Old 05-10-2009, 07:13 AM   #256
Swift and Sleek's Avatar
Smile WHEEL AXLE
GUYS,
WHAT DO YOU GUYS PREFER FOR THE KIT
FRONT DRIVE: FRONT ONE WAY, CENTER ONE WAY, OR GEAR DIFF?
REAR DRIVE: CENTER ONE WAY, OR BALL DIFF?
ARE THE TA05 STABILIZER SET NEEDED FOR THE KIT OR ITS JUST ONE OF THE USELESS HOP UPS FOR THE KIT?
HAVE ANYONE TRIED IF THE TB03 AND TRF 415 WHEEL AXLES ARE THE SAME IN SIZE? IF IT IS IT WILL BE NICE BECAUSE THE TRF 415 HAS ITS LIGHTWEIGHT VERSION OF THE WHEEL AXLES.
Tamiya (#54076) TB-03 Wheel Axles
Tamiya (#53939) Lightweight Wheel Axle - For Reversible Suspension
THANKS!
"TEAM BAD BOYS"
FOR THE LOVE OF THE GAME
Swift and Sleek is offline   Reply With Quote
Old 05-10-2009, 07:45 PM   #257
VR6T's Avatar
Originally Posted by DragonDrop View Post
The new 3racing steering assembly is in there somewhere.
what is ur steering turn buckle length?coz i just cant get my steering straight.
TQ
VR6T is offline   Reply With Quote
Old 05-10-2009, 11:40 PM   #258
TQ
I just set the turnbuckles to whatever length i needed to get it to drive straight then I fine tuned it with my radio. Then I set up the EPA to 76 left and 96 right. But these numbers are all specific to my set up. Your servo placement and turnbuckle length will net you different numbers!
DragonDrop is offline   Reply With Quote
Old 05-11-2009, 10:19 AM   #259
TryHard's Avatar
You really shouldn't need to be running such large differences in EPA. EPA should be used as a last resort, not as a default means to set-up your steering.
Try the following;
First off, set you radio to equal steering each side, and remove any curve etc (you can put this back in later)
Set you toe links to equal length, and then mount them on the car. Ignore if you have extreme toe-in or out, you'll reset it later.
Now on you need to position the servo horn such that when the steering is in neutral, the drag link (link between the horn and assembly) is forming a 90deg angle. Given the height of the horn and steering assembly, this will require the horn to be off centre. Now this is not a problem, in fact it's a good thing, as the 90deg angle will ensure equal servo throw side to side.
Then set the drag link to the length needed to get equall amounts of toe either side (rembering the equal toe links from the previous step). When straight, then adjust the toe links equal amounts to the desired toe setting.
This way, you'll get equal steering throw side to side, with the car tracking straight. The only thing you might have to adjust is the sub-trim to get the servo horn in the right place, but take your time, and once you've done it a few times, it's very easy to adjust quickly.
Oh, and I would move that ball joint the otherside of the horn, as that much angle on the link isn't good
HiH
Ed
Old 05-17-2009, 07:51 PM   #260
VR6T's Avatar
thanx for the info bro...will try i later.
TQ
Old 05-18-2009, 01:51 AM   #261
Hebiki's Avatar
Trader Rating: 26 (100%+)
Originally Posted by Swift and Sleek View Post
GUYS,
THANKS!
lightweight axles are for the old chubs and rear hubs that used the 5x9 bearings. the TB-03 uses the new 416 axles that uses 5x10 bearings. Bigger bearings = more durable.
the TA05 sway bar kit will work on this car. what do you mean by "useless"? some people prefer sway bars... some don't. it all depends on your set up and track conditions....
Hebiki Design Works
Custom R/C Vinyl Graphics & Apparel: Your gear, your way!
Web Design - Web Development - Logo Design - Graphic Design
www.facebook.com/HebikiDesignWorks
Hebiki is offline   Reply With Quote
Old 05-20-2009, 01:23 PM   #262
Pentagonist's Avatar
Default Sorry. My english is not that awesome.
Hello everyone,
I got a few question to ask here about TB03. I am planning to buy TB03D soon and before that, I wanted to know if there's any of you guys here had tried using a one way shaft to your TB03?
What I mean is, is there any of you had tried using one way shaft for other models from Tamiya to your TB03 such as Topcad one way shaft for TT01 fitted to TB03?
Thanks.
Pentagonist is offline   Reply With Quote
Old 05-23-2009, 02:34 PM   #263
LOSI123's Avatar
Trader Rating: 63 (100%+)
Hello, Can anyone tell me if the tb-03 will fit after market spur gears, also if you can make it not an IFS just with a few parts????
Also can you make it be about 1425 grams with a 3800 li-po as current rules where i am allows minimum weight of 1425 grams
LOSI123 is offline   Reply With Quote
Old 05-24-2009, 02:04 AM   #264
VooDooPH's Avatar
Trader Rating: 18 (100%+)
Send a message via Yahoo to VooDooPH
aftermarket spurs will fit... but i think your max is around 90+T 64p
all you'd need is the front shock mount to make it non-IFS
titanium/aluminum screws all around with the lightweight bodysets from proline or tamiya should drop your weight considerably. also the blue lightweight driveshafts.
[TRF418][TB-04Pro][FF-03Pro][M-05v2][TRF102][F-104 WGP][TT-01R TypeE]
[Cross CF-01'08][Yokomo R12][Team C TC02Evo][Team C T8E v3]
VooDooPH is offline   Reply With Quote
Old 05-24-2009, 06:22 AM   #265
LOSI123's Avatar
double post
Old 05-24-2009, 06:33 AM   #266
LOSI123's Avatar
Thank you
do you know if you can achieve 3.5 fdr needed for most 17.5 racing ???
Old 05-24-2009, 08:23 AM   #267
J.Dy's Avatar
Thank you
Yes, I was running 72 spur with 49 pinion. Make sure you check your motor temp.
J.Dy is offline   Reply With Quote
Old 05-27-2009, 05:29 AM   #268
Smile TB03
BROS
1. WHICH IS LIGHTER THE STOCK PLASTIC SUSPENSION MOUNTS OR THE ALUMINUM?
2. IN THE KITS MANUAL IT SAYS TO USE THE 46MM SWING SHAFT BUT IN THE SOME OF THE INTERNET SITE IT OFFERS TO USE THE 44MM SWING SHAFT. WHICH ONE DO YOU GUYS REFER?
"TEAM BAD BOYS"
Old 05-27-2009, 07:48 AM   #269
Phat-Boy's Avatar
Trader Rating: 25 (96%+)
1. plastic
2. tb-03 ball diff 46mm / spool or oneway 44mm
tb-03d ball diff 44mm / spool or oneway 42mm
Phat-Boy is offline   Reply With Quote
Old 05-31-2009, 07:39 PM   #270
Smile TB03
IS THE TA05 WHEEL AXLE FOR UNIVERSAL SHAFT FIT THE TB03 AND 44MM SWING SHAFT??? THERE ARE NO STOCKS OF TB03 IN OUR LHS. DO YOU GUYS KNOW WHAT SITES HAVE THEM OVER THE INTERNET? THANKS!
"TEAM BAD BOYS"
Selling Schumacher Mi2, Tamiya M02, Tamiya TA04-S, Tamiya TB Evolution 3 Surikarn Ltd st_rob Australia For Sale/Trade 4 12-23-2008 06:37 PM
Tamiya 415 MSX, legacy 2.0, NIP Type A tires, Tamiya towel for sale or trade Fastburn R/C Items: For Sale/Trade 16 09-05-2008 11:45 PM
FS: Tekin Rebel 2 ESC w/ Tamiya GT Tuned Motor & Tamiya AM Radio & Receiver wrxnfx R/C Items: For Sale/Trade 6 06-10-2008 05:40 PM
Tamiya M03 / Trinity Brushes / Muchmore Battery Cooler / Tamiya M Chassis Wheels bluejays R/C Items: For Sale/Trade 2 12-16-2007 08:31 PM
Hpi rs4, tamiya tt01, tamiya tg-10, tamiya sprint! MORE!!!!! Genuinekid R/C Items: For Sale/Trade 10 09-10-2007 03:21 PM
