Many discounts and deals on RC products and parts can be found on UltimateCoupons.com.
Consider visiting BensBargains.net for great discounts on remote control products.
Old 07-12-2009, 09:24 AM   #331
bluesxman's Avatar
Default Slack in the rear shocks
So with the stock kit and factory setup, I have slack in the rear shocks. Basically, with the suspension fully unloaded, I can freely slide the whole spring up and down a bit before I hit the preload or the bottom of the shock.
Is this normal? Is it anything to worry about? Should I use a larger preload spacer in the rear to take up the slack?
bluesxman is offline   Reply With Quote
Old 07-12-2009, 11:26 AM   #332
kraig822's Avatar
Originally Posted by redbones View Post
Shocks being long is ok. Just make sure they are all the same length. Your down travel will be limited by the droop screws anyway. Don't over tighten the lower ball joint as it may cause binding. If you build it exactly how the manual states, you should have about 5mm ride height. It is important to have the pushrods the correct length too.
I had the same problem this is what redbones told me and it solved my problem.
my pushrods were not the correct length as per the manual.
TB-03
NTC3
Slash
Mini Z
kraig822 is offline   Reply With Quote
Old 07-12-2009, 11:54 AM   #333
bluesxman's Avatar
When you say pushrod, do you mean the piston rod that goes inside the shock (BD11)? Or are you talking about the turnbuckles in the front that attach the the shock rocker arm to the front arm? Keep in mind that I'm talking about the rear shocks only here. The front is fine.
The manual is pretty vague here and doesn't say anything about proper length for the piston rod. Also, my rear turnbubkles are set to 19mm as per the manual. Thoughts?
One other thing I noticed is that there's a V2 part that I assume goes on the end of the piston rod. The manual doesnt mention it, but its longer than the V1 part and would probably take up the slack on the spring.
Old 07-12-2009, 06:19 PM   #334
kraig822's Avatar
bluesxman For the rear I just adjusted my droop screws so that the down travel does not let the shock spring hang loose. If you limit the down travel it should not let the pushrod fully extend. At first I had lots of slop between in the spring. after the adjustment its snug and I have the v4 spacer in there. before the adjustment I had to put the biggest spacer in the kit to make up for the slop. hope this helps.
By pushrods i meant the link that connects the front arm to the cantilever, but you said the rear I guess I didn't see that part sorry.
TB-03
NTC3
Slash
Mini Z
Old 07-12-2009, 08:13 PM   #335
bluesxman's Avatar
Thanks for the help. I also wonder if its worth shifting the shock over one hole to the center on the rear arms. At any rate, I'm not convinced its a problem, but I thought it seemed strange that the factory setup would have that slack.
Old 07-12-2009, 08:46 PM   #336
kraig822's Avatar
No problem bluesxman. It is kinda strange that the shocks come from the factory a little to long. This is the first time I have experienced it. Another way I have heard of fixing it is putting an o-ring on the shock piston rod inside the shock body just under the shock piston to limit the travel of the shock piston rod. That way seems like you could miss out on the extra shock travel.
TB-03
NTC3
Slash
Mini Z
Old 07-12-2009, 10:17 PM   #337
kraig822's Avatar
Default silver can fdr
Could anyone recommend a fdr for the TB-03 with a silver can. I would like to have more speed. Also after the first run I noticed the motor was hot to the touch and the esc was warm. Esc is teu 101bk and batteries are ener-g 4600. Is the car possibly under geared?
TB-03
NTC3
Slash
Mini Z
Old 07-13-2009, 03:56 PM   #338
Racecrafter's Avatar
My latest blog has been posted. Check it out!
http://www.teamtrf.com/index.php/myb...-the-tb03.html
Jimmy Wright
Racecrafter is offline   Reply With Quote
Old 07-13-2009, 07:20 PM   #339
bluesxman's Avatar
Well, with the stock setup, the can gets very hot for me too with 6 cell nimh. The batteries dont heat up too badly though. Personally, I'm not too worried about it. Worst case, I burn up a $5 motor.
Old 07-13-2009, 07:30 PM   #340
JimmyMac's Avatar
I got to hold a newly built TB03 today. My friend Timmie's. It's a very nice and completely smooth kit. I'm soo tempted to get one! Completely sealed drivetrain. Only thing I don't like is the huge amounts of steering slop from the plastic and bushings. But I'm sure this will be fixed with the steering hopup kit. Can't wait to see it on the track!
Mike J. Mc. (Roar No. 3-95872)
Team eXpress Motorsports : HobbyHaven : ORCA
Yokomo BD5
Tamiya TRF415 MRE : Tamiya TA05 : Tamiya Evo IV JM
JimmyMac is offline   Reply With Quote
Old 07-13-2009, 09:28 PM   #341
bluesxman's Avatar
I've put that sealed drivetrain to the test too. Driving in sandy and rocky parking lots, I've had zero problems with debris in the gears. I've had little pebbles get lodged in the suspension arms or between the motor and shaft. Basically the car ignores all the trash and keeps trucking.
Old 07-13-2009, 09:39 PM   #342
J.Dy's Avatar
Thanks for the update Jimmy, it's nice to hear from a tamiya driver with the same car. I raced RCGT that day also in the sportsman class. I always had my eye on your car while turn marshaling. Care to share your setup ? Thanks.
Jimmy Wright
R1wurks Competition Batteries
ABC Hobby USA
Fusion Hobbies USA
J.Dy is offline   Reply With Quote
Old 07-13-2009, 10:22 PM   #343
bluesxman's Avatar
Jimmy Wright
So the link requires a login and I see no way to create one. Anyway the average joe can read this?
Old 07-13-2009, 10:24 PM   #344
stitchy's Avatar
If you scroll down a little bit, link is on the left. "First major event wi..."
speedtechrc.com
stitchy is offline   Reply With Quote
Old 07-14-2009, 01:23 AM   #345
LOSI123's Avatar
Trader Rating: 37 (100%+)
I have built many smooth diffs in the past, but i cant seem to get my tb-03 diff feeling that smooth.
Any one else noticed this?
was wondering if the evo V ms balls and the alum tamiya outdrives will help this.
or if its the thrust bearing?
MPRCCC - Meakin Park Radio Control Car Club
Venom Pro 120A ESC - Tekin RS Pro - Novak Ballistic - Xray T2 009 EU
WWW.MPRCCC.LCRCCC.ORG
LOSI123 is offline   Reply With Quote
Forum Jump
Selling Schumacher Mi2, Tamiya M02, Tamiya TA04-S, Tamiya TB Evolution 3 Surikarn Ltd st_rob Australia For Sale/Trade 4 12-23-2008 06:37 PM
Tamiya 415 MSX, legacy 2.0, NIP Type A tires, Tamiya towel for sale or trade Fastburn R/C Items: For Sale/Trade 16 09-05-2008 11:45 PM
FS: Tekin Rebel 2 ESC w/ Tamiya GT Tuned Motor & Tamiya AM Radio & Receiver wrxnfx R/C Items: For Sale/Trade 6 06-10-2008 05:40 PM
Tamiya M03 / Trinity Brushes / Muchmore Battery Cooler / Tamiya M Chassis Wheels bluejays R/C Items: For Sale/Trade 2 12-16-2007 08:31 PM
Hpi rs4, tamiya tt01, tamiya tg-10, tamiya sprint! MORE!!!!! Genuinekid R/C Items: For Sale/Trade 10 09-10-2007 03:21 PM
Powered By: vBulletin v3.7.4
Content © 2001-2008 RCTech.net | Privacy Policy | Terms of Use Privacy Policy | Terms of Use
SEO by vBSEO 3.2.0
