
Also, is the chassis 190mm or 200mm? Can it fit both sizes?
Old 09-19-2009, 08:15 PM   #1194
Swift and Sleek's Avatar
Default tb03
IVE BEEN RUNNING THE KIT FOR QUITE SOME TIME NOW AND I MUST SAYS IT GAVE TA05 A RUN FOR ITS MONEY.
1.DOES TAMIYA PRODUCE AN ADJUSTER WITH HOLES ON IT OR YOU GUYS JUST DRILL HOLES TO THE PLASTIC PART?
2. WHAT IS THE PART NUMBER AND THE PART NAME OF THE WHITE GEAR (PICTURE ATTACHED BELOW)?
3. WHAT SPRINGS AND OIL DO YOU SUGGEST FOR THE CAR NOT TO BE UNDERSTEER?
THANKS!
RICO
"TEAM BAD BOYS"
FOR THE LOVE OF THE GAME
Swift and Sleek is offline   Reply With Quote
Old 09-19-2009, 08:18 PM   #1195
Callahan_88's Avatar
This one is waiting for my TB-03D to be finished!
Go big or go home! :)
Callahan_88 is offline   Reply With Quote
Old 09-19-2009, 09:18 PM   #1196
Metla's Avatar
meh, I just fitted the 3racing aluminium steering components, there is now the same or maybe more slop then when the original parts were fitted.
Metla is offline   Reply With Quote
Old 09-19-2009, 10:46 PM   #1197
The only advantage i see in that is it uses ball bearings
I went from that to the tamiya one and boy, what a difference.
Ay Way Way is offline   Reply With Quote
Old 09-19-2009, 11:34 PM   #1198
Hebiki's Avatar
Trader Rating: 26 (100%+)
THANKS!
RICO
Rico,
some answers for you.
1. i just drill through the ball cup using a body reamer. the reason you want a hole there is because you're using a hex head ball stud. you can unscrew it without popping off the ball cup (which after excessive use will loosen.) this makes changing the spacers easier.
2. the gear in that photo is a Xenon spur gear. they come in a variety of different sizes. visit www.speedtechrc.com - Jeff is the owner, and he has all the different sizes (for 64P and 48P).
3. this is too broad of a question. we'll need to know the body, motor, tire, inserts you are using as well as track conditions. provide these and one of us can point you in the right direction in terms of set up.
- C
Hebiki Design Works
Custom R/C Vinyl Graphics & Apparel: Your gear, your way!
Web Design - Web Development - Logo Design - Graphic Design
www.facebook.com/HebikiDesignWorks
Hebiki is offline   Reply With Quote
Old 09-20-2009, 04:25 AM   #1199
Default tb03
Originally Posted by Hebiki View Post
Rico,
- C
HEBIKI
BODY- ARTA GARAIYA
MOTOR- SILVER CAN
TIRE- STOCK 24MM TAMIYA SLICK TIRES
INSERT- STOCK INSERTS
TRACK ASPALT
THANKS!
"TEAM BAD BOYS"
Old 09-20-2009, 06:05 AM   #1200
5x5 or 5x8???
Hi Drftwoof,
For your shocks, you need this, "RC 5mm Ball Connector"
https://www.tamiyausa.com/product/it...uct-id=9804205
EP (Electric Powered) cars generally are 190mm chassis. For drifting, people tends to run 200mm covers, this will allow them to choose rims with plenty of offset. This will provide the deep dish look.
I personally uses a bashed up HPI GS (200mm) cover mated to Front=7mm offset, Rear=10mm offset Speedway Pal rims. Standard suspension arms are used, not the short reversible arms.
In this picture, its fitted with HPI rims from its LP series. Its the inch up version of rims. The Front=6mm offset, Rear=9mm offset.
Cheers!!
K.I.S.S.
Selling Schumacher Mi2, Tamiya M02, Tamiya TA04-S, Tamiya TB Evolution 3 Surikarn Ltd st_rob Australia For Sale/Trade 4 12-23-2008 06:37 PM
Tamiya 415 MSX, legacy 2.0, NIP Type A tires, Tamiya towel for sale or trade Fastburn R/C Items: For Sale/Trade 16 09-05-2008 11:45 PM
FS: Tekin Rebel 2 ESC w/ Tamiya GT Tuned Motor & Tamiya AM Radio & Receiver wrxnfx R/C Items: For Sale/Trade 6 06-10-2008 05:40 PM
Tamiya M03 / Trinity Brushes / Muchmore Battery Cooler / Tamiya M Chassis Wheels bluejays R/C Items: For Sale/Trade 2 12-16-2007 08:31 PM
Hpi rs4, tamiya tt01, tamiya tg-10, tamiya sprint! MORE!!!!! Genuinekid R/C Items: For Sale/Trade 10 09-10-2007 03:21 PM
