Old 09-14-2009, 09:25 PM   #1171
Racecrafter's Avatar
Trader Rating: 25 (96%+)
Originally Posted by Timmie View Post
Hey! good to know your well Ooo cool your racing the Mazda race too. Dang wish I could come. I won a race this past weekend with my 416. PM me if you want to compare setups hehe. You did awesome at the nats, you just needed that diff a little sooner
I plan on coming back to the left coast for sure sometime this year. My Mom wants to visit with family in Corona so I'm going to go with her. I want to see if there is any races out there that I can try to time it right to make. Know when West coast will re open?
Good to hear Tim!
I'm only 30 minutes from Corona.
Jimmy
Jon Dy, You going to Camarillo?
Jimmy Wright
www.trackstarrc.com ~ www.facebook.com/TrackStarRC ~ Home of the 2x's Stock Nationals Champion TS-Gold & TS-Black tire sauce, TS-1+ lubricants, TS-Precision bearings, XRG Xtreme Racing Grease, Scale Auto Engineering, ElevenTech, WRD2, Carbon 12, Stiff Products
Racecrafter is offline   Reply With Quote
Old 09-14-2009, 10:33 PM   #1172
J.Dy's Avatar
Originally Posted by Racecrafter View Post
Good to hear Tim!
I missed 3 races already so I think I might sit this one out. Good luck Jimmy (not that you need it), take the gold!
R1wurks Competition Products
ABC Hobby USA
J.Dy is offline   Reply With Quote
Old 09-15-2009, 12:03 AM   #1173
Glinzo's Avatar
Whoa thats cool! nice stuff Florian! Hey can you find me a BMW e30 body over there?
No Problem:
21 EUR just the body.
2 Months ago they sold hundreds of TT-01 chassis with BMW E30 M3 and Mercedes 190 bodies for just 55 - 85 EUR.
Glinzo is offline   Reply With Quote
Old 09-15-2009, 07:00 AM   #1174
Swift and Sleek's Avatar
[QUOTE=Timmie;6336934]
Originally Posted by Swift and Sleek View Post
GUYS,
I HAVE FOUND OUT SOMETHING REGARDING MY PROBLEM WITH THE SHAFT BINDING. THERE WAS NO BINDING RIGHT NOW AFTER A LOOK INSIDE THE GEAR CASES. I FOUND OUT TOGETHER WITH SOME OF OUR LOCAL RACERS THAT THE SHIMMING VARRIES WITH THE KIND OF GEAR CASE THAT YOU WILL USE. AS FOR ME I USE A CARBON REINFORCED GEAR CASE FRONT AND REAR. I USED ONLY ONE PIECE OF SHIMMING ON EACH SIDE.
HAVING SAID IM NOW USING A CENTER ONE WAY AND I NOTICE SOMETHING AND I DON'T KNOW IF ITS NORMAL OR NOT. I NOTICED THAT THE PROPELLER JOINT SET REAR GOES UP AND DOWN.
HERE'S A VIDEO ON IT:
http://www.youtube.com/watch?v=FFngmwjx-NA
I AM NOW LEFT WITH THE KNUCKLE ARM MOTION TO NOT BEING STIFF FOR BEING STIFF WILL NOT LET THE SHOCKS DO ITS WORK. HAVE YOU GUYS TRIED SANDING THE KNUCKLE ARM OR USING DIFFERENT SHIMMING FOR THE KNUCKLE ARM TO SWING FREELY.
REFERENCE PICTURE IS ATTACHED[/QUOTE
Like I said before, you have to check shimming when you change diffs/parts etc to make sure your tolerances have not changed. Its good that you did when you went to the carbon cases, but did you check things out when you put the center one way in? If you shim the center one way correctly, the up and down you are seeing on the prop joint should go away.
Yes, you can do either. I just sand my hub with a fine fingernail file just enough to free things up
Timmie
I have followed every instruction on the manual about the shimming and still it still have the up and down movement of the joint have anyone here uses the center one way? Maybe shimming it more than the manual tells.
Kindly look at the manual adendum picture below if what I have done is right.
Thanks!
Rico
"TEAM BAD BOYS"
FOR THE LOVE OF THE GAME
Swift and Sleek is offline   Reply With Quote
Old 09-15-2009, 09:59 AM   #1175
[QUOTE=Swift and Sleek;6347449]
Timmie
Thanks!
Rico
Rico,
Sorry to jump in this mid way...
Watching your you tube video shows that there is nothing wrong with your shimming. The shaft that the drive shaft cup is on should move. This is where the one way "clutch" bearing resides. Shimming it tight would result in little to no one way movement.
Jimmy Wright
Old 09-15-2009, 11:29 PM   #1176
Smile TB03
[QUOTE=Racecrafter;6348089]
Rico,
Thanks for the info but am I right? I only placed 4 shimmings (as per manual) after the bearing holder and 1 pc of .1mm shim before the bearing?
So does this mean that the up and down movement of the propeller joint set is only ITS NORMAL REACTION? http://www.youtube.com/watch?v=FFngmwjx-NA
"TEAM BAD BOYS"
Old 09-16-2009, 08:37 AM   #1177
Timmie's Avatar
Good to hear Tim!
Jimmy
Sweeeeet. Can I bum a ride then? lol
:: Serpent America ::Desoto Racing :: Track Star Racer Services ::Skyrocket Racing::TOP::
Timmie is offline   Reply With Quote
Old 09-16-2009, 08:41 AM   #1178
Timmie's Avatar
Originally Posted by Glinzo View Post
No Problem:
yep thats the one Hmm I send you a PM later about it Wanting to make it match my 1/1. Wish mine was a M3 though
Old 09-16-2009, 08:45 AM   #1179
Timmie's Avatar
[QUOTE=Swift and Sleek;6351443]
You still shim the center one way like you would the standard propeller joint shaft, checking for excessive free play and adding shims accordingly but the needle bearings themselves cannot be shimmed and up and down movement in this area is normal.
Last edited by Timmie; 09-16-2009 at 08:47 AM. Reason: I haven't slept in 2 days lol
Old 09-16-2009, 08:56 AM   #1180
Timmie's Avatar
Hi all,
A little off the wall here, but was hoping someone could suggest a good site for free music downloads that I could add to some videos I want to post on YouTube of the TB03 in action. I tried to post one there, but was unaware of the copyright infringement they have implemented. Basically, I am looking for some underground, non famous, heavy metal/rock soundtracks that I could use that actually sounds decent The approved music YouTube has available leaves a lot to be desired Any help would be appreciated. Thanks!
Old 09-17-2009, 01:28 AM   #1181
Trader Rating: 4 (83%+)
I'm looking to replace my stock TB-03D Ball studs for my shocks and maybe all my turnbuckles. I'm tired of yanking them off with pliers because it feels like I am going to break something. I think their size is 5x8mm, confirm?
Will these be a good replacement for my shocks? Would the ball studs be the same for both the turnbuckles and the shocks studs?
http://www3.towerhobbies.com/cgi-bin...&I=LXRLD9&P=BR
Those are kinda pricey though, feel free to recommended me some cheaper if you know any. I'm still hunting.
Feel free to recommend.
DriftWoof is offline   Reply With Quote
Old 09-17-2009, 07:19 AM   #1182
tns
Hi
Why not just use one of these, if you're having trouble removing your turnbuckles & shocks from the ball studs?
http://www.rcmart.com/catalog/tools-...c-456_798.html
They do so make things easier
tns is offline   Reply With Quote
Old 09-17-2009, 07:27 AM   #1183
Timmie's Avatar
The steel ones are good for durability. But I prefer to use thesehttp://www.speedtechrc.com/store/ebp...id=618&id=6257
and these
http://www.speedtechrc.com/store/ebp...id=618&id=6258
I would use the 5X8 for shock mounting positions, and depending on roll centers that you used would determine if you used a 5X5 or 5X8 on other areas of the car.
Old 09-17-2009, 11:09 AM   #1184
What about these they are much cheaper. My TB-03D is pretty much stock with a locked rear diff(thanks to tire patches).
http://www.3racing.hk/products.php?products_key=4044
http://www.3racing.hk/products.php?products_key=4048
4.8mm Fit?
I can't seem to find how long they are.
4.8 x ????
Are they HEX ball studs?
Old 09-17-2009, 11:22 AM   #1185
Hebiki's Avatar
Trader Rating: 26 (100%+)
4.8mm Fit?
4.8 x ????
the tamiya ones are hex ball studs. those 3 racing doesnt look like its the same BLUE as the tamiya parts
gotta have matching blue!
Hebiki Design Works
Custom R/C Vinyl Graphics & Apparel: Your gear, your way!
Web Design - Web Development - Logo Design - Graphic Design
www.facebook.com/HebikiDesignWorks
Hebiki is offline   Reply With Quote
Selling Schumacher Mi2, Tamiya M02, Tamiya TA04-S, Tamiya TB Evolution 3 Surikarn Ltd st_rob Australia For Sale/Trade 4 12-23-2008 07:37 PM
Tamiya 415 MSX, legacy 2.0, NIP Type A tires, Tamiya towel for sale or trade Fastburn R/C Items: For Sale/Trade 16 09-06-2008 12:45 AM
FS: Tekin Rebel 2 ESC w/ Tamiya GT Tuned Motor & Tamiya AM Radio & Receiver wrxnfx R/C Items: For Sale/Trade 6 06-10-2008 06:40 PM
Tamiya M03 / Trinity Brushes / Muchmore Battery Cooler / Tamiya M Chassis Wheels bluejays R/C Items: For Sale/Trade 2 12-16-2007 09:31 PM
Hpi rs4, tamiya tt01, tamiya tg-10, tamiya sprint! MORE!!!!! Genuinekid R/C Items: For Sale/Trade 10 09-10-2007 04:21 PM
