Old 08-12-2009, 02:06 PM   #706
Default DAMPER and INsert!
I have question about the TRF damper?
Is this the same? performance wise!
http://www.rcmart.com/catalog/rc-dam...8-p-26673.html
http://www.rcmart.com/catalog/rc-dam...2-p-23733.html
Also which tire insert should i use for low grip parking lot?
Thanks!
Have a Nice Race Day!
SKYFLAKES is offline   Reply With Quote
Old 08-12-2009, 02:12 PM   #707
This is the hopups that I will be purchasing for my car, I am a new tamiya user so Im not sure if I miss something or not. did I miss a part which is really important?
x Tamiya (#54056) TB-03 Aluminum Differential Joint Set
x Tamiya (#54067) TB-03 Suspension Mount (1XA)
x Tamiya (#54072) TB-03 Aluminum Suspension Mount (1D)
x Tamiya (#54073) TB-03 Aluminum Suspension Mount (1E)
x Tamiya (#54076) TB-03 Wheel Axles
x Tamiya (#54095) TB-03 Racing Steering Set
x Tamiya (#54097) TB-03 Carbon Steering Link
x Tamiya (#54125) TB03D Direct Coupling
x Tamiya (#54151) TB-03 High Precision Bearing Holder
x Tamiya (#53570) Clamp Type Alu. Wheel Hub (4mm Thick)
x Tamiya (#53907) 5x8mm Alu. Hex Ball Connector
x Tamiya (#53932) Alu. Suspension Mount Spacer (0.5mm)
x Tamiya (#53933) Alu. Suspension Mount Spacer (1mm)
x Tamiya (#54078) 44mm Swing Shafts
x Tamiya (#53724) 46mm LIGHTWEIGHT For TB Evo.IV
x Tamiya (#53539) 5.5mm Alu. Spacer Set
x Tamiya (#42137) Competition O-Rings For Oil Dampers
x Tamiya (#84008) TRF Sp Damper H Coating (BK)
Old 08-12-2009, 02:22 PM   #708
Hebiki's Avatar
Trader Rating: 26 (100%+)
thats a good set of hopups to start with.
Hebiki Design Works
Custom R/C Vinyl Graphics & Apparel: Your gear, your way!
Web Design - Web Development - Logo Design - Graphic Design
www.facebook.com/HebikiDesignWorks
Hebiki is offline   Reply With Quote
Old 08-12-2009, 02:32 PM   #709
bluesxman's Avatar
The only thing I can think of is a servo saver. The kit servo saver is junk. I assume you are good on springs, tires, and shock oil options?
bluesxman is offline   Reply With Quote
Old 08-12-2009, 02:37 PM   #710
Timmie's Avatar
Thanks!
Yes, they will perform the same. What tires are you planning to use? If you don't know what tires you will be using, just get some Much More aqua inserts. They work really well and are inexpensive to purchase. Your list looks good, but I would add a hex head screw kit to it as well. Trust me, the phillps head screws will drive you nuts! A friend that I recently converted to Tamiya...HEHHEHE.....bought a TA05 and got a nice stainless screw kit from Tony's screw kit or something. Worth checking out.
:: Serpent America ::Desoto Racing :: Track Star Racer Services ::Skyrocket Racing::TOP::
Timmie is offline   Reply With Quote
Old 08-12-2009, 02:50 PM   #711
Glinzo's Avatar
Originally Posted by CSaddict View Post
I just ordered a TB03(58409) and a Novak Havoc 13.5 esc and motor. I bought it to use on asphalt and carpet. The owner of the LHS told me I can't fit it with foam tires without extensive changes because the foams hit the knuckle. Is there any other option if I want to run foams on it? I intend to run rubber mostly anyway but I would like the option to switch.
I just can't imagine where the foams should hit the knuckle. Which foams are you looking for / by using which foams will this appear?
I use LRP VTEC foams on several cars and i don't have a problem with that. Normally the knuckle is turning in just parallel to the foam tire while steering so the space between will rest just the same.
The only problem i had on my trf 414M was that the inner rim touched the upper end of the tie rod attached to the knuckle. I solved this with some Dremel work on the inside of the rim. Just taking off 1mm on the inside removing the sharp 90 edge.
Glinzo is offline   Reply With Quote
Old 08-12-2009, 03:15 PM   #712
Dont take the Tamiya (#53724) 46mm LIGHTWEIGHT For TB Evo.IV use the 44mm . I buy the 46mm because the manual said that and its very tight with an allu diff or a spool ( never try the plastic diff with it). I use them with 0 camber for drift but if you go more than 2 degree of camber they dont fit anymore . I have to replace them with the stock for now and I will order the 44mm
Group B Monster is offline   Reply With Quote
Old 08-12-2009, 03:36 PM   #713
CSaddict's Avatar
I think the offset of the stuff he sells or maybe just what you mentioned. I will know soon enough.
TLR 22
Losi SCTE
Blitz Open
Xray T3 RCGT
www.rcmadness.freeforums.org
CSaddict is offline   Reply With Quote
Old 08-12-2009, 05:01 PM   #714
tech5's Avatar
Jimmy Wright Wins RCGT last night at WCRC with his Ballistic tb03!
TRACKSTARRC.COM
Track Star Racer Services / DE racing / TKO Bearings / AKA Racing / WRD2 / KO Propo / Fantom Motors and Batteries / M2C Racing / Scale Auto Engineering/EKD designs/STRC
"FROM THE BENCH TO THE TRACK, WE GOT YOUR BACK!"
tech5 is offline   Reply With Quote
Old 08-12-2009, 05:20 PM   #715
Racecrafter's Avatar
Trader Rating: 25 (96%+)
Thanks Tech5!
My goal was to be on pace with the average of the 13.5 TC's with my 17.5 RCGT car. I was close I think I was .6-.7 seconds average a lap slower than they were. not bad for a car with "radial" tires on it.
Racecrafter is offline   Reply With Quote
Old 08-12-2009, 06:19 PM   #716
Timmie's Avatar
Originally Posted by Racecrafter View Post
Thanks Tech5!
Woo hoo! Nice nice Jimmy! Great to hear of your continued success wow that close to 13.5's with you on xpatterns?!? DIALED! LOL! COOL!
Old 08-12-2009, 06:36 PM   #717
Hehehee! Yep on X-Patterns.
(Don't tell anyone but,..... It's got a few more tenths in it per lap )
Old 08-12-2009, 06:40 PM   #718
Timmie's Avatar
OH SNAPPY DOO! SHhhhh! Your already scaring the competition...no need to worry the 13.5 guys too!
Old 08-12-2009, 07:12 PM   #719
slakr's Avatar
Trader Rating: 28 (100%+)
Hey... that would be me
It's not a SS screw kit, but Tony's Screws are good stuff.
This is the kit I got for TA05v2... http://www.tonysscrews.com/product.s...&categoryId=60
It's a 136 piece kit for the TA05.
There is also a 180 piece kit for the TA05MS... http://www.tonysscrews.com/product.s...&categoryId=60
I also have various RC Screwz SS screw kits from other models; so far I have been able to avoid using the phillips heads
TLR 22 4.0, 22-4 2.0, 8IGHT & 8IGHT-E 4.0~XRAY XB2C~AE TC7.1
Tim aka "slakr" ROAR No. 3-119960
slakr is offline   Reply With Quote
Old 08-12-2009, 07:53 PM   #720
Core Creations's Avatar
Trader Rating: 93 (100%+)
Send a message via AIM to Core Creations
If anyones looking. I have some leftover hopups and parts for the TB03.
NIP Oneway
1 run old Spool
A couple NIP Diff and Spool/oneway gear sets
A bunch of composite suspension mounts XA etc
NIP stock composite outdrives (2 packs of 4 outdrives)
Drop me a PM if interested
Core Creations paint thread
Mini Mafia Kansas Chapter - where the monster minis grow!
Core Creations is offline   Reply With Quote
Selling Schumacher Mi2, Tamiya M02, Tamiya TA04-S, Tamiya TB Evolution 3 Surikarn Ltd st_rob Australia For Sale/Trade 4 12-23-2008 06:37 PM
Tamiya 415 MSX, legacy 2.0, NIP Type A tires, Tamiya towel for sale or trade Fastburn R/C Items: For Sale/Trade 16 09-05-2008 11:45 PM
FS: Tekin Rebel 2 ESC w/ Tamiya GT Tuned Motor & Tamiya AM Radio & Receiver wrxnfx R/C Items: For Sale/Trade 6 06-10-2008 05:40 PM
Tamiya M03 / Trinity Brushes / Muchmore Battery Cooler / Tamiya M Chassis Wheels bluejays R/C Items: For Sale/Trade 2 12-16-2007 08:31 PM
Hpi rs4, tamiya tt01, tamiya tg-10, tamiya sprint! MORE!!!!! Genuinekid R/C Items: For Sale/Trade 10 09-10-2007 03:21 PM
