Old 04-02-2015, 06:43 PM   #2266
big al's Avatar
Originally Posted by CSeils View Post
Looking for setup settings for VTA?
USVTA rules, running on indoor carpet track.
I am getting close, thought I'd see what others are running to compare.
I've been running tamiya blues up front, no spacer on the ifs. RSD silvers in the rear, shocks on outer most upper hole. F/R shocks on mounted on arms per manual. Camber 1.5/2.0
HPI D compound vta tires.
40/30 oil--kinda light for carpet
It's handled well, but the rear still doesn't rotate as much as I would like. I'm gonna try a 1mm shim on the under the ballstud of the rear upright in hopes of fixing that.
You've sparked my curiosity as to your setup.
TA05 gen 1.... the real OG.
I'm not a racer, I just crush a lot.
17.5- Spec-r S1~ Scale Spec- VBC Ghost EVO ~ GT2- TA05 ~ GT3- TB03 ~ F1-F104
Keepin' it real with my M11x
big al is offline   Reply With Quote
Old 04-02-2015, 09:41 PM   #2267
vivo quevas's Avatar
Trader Rating: 18 (100%+)
How much droop are you running in the front and what do you need steering on corner entry or mid corner to corned exit? Also what sway bar in the rear are you using?
Awesomatix A800 USGT, Awesomatix 800 VTA, , Tamiya Euro Truck, CRC WTF1
http://localrcracing.freeforums.org/
HobbyTown Fresno, Ca. McAllister Racing, Visa/MasterCard's
vivo quevas is offline   Reply With Quote
Old 04-02-2015, 09:50 PM   #2268
big al's Avatar
I'm starting with 2mm over ride height for droop. I don't use roll bars at all. The hpi tires don't seem to generate enough grip to necessitate roll bars. I really need the rear end to come around at mid corner and corner exit. If the 1mm spacer doesn't get me moving in the right direction, I'll just put some heavier oil in the rear.
Old 04-02-2015, 11:04 PM   #2269
I would run a rear bar to get the car to rotate in the corner. I run bars on both ends of my of my VTA. You might want to try .5 less droop in the front so you don't lose as much steering when you are exiting the corner.
Old 04-03-2015, 06:42 AM   #2270
CSeils's Avatar
Trader Rating: 48 (100%+)
Here's my set up sheet for VTA. I'll probably change a few things next week once I see what the traction is like at the USVTA Nationals.
Gearing and driving aggressive enough are my biggest issues.
You can never go wrong with a Hooters Mini. But Mini Hooters are bad.
--- USVTA National Points Series Member #122 ---
customracingstickers@gmail.com - http://www.rctech.net/forum/painting-designs-graphics-photography/279695-usvta-trans-am-decals.html
CSeils is offline   Reply With Quote
Old 04-06-2015, 10:46 AM   #2271
SteveM's Avatar
Trader Rating: 134 (100%+)
If anyone is looking, I just listed my much loved TB-03 and a huge parts lot for sale.
Tamiya TB-03 Roller & Huge Parts Lot
SteveM is online now   Reply With Quote
Old 04-06-2015, 04:28 PM   #2272
big al's Avatar
I was able to get my TB03 into the 10th spot of the A-main this weekend at the Emerald City Classic in Seattle. It was a blast
Setup:
Front- 40wt oil, Tamiya blue spring, no spacers on IFS, stock lower shock arm mount. #4 camber hole, 2mm spacer under inner ball stud, 1.5 deg camber. Yellow roll bar. Slipper spool,
Rear- 30wt oil, RSD Silver spring, #4 upper shock mount, stock lower shock arm mount, 1mm spacer under inner ball stud, #4 camber hole, 2 deg camber, yellow roll bar, ball diff
HPI X-Pattern tires!
I decided to go with x patterns for the weight savings so that I could use a full size pack. They felt like they gave the tranny a little more snap.
I love driving this car.
Old 04-10-2015, 10:17 PM   #2273
my setup from TCS#203 GT3
torg is offline   Reply With Quote
Old 04-11-2015, 08:04 AM   #2274
OVA
OVA's Avatar
Trader Rating: 76 (100%+)
I have not failed. I've just found 10,000 ways that won't work
OVA is offline   Reply With Quote
Old 07-02-2015, 08:08 PM   #2275
big al's Avatar
Has anyone tried the 418 stabilizer set with the stock suspension? The 418 set is a far more attractive system.
Old 07-03-2015, 08:47 AM   #2276
If you fit with 418 arms
TamiyaW1688 is offline   Reply With Quote
Old 01-05-2016, 09:10 AM   #2277
bornox's Avatar
Trader Rating: 26 (100%+)
can i convert my tb evo 3 to tub chassis?
bornox is offline   Reply With Quote
Old 01-05-2016, 09:59 AM   #2278
Yes
Juan Aveytia is offline   Reply With Quote
Old 01-05-2016, 02:45 PM   #2279
bornox's Avatar
Originally Posted by Juan Aveytia View Post
Yes
what tub should i use? does the tub for tb03 fits?
Old 01-05-2016, 03:58 PM   #2280
No, TB-evo III is racing version of TB-02, they have many common parts. Take a look at Tamiya web, you can compare manuals
Papi is offline   Reply With Quote
Selling Schumacher Mi2, Tamiya M02, Tamiya TA04-S, Tamiya TB Evolution 3 Surikarn Ltd st_rob Australia For Sale/Trade 4 12-23-2008 06:37 PM
Tamiya 415 MSX, legacy 2.0, NIP Type A tires, Tamiya towel for sale or trade Fastburn R/C Items: For Sale/Trade 16 09-05-2008 11:45 PM
FS: Tekin Rebel 2 ESC w/ Tamiya GT Tuned Motor & Tamiya AM Radio & Receiver wrxnfx R/C Items: For Sale/Trade 6 06-10-2008 05:40 PM
Tamiya M03 / Trinity Brushes / Muchmore Battery Cooler / Tamiya M Chassis Wheels bluejays R/C Items: For Sale/Trade 2 12-16-2007 08:31 PM
Hpi rs4, tamiya tt01, tamiya tg-10, tamiya sprint! MORE!!!!! Genuinekid R/C Items: For Sale/Trade 10 09-10-2007 03:21 PM
