Old 09-02-2009, 04:54 PM   #1051
Callahan_88's Avatar
Just orded an Tamiya TB-03D (#92206) today!
Go big or go home! :)
Callahan_88 is offline   Reply With Quote
Old 09-02-2009, 05:59 PM   #1052
fat500's Avatar
Trader Rating: 29 (100%+)
@ c88 welcome to the team......you will love the car
fat500 is offline   Reply With Quote
Old 09-02-2009, 06:34 PM   #1053
Timmie's Avatar
Best decision you have ever made Have fun hanging sideways
:: Serpent America ::Desoto Racing :: Track Star Racer Services ::Skyrocket Racing::TOP::
Timmie is offline   Reply With Quote
Old 09-02-2009, 06:40 PM   #1054
congratulations to the racers! Now let's see those setup sheets!
redbones is offline   Reply With Quote
Old 09-02-2009, 06:43 PM   #1055
Timmie's Avatar
[QUOTE=hermanchauw;6289909]Is it legal in a race to put the receiver or esc on top of the battery? I did this in my ta05 drifter and have to add only 10g on the battery side to balance.
It would raise the CG a little but in the stock instructions, it says to put the receiver on top of the servo anyway. Btw my battery is Orion 3200mah carbon edition.
Hi,
Not sure about the rules at your local track, but most places require the speed controller to be attached to the chassis. Receiver on the servo is not a issue, that is where I have mine on my TB. Another thing to think about with how your car is set up now, is that if you race indoors some tracks require you to charge your lipo in a safety bag. So if that would be the case, you would have a time doing that. Hmm or you could just put your whole car in if it would fit
Old 09-03-2009, 04:02 AM   #1056
Trader Rating: 4 (83%+)
Now that my TB-03D is built. I need to add the electroncis so I got a bunch of stuff for it. Only thing is, I didn't lock the Diffs, I only put them as tight as I could, really tight. To the point I think I could have broken it. I don't how to lock them though, I will learn and do it later.How do you lock the diffs though?
What do I need to max out my TB-03D for drifting? Center 1 way? Locked Diffs? What parts do I need?
I ordered these parts 2 days ago from Tower Hobbies:
-FRC175 RX CRYSTAL 75 75 75690
-Futaba R152JE 2-Channel AM Receiver 75MHz
-Novak Havoc Sport Sensored Brushless System
-Hobbico Extension 6" Futaba J
-Futaba S3010 Standard High-Torque BB Servo
-Integy Motor Heatsink Type II Wrap Around Gun
Let me know guys! Thanks again, the thing is smoother then My Yokomo MR4TC SD CMS by the initial feel of spinning the shaft.
DriftWoof is offline   Reply With Quote
Old 09-03-2009, 07:12 AM   #1057
Racecrafter's Avatar
Trader Rating: 25 (96%+)
Do not over tighten the plastic diff halves. You will break the centers out of them.
I suggest a spool for the front, aluminum halves for the rear and a center one way for better turn in.
Racecrafter is offline   Reply With Quote
Old 09-03-2009, 07:25 AM   #1058
Glinzo's Avatar
That's what i did. Now i'm waiting for a spool
I just finished building my TB-03. Now i'm waiting for some hop-ups. First drive on my local track will be in two weeks. I'm very excited...
Glinzo is offline   Reply With Quote
Old 09-03-2009, 03:00 PM   #1059
CSaddict's Avatar
My car pulls hard left on power. I think that is because of spool. I may take it out and see if it still does that with the ball diff.
TLR 22
Losi SCTE
Blitz Open
Xray T3 RCGT
www.rcmadness.freeforums.org
CSaddict is offline   Reply With Quote
Old 09-03-2009, 07:38 PM   #1060
They didn't brake. I have them really tight though. Will they brake when I drive it or something?
Can I got without lubing up the differential? I noticed it puts a bit of friction but it's still smooth. Can I go with out diff grease?
Center 1 way
A spool??? Is that a hole new Diff?
Aluminum halves?
Also, the stock motor spacer, do I need that? Does it have to be on? The heat might not transfer to the motor mounts cooling fins if i put it on. it looks like this:
http://www.tamiyausa.com/product/ite...oduct-id=54129
Will I be fine without it?
Where do they have these parts?
Old 09-03-2009, 08:08 PM   #1061
Metla's Avatar
http://www.rcmart.com/catalog/tamiya..._744_1229.html
Metla is offline   Reply With Quote
Old 09-03-2009, 11:06 PM   #1062
I got a set of universal shafts from 3racing, and i want to switch out to shorter swing shafts, does anyone here know if i just get a set of Tamiya swing shafts and use the 3racing wheels axles and cross joints with it?
Ay Way Way is offline   Reply With Quote
Old 09-04-2009, 08:39 AM   #1063
bluesxman's Avatar
Center 1 way
Aluminum halves?
1) Definitely lube your diff. Good video on building your diff: http://www.youtube.com/watch?v=ZLLoR...eature=related
2) Spool is basically just a solid axle: http://www.tamiyausa.com/product/ite...oduct-id=54125
3) Aluminum halves aka outdrives: http://www.tamiyausa.com/product/ite...oduct-id=54056
bluesxman is offline   Reply With Quote
Old 09-04-2009, 11:21 AM   #1064
The diff will usually come loose after a while regardless how tight u put it (from my experience)
Get Tamiyas direct coupling(spool) if you want something "locked" and put that in the rear.
Old 09-04-2009, 12:00 PM   #1065
3) Aluminum halves aka outdrives: http://www.tamiyausa.com/product/ite...oduct-id=54129
Number 3 you mentioned, isn't that the motor spacer?:
Also, do I need to add the stock motor spacer? Is it necessary? If I put it on it might hinder the heat getting into the motor mount fins to help cool it off.
I'm running a Brushless Novak Havoc Sport.
How do my parts list look?:
http://www.rcmart.com/catalog/rc-tb0...h=595_744_1229
http://www.rcmart.com/catalog/rc-evo...h=595_744_1229
http://www.rcmart.com/catalog/rc-dam...h=595_744_1229
http://www.rcmart.com/catalog/rc-tb0...2-p-27896.html
Or should I got with all 3Racing parts? Are 3Racing parts good? They are significantly cheaper.
Selling Schumacher Mi2, Tamiya M02, Tamiya TA04-S, Tamiya TB Evolution 3 Surikarn Ltd st_rob Australia For Sale/Trade 4 12-23-2008 06:37 PM
Tamiya 415 MSX, legacy 2.0, NIP Type A tires, Tamiya towel for sale or trade Fastburn R/C Items: For Sale/Trade 16 09-05-2008 11:45 PM
FS: Tekin Rebel 2 ESC w/ Tamiya GT Tuned Motor & Tamiya AM Radio & Receiver wrxnfx R/C Items: For Sale/Trade 6 06-10-2008 05:40 PM
Tamiya M03 / Trinity Brushes / Muchmore Battery Cooler / Tamiya M Chassis Wheels bluejays R/C Items: For Sale/Trade 2 12-16-2007 08:31 PM
Hpi rs4, tamiya tt01, tamiya tg-10, tamiya sprint! MORE!!!!! Genuinekid R/C Items: For Sale/Trade 10 09-10-2007 03:21 PM
