Old 08-29-2009, 04:04 PM   #991
Originally Posted by Callahan_88 View Post
When i look at all the pictures of the suspension mounts it looks like F is tha longets one!
Or are i wrong?
here a link where you can see the toe with the block and at the bottom its explain that A B C D E F is the wider and Xa Xb Xc Xd Xe Xf is the narrow one
http://www.rc-sunshine.ch/suspension-mounts.htm
Group B Monster is offline   Reply With Quote
Old 08-29-2009, 04:51 PM   #992
Callahan_88's Avatar
Thanks alot!
Edit: Canīt find any exploded view on the TB03!
Does anyone have an link?
Go big or go home! :)
Callahan_88 is offline   Reply With Quote
Old 08-29-2009, 09:34 PM   #993
Metla's Avatar
I've completed my build, I can see I'm going to have to upgrade most of the drive train, In fact I'm going to order in the parts immediately and fit them before I take it for its first run. The steering also needs immediate attention.
I'd also like to swap out the dampers but the recommended items are out of stock at rcmart so they will have to wait.
Does anyone see any benefit to swapping out the shock tower for the carbon fibre items?
Metla is offline   Reply With Quote
Old 08-29-2009, 10:13 PM   #994
Racecrafter's Avatar
Trader Rating: 25 (96%+)
Originally Posted by CSaddict View Post
The chart it comes with says its in the 7.2ish. It would need a huge pinion to get to the 4 range.
Yes you will need a huge pinion and a small spur.
Most all BL motor charts will show a 4.5 FDR as a starting point for a 13.5
With the 17.5s we run in RCGT its not uncommon to see some of us run 3.2 and at the Reedy Race I know some people who ran 2.9!
Racecrafter is offline   Reply With Quote
Old 08-29-2009, 10:18 PM   #995
Thanks for the link! That explains it perfectly!
Old 08-30-2009, 12:03 AM   #996
Trader Rating: 4 (83%+)
I'm getting a TB-03D the 29th, which is pretty much tomorrow in 5 minutes. Anyways I want to get it as good of a drifter as my Yokomo MR4TC SD CM.
I read on boards randomly that the TB-03D is smoother. And I noticed in pictures the TB-03 is symmetrical and the Yokomo MR4TC has a bulge on the side for the servo.
I am more into what's necessary for it. If it's good stock I'll keep it stock hop it up later.
What are some necessary hopups? Should I lock the rear diff get a one one too?
I plan to try and build it in on day, I never built a car before so feel free to give me some tips. Is it hard? I think the TB-03D is easier to build then the TB-03.
Thanks guys.
DriftWoof is offline   Reply With Quote
Old 08-30-2009, 04:06 AM   #997
Metla's Avatar
Just paid a visit to http://www.gearchart.com/ and generated this chart if anyone is looking into gearing, I also submitted the cars details so with a bit of luck it will be added to the list.
Old 08-30-2009, 05:50 AM   #998
CSaddict's Avatar
Thanks for the chart. What pinion and spur do I need as far as pitch? I called my LHS and he said, yes you may have a 46 pitch in there but may be different than the standard 46 he carries. He said it will be a metric in the Tamiya but similar. So if I need to change both, what are my options?
Is the spur bolt pattern standard and then I could change it to the style my LHS carries? I would think he has a lot of 64 pitch spurs and pinions since he does a lot of carpet there.
TLR 22
Losi SCTE
Blitz Open
Xray T3 RCGT
www.rcmadness.freeforums.org
CSaddict is offline   Reply With Quote
Old 08-30-2009, 08:52 AM   #999
Go 64 pitch....
You have waaaayyy more tuning option with 64.
Also if you run 17.5BL you will need a spur gear in the range of 72-78 and pinions ranging from 45-60.
Jimmy W
Old 08-30-2009, 10:09 AM   #1000
bluesxman's Avatar
Originally Posted by Racecrafter View Post
Go 64 pitch....
Jimmy W
60 tooth pinions? Are you really gearing in the low 3s or is my math wrong?
bluesxman is offline   Reply With Quote
Old 08-30-2009, 01:05 PM   #1001
Metla's Avatar
Throw the Tamiya spur and pinion in the rubbish (seriously, if they go into the parts pile you may accidentally use them in the future) and just buy whatever pitch your LHS carries. They both do exactly the same job.
Looks to me like any generic spur will fit.
Old 08-30-2009, 01:19 PM   #1002
fat500's Avatar
Trader Rating: 29 (100%+)
I run 3.6 now down from 3.9. 76/51 64 pitch . PRS gears. Very smooth
17.5 rcgt. motor temps at aprox. 155 deg after a 7min run so I could go lower
fat500 is offline   Reply With Quote
Old 08-30-2009, 01:22 PM   #1003
Metla's Avatar
That's wickedly steep gearing, Higher then what we run here on silver can motors.
Certainly made me rethink what gearing I'm going to go for, I'm going to fit an 8.5 to mine but swap that out to a 13.5 (legal race motor here in NZ) when funds allow.
Old 08-30-2009, 01:30 PM   #1004
fat500's Avatar
See the pics of my arta body. Notice the lack of rear bodywork and the small gray standoff's used on the body post's on the rear. Putting Body clips on have been a porblem on the arta body so they solve that They are Kenex toys and fit like a glove. That way the clips do not kill the body and no body slop in the rear
Old 08-30-2009, 01:34 PM   #1005
fat500's Avatar
I have found that you gear brushless much different that brushed. we run 17.5 rcgt but you can use a stock 27 turn and be just as fast. It will come down to the driving for the most part. Running 27 t you gear my Tb03 at 5.2-5.6 and brushless at 3.4 to 3.9.
Selling Schumacher Mi2, Tamiya M02, Tamiya TA04-S, Tamiya TB Evolution 3 Surikarn Ltd st_rob Australia For Sale/Trade 4 12-23-2008 06:37 PM
Tamiya 415 MSX, legacy 2.0, NIP Type A tires, Tamiya towel for sale or trade Fastburn R/C Items: For Sale/Trade 16 09-05-2008 11:45 PM
FS: Tekin Rebel 2 ESC w/ Tamiya GT Tuned Motor & Tamiya AM Radio & Receiver wrxnfx R/C Items: For Sale/Trade 6 06-10-2008 05:40 PM
Tamiya M03 / Trinity Brushes / Muchmore Battery Cooler / Tamiya M Chassis Wheels bluejays R/C Items: For Sale/Trade 2 12-16-2007 08:31 PM
Hpi rs4, tamiya tt01, tamiya tg-10, tamiya sprint! MORE!!!!! Genuinekid R/C Items: For Sale/Trade 10 09-10-2007 03:21 PM
