Old 05-31-2009, 09:49 PM   #271
Phat-Boy's Avatar
Trader Rating: 25 (96%+)
http://www.tamiyausa.com/product/ite...oduct-id=54076
Phat-Boy is offline   Reply With Quote
Old 06-01-2009, 11:04 AM   #272
Originally Posted by VooDooPH View Post
aftermarket spurs will fit... but i think your max is around 90+T 64p
all you'd need is the front shock mount to make it non-IFS
titanium/aluminum screws all around with the lightweight bodysets from proline or tamiya should drop your weight considerably. also the blue lightweight driveshafts.
Wrong the max spur is 96T 64P. That what I got and I dont think higher teeth will clear the cover, there not alot of clearance
Group B Monster is offline   Reply With Quote
Old 06-07-2009, 06:41 PM   #273
Swift and Sleek's Avatar
Smile SUSPENSION BLOCK
GUYS,
HOW DO YOU INSTALL YOUR ALUMINUM SUSPENSION BLOCKS? 1. UPRIGHT WHEREIN YOU SEE THE SUSPENSION BLOCK TYPE IE: 1X OR 2. DOWNRIGHT WHERE THE BLOCK TYPE CANNOT BE SEEN.
"TEAM BAD BOYS"
FOR THE LOVE OF THE GAME
Swift and Sleek is offline   Reply With Quote
Old 06-07-2009, 08:36 PM   #274
VooDooPH's Avatar
Trader Rating: 18 (100%+)
Send a message via Yahoo to VooDooPH
isn't "96" a "90+"? i might have given a broad range with my post but i don't think i was wrong.
[TRF418][TB-04Pro][FF-03Pro][M-05v2][TRF102][F-104 WGP][TT-01R TypeE]
[Cross CF-01'08][Yokomo R12][Team C TC02Evo][Team C T8E v3]
VooDooPH is offline   Reply With Quote
Old 06-07-2009, 08:37 PM   #275
VooDooPH's Avatar
Originally Posted by Swift and Sleek View Post
GUYS,
FR and RF, upside down with 3mm spacers
FF and RR, right side up with no spacers
hths
Old 06-07-2009, 09:07 PM   #276
kraig822's Avatar
Default new tb03
just ordered a tb03 gt-r. I can't wait to build this thing. By the way this forum has alot of great info.
kraig822 is offline   Reply With Quote
Old 06-07-2009, 09:12 PM   #277
Trader Rating: 110 (100%+)
I am using a TA05 front bridge suspension mount that has the hump in the middle of it for the belt to run through. This clears the chassis molding.
Dave
dragracer72nova is offline   Reply With Quote
Old 06-08-2009, 04:25 PM   #278
Default Impressive
Hi Guys.
Ive got a TB-03 up and running now and im impressed.
Ive been running various versions of the TA05 for a long time now, and this is perhaps a faster car in its element.
Its got tonnes of high speed steering, you can really push it going in, and the shaft really jumps out of corners also, I drove up the back of a couple of guys were I usually sit behind them comfortably with my TA05.
Oh I run 17.5,
And just a few things that I had trouble finding elsewhere.
You can get it down to 3.5 roll out.
I takes standard 2 or 4 hole spurs from kawada or Kimbrough.(48P)
I use 66T Kawada with about a 38 pinion since we have roll out limit.
But you can stick a 60T spur from Robinson racing in it and get down to your minus 4 roll outs.
Ive found it to be a long car, ive dropped the front tyres back to make it push slightly off power and rotate faster mid corner, and ive gone with a sway bar up front because its pretty twitchy without.
So far 7 wins from 8 starts aint bad.
Eat more possum!
Lees52 is offline   Reply With Quote
Old 06-08-2009, 09:09 PM   #279
VooDooPH's Avatar
anyone tried running the TB03 with a 13.5? rubber on asphalt? would appreciate pix on your install.
also, any tips on taking care of the diff pinion gear and bevel gears? they seem to be a bit fragile even with minor taps on the wall...
Old 06-09-2009, 03:07 PM   #280
hths
You will still need to use the 1mm plastic for this,
or you can make it with 4mm spacer on FR and RF (upside down)
1mm spacer on FF and FR
einix is offline   Reply With Quote
Old 06-09-2009, 03:28 PM   #281
kraig822's Avatar
Default lipo size
What is the biggest 7.4 2c lipo that the TB-03 can fit in the chassis without modification? Thanks in advance.
Last edited by kraig822; 06-09-2009 at 03:30 PM. Reason: not clear on the question
Old 06-12-2009, 06:06 AM   #282
LOSI123's Avatar
Trader Rating: 63 (100%+)
How fragile is the diff pinion gear? i was thinking of getting this car to run 17.5 motor with a spool in the front.
Team Durango - Speed Passion - Gens Ace
LOSI123 is offline   Reply With Quote
Old 06-12-2009, 10:09 AM   #283
Hebiki's Avatar
Trader Rating: 26 (100%+)
its very durable unless you run your car into a concrete wall. then you have other issues.
i've been running mine in RCGT which is 17.5. I also use a spool up front.
Hebiki Design Works
Custom R/C Vinyl Graphics & Apparel: Your gear, your way!
Web Design - Web Development - Logo Design - Graphic Design
www.facebook.com/HebikiDesignWorks
Hebiki is offline   Reply With Quote
Old 06-14-2009, 10:02 PM   #284
Default TB03
I HAVE JUST SHAVE PLASTIC PARTS THAT BLOCKS THE SUSPENSION MOUNT TO BE LAID WITH THE BLOCK TYPE SHOWING. I HOPE IM RIGHT WITH THIS ONE . I SAW IN THE TAMIYA PACKS THAT I MUST SHAVE SOME PARTS SO I DID .
BUT I STILL PUT THE PLASTIC SPACERS
"TEAM BAD BOYS"
Old 06-14-2009, 11:58 PM   #285
Smile TB03
Originally Posted by DA_cookie_monst View Post
it allows the diff balls to grip the plate better, allowing for less pressure on the diff to attain the same diff action.
SIR,
THIS ARE GOOD INPUTS AS WELL!!! DO YOU HAVE ANY ILLUSTRATIONS ON THIS WHICH SIDE OR WHAT PART EXACTLY.
"TEAM BAD BOYS"
Selling Schumacher Mi2, Tamiya M02, Tamiya TA04-S, Tamiya TB Evolution 3 Surikarn Ltd st_rob Australia For Sale/Trade 4 12-23-2008 07:37 PM
Tamiya 415 MSX, legacy 2.0, NIP Type A tires, Tamiya towel for sale or trade Fastburn R/C Items: For Sale/Trade 16 09-06-2008 12:45 AM
FS: Tekin Rebel 2 ESC w/ Tamiya GT Tuned Motor & Tamiya AM Radio & Receiver wrxnfx R/C Items: For Sale/Trade 6 06-10-2008 06:40 PM
Tamiya M03 / Trinity Brushes / Muchmore Battery Cooler / Tamiya M Chassis Wheels bluejays R/C Items: For Sale/Trade 2 12-16-2007 09:31 PM
Hpi rs4, tamiya tt01, tamiya tg-10, tamiya sprint! MORE!!!!! Genuinekid R/C Items: For Sale/Trade 10 09-10-2007 04:21 PM
SEO by vBSEO 3.5.0
