Many discounts and deals on RC products and parts can be found on UltimateCoupons.com.
Consider visiting BensBargains.net for great discounts on remote control products.
Old 06-25-2009, 12:03 AM   #301
Originally Posted by kraig822 View Post
when building the shocks i noticed that when you put the spring on there is to much space and it moves up and down about 3mm. its like the shock piston is to long. i tightened the ends as far as they would go on. i have this problem on all 4 of the shocks. if i add more spacers the ride height is to high. any help would be appreciated
also would the mamba max esc fit, and would it be ok to use it with the stock motor?
Shocks being long is ok. Just make sure they are all the same length. Your down travel will be limited by the droop screws anyway. Don't over tighten the lower ball joint as it may cause binding. If you build it exactly how the manual states, you should have about 5mm ride height. It is important to have the pushrods the correct length too.
redbones is offline   Reply With Quote
Old 06-25-2009, 04:27 AM   #302
LOSI123's Avatar
Trader Rating: 37 (100%+)
I heard that only certain servo's fit this car as it has no servo adjustment in the mounts, Do futaba servo's fit ok ?
MPRCCC - Meakin Park Radio Control Car Club
Venom Pro 120A ESC - Tekin RS Pro - Novak Ballistic - Xray T2 009 EU
WWW.MPRCCC.LCRCCC.ORG
LOSI123 is online now   Reply With Quote
Old 06-25-2009, 10:36 AM   #303
Regional Moderator
Darkseid's Avatar
Does anyone know the spur/pinion combined min/max tooth count (64p) for the TB-03?
Tamiya M05pro - Tamiya TA05 IFS R - Tamiya TB-03 - TRR(Team Ruining Racing) - Futaba 4PK - Core Creations - Yu-Gi-OH! TCG - WOW player - iMac - iPhone 3G
Old 06-25-2009, 07:09 PM   #304
I don't think I can fit anything bigger than a 96 spur in there. pinion can go to around 50
Old 06-25-2009, 07:44 PM   #305
kraig822's Avatar
Thanks Redbones. The push rods were a little short and adjusted the rear droop screws and everything is just fine. Thanks again.
TB-03
NTC3
Slash
Mini Z
kraig822 is offline   Reply With Quote
Old 06-25-2009, 08:12 PM   #306
Regional Moderator
Darkseid's Avatar
No, I mean the max/min total tooth count between the spur and pinion combined, that the car can possibly function with.
For example: on my old Schumacher Mi3, the max tooth sum was: 161 teeth and the min tooth sum was 121 when using 64p gears.
That meant that if I used a 120t spur, that the biggest pinion that would fit would be a 41t. 120+41=161
I just find it useful when I'm trying a new car to know the max/min tooth count, that way I can be sure I'm never buying spurs or pinions I don't need. And after a long time of using my TA05 and IFS-R, I know I'll have to pick up a few new spurs and pinions to run proper ratios in the TB-03 in 17.5 racing.
No big deal if no one knows, I was just asking incase someone happened to know.
Old 06-28-2009, 02:54 AM   #307
LOSI123's Avatar
can this car achieve a fdr of about 10:1 for 3.5T motors
Old 06-28-2009, 10:22 AM   #308
Send a message via AIM to Markus
Darkseid,
I run 17.5 and use a 78 or 80 spur
the pinions I use range from 47 to 51 depending on what I need.
*note I had do use the 80 spur to drop two teeth in my current gearing. while using the 78 spur did not mesh; the motor and pinion did not reach the spur.
HTH.
Markus is offline   Reply With Quote
Old 06-30-2009, 02:18 AM   #309
Swift and Sleek's Avatar
Default GEAR
WHAT PITCH DOES THE TB03 USES, 64PITCH OR 48PITCH?
WHAT DOES X GEAR MEANS I HAVE SEEN SOME STICKERS ON SOME OF THE TAMIYA PRO DRIVERS CAR STICKERS.
TNX!
"TEAM BAD BOYS"
FOR THE LOVE OF THE GAME
Swift and Sleek is offline   Reply With Quote
Old 06-30-2009, 04:38 AM   #310
Is the TT01 propeller shaft compatible with the TB03?
rnd_tang is offline   Reply With Quote
Old 06-30-2009, 09:09 AM   #311
jrxs-r's Avatar
From memory, the TB03 comes with metric 0.6 module spurs... Easily changed over to any normal 48 or 64 pitch spurs as they bolt straight on.
Dunno about the shaft. I think they are different.
Cheers,
Zack
jrxs-r is offline   Reply With Quote
Old 06-30-2009, 09:11 AM   #312
jrxs-r's Avatar
Shouldn't have any problems... I've had the futaba servos in there before..
Cheers,
Zack
Old 07-02-2009, 08:15 AM   #313
LOSI123's Avatar
Can anyone tell me if i can widen my cars track width, with the inner suspension mounts , different ones?
I dont want to use the tamiya +2 rims anymore that came with my kit
And do any ta05 universals fit the tb03 front end
Old 07-02-2009, 11:41 AM   #314
the Ta05 axles do not fit. they use a different bearing size.
you can however use the swing shafts.
you'll have to get TB03/416 axles, it's cheaper to just get the axles then the whole universal set.
Old 07-02-2009, 01:42 PM   #315
J.Dy's Avatar
The ta05 ifs-r should work. The regular ifs is different.
R1wurks Competition Batteries
ABC Hobby USA
Fusion Hobbies USA
J.Dy is offline   Reply With Quote
Forum Jump
Selling Schumacher Mi2, Tamiya M02, Tamiya TA04-S, Tamiya TB Evolution 3 Surikarn Ltd st_rob Australia For Sale/Trade 4 12-23-2008 06:37 PM
Tamiya 415 MSX, legacy 2.0, NIP Type A tires, Tamiya towel for sale or trade Fastburn R/C Items: For Sale/Trade 16 09-05-2008 11:45 PM
FS: Tekin Rebel 2 ESC w/ Tamiya GT Tuned Motor & Tamiya AM Radio & Receiver wrxnfx R/C Items: For Sale/Trade 6 06-10-2008 05:40 PM
Tamiya M03 / Trinity Brushes / Muchmore Battery Cooler / Tamiya M Chassis Wheels bluejays R/C Items: For Sale/Trade 2 12-16-2007 08:31 PM
Hpi rs4, tamiya tt01, tamiya tg-10, tamiya sprint! MORE!!!!! Genuinekid R/C Items: For Sale/Trade 10 09-10-2007 03:21 PM
Powered By: vBulletin v3.7.4
Content © 2001-2008 RCTech.net | Privacy Policy | Terms of Use Privacy Policy | Terms of Use
SEO by vBSEO 3.2.0
