Old 09-13-2009, 06:07 AM   #1141
CSaddict's Avatar
I was just going to cut the ball off the axle, take out 2mm and then TIG is back together. You solution seems less invasive!
TLR 22
Losi SCTE
Blitz Open
Xray T3 RCGT
www.rcmadness.freeforums.org
CSaddict is offline   Reply With Quote
Old 09-13-2009, 06:08 AM   #1142
CSaddict's Avatar
Originally Posted by Timmie View Post
Yes the lateral blocks. Then you have a/a front blocks. No they don't include other blocks in the kit unfortunately. Install the 46mm shafts in the rear and see if they clear ok. The rear uses xa/d so It is a little wider. Worse case scenario if the rears fit, is that you would have to buy a pair off 44mm shafts for the front. Or you could purchase wider front blocks. Buying blocks wouldn't be a bad idea either since they can be used in the rear as well to adjust your rear toe. Let us know how you make out.
If the front is wider than the back wont that effect the handling? How would it effect it?
TLR 22
Losi SCTE
Blitz Open
Xray T3 RCGT
Old 09-13-2009, 06:12 AM   #1143
Timmie's Avatar
Originally Posted by CSaddict View Post
OK Timmie I see what you are talking about with suspension blocks. I have XD left over from the rear. I need D or C blocks to make this work?
You had a xd block come with your car? Now I need to go look at my left over parts But xd is very short. So that is not the block you need. It should say 1D on the rear, rear block of your car. If you have one more of the 1D blocks left over on your parts tree, install both of them on the front of your car and see if your 46mm shafts fit then.
Also for a great reference and a way to see how to tune with Tamiya blocks, refer to this article on Tamiya's website, its very clear and concisehttp://www.tamiyausa.com/articles/fe...article-id=412
:: Serpent America ::Desoto Racing :: Track Star Racer Services ::Skyrocket Racing::TOP::
Timmie is offline   Reply With Quote
Old 09-13-2009, 06:19 AM   #1144
CSaddict's Avatar
LOL I just read that while searching about the blocks! Thanks for the help as usual.
TLR 22
Losi SCTE
Blitz Open
Xray T3 RCGT
Old 09-13-2009, 06:24 AM   #1145
Timmie's Avatar
LMAO! Now that's what I'm talking about! lol! That is actually something I did once with a car I had, got mad at the replacement cost so I TIG welded the center of some 1/8 buggy axles in its place Saved me 50 bucks hehe
Yes wider front blocks will effect the handling some. But in a good way I think you will find. I see you plan on running 13.5 so with the speed of 13.5 now, the wider blocks will make the front more stable at high speed. You can get away with running no sway bars running wide blocks too. All depends on your setup. Right now I am running C/C front and XA/D for the rear and it feels great for 13.5.
Old 09-13-2009, 06:42 AM   #1146
CSaddict's Avatar
So I just looked at the blocks I have left. The 1A has a small hole for a pin and the 1D has a large recess area for a ball stud of sorts. This doesnt seem like I could make it work.
TLR 22
Losi SCTE
Blitz Open
Xray T3 RCGT
Old 09-13-2009, 07:15 AM   #1147
Timmie's Avatar
Yeah I don't know why they did that, but the A blocks that come with the kit don't have the open end that the hinge pin ball shim fits into. The rear kit blocks do, just like the aluminum ones the rest of the Tamiya cars use. Just to check for fit, If you have two of the plastic D blocks, install both of them at the front of the car. If you don't have extra hinge pin ball shims to check this, take them from the front, rear XA block. I know its a pain, but then you will know what to do next, if you want to run those blocks or buy 44mm axles.
Old 09-13-2009, 07:45 AM   #1148
CSaddict's Avatar
The more I think about it the more I think they are getting cut and rewelded. I need to get back to my roots!! Make due with what you have. Thats how I learned to TIG...... I bought this car as a budget racer. Why spend more?
TLR 22
Losi SCTE
Blitz Open
Xray T3 RCGT
Old 09-13-2009, 08:13 AM   #1149
Timmie's Avatar
Sounds good, bevel and some 309 rod and call it a day hehe
Old 09-13-2009, 09:43 AM   #1150
CSaddict's Avatar
The 3racing shafts are stainless? I will have to check. I have tons of 309 so that would be great! I make custom turbo manifolds and use 304l so 308 and 309 I use the most.
TLR 22
Losi SCTE
Blitz Open
Xray T3 RCGT
Old 09-13-2009, 10:27 AM   #1151
Timmie's Avatar
I don't know if they are stainless or not. But I use 309 for mild to mild steel because I like working with it. Makes some pretty beads and seems just as strong. But ER70 is cheap if you don't have some laying around. Cool that you make manifolds, I've done a few for some imports
I know, off subject but we still kinda talked about TB03 hehe
Old 09-13-2009, 12:09 PM   #1152
Glinzo's Avatar
It got a little "different"
I can't embed the picture here. So here is a link:
http://www.bilder-hochladen.net/files/9wcf-4-jpg.html
Glinzo is offline   Reply With Quote
Old 09-13-2009, 09:16 PM   #1153
Racecrafter's Avatar
Trader Rating: 25 (96%+)
Holy Repsol Glinzo!
That is sweet!!
Jimmy Wright
www.trackstarrc.com ~ www.facebook.com/TrackStarRC ~ Home of the 2x's Stock Nationals Champion TS-Gold & TS-Black tire sauce, TS-1+ lubricants, TS-Precision bearings, XRG Xtreme Racing Grease, Scale Auto Engineering, ElevenTech, WRD2, Carbon 12, Stiff Products
Racecrafter is offline   Reply With Quote
Old 09-13-2009, 11:44 PM   #1154
Timmie's Avatar
Man, thats really good. Thanks for posting that up!
Old 09-14-2009, 12:04 PM   #1155
tech5's Avatar
Ready for Mazdafest/sevenstock 12!
TRACKSTARRC.COM
Track Star Racer Services / DE racing / TKO Bearings / AKA Racing / WRD2 / KO Propo / Fantom Motors and Batteries / M2C Racing / Scale Auto Engineering/EKD designs/STRC
"FROM THE BENCH TO THE TRACK, WE GOT YOUR BACK!"
tech5 is offline   Reply With Quote
Selling Schumacher Mi2, Tamiya M02, Tamiya TA04-S, Tamiya TB Evolution 3 Surikarn Ltd st_rob Australia For Sale/Trade 4 12-23-2008 07:37 PM
Tamiya 415 MSX, legacy 2.0, NIP Type A tires, Tamiya towel for sale or trade Fastburn R/C Items: For Sale/Trade 16 09-06-2008 12:45 AM
FS: Tekin Rebel 2 ESC w/ Tamiya GT Tuned Motor & Tamiya AM Radio & Receiver wrxnfx R/C Items: For Sale/Trade 6 06-10-2008 06:40 PM
Tamiya M03 / Trinity Brushes / Muchmore Battery Cooler / Tamiya M Chassis Wheels bluejays R/C Items: For Sale/Trade 2 12-16-2007 09:31 PM
Hpi rs4, tamiya tt01, tamiya tg-10, tamiya sprint! MORE!!!!! Genuinekid R/C Items: For Sale/Trade 10 09-10-2007 04:21 PM
