Old 03-15-2014, 09:26 AM   #2191
Jethroz's Avatar
Trader Rating: 49 (100%+)
Originally Posted by Atechbh View Post
It seems when I have the normal tamiya
Springs in I can only get down to 6mm
Ride height. If I put the short ones in
5mm is easy but it seems weak?
What is everybody else using? Short or
Long
My short black springs are softer than the standard springs. The short white springs are right at, if not slightly harder than, the standard springs. I run short black/blue on front with standard yellow in rear with the 1mm drop-down retainers in the rear only.
JustRacin'
"Shut up and Drive!"
Jethroz is offline   Reply With Quote
Old 03-15-2014, 08:21 PM   #2192
So today decided to run a 3s lipo for giggles.
My ball diffs melted
So what's my best bet for diffs?
Can the spec r diffs handle 3s lipos?
I am running a castle 3800kv motor
Thanks guys
Checkdalevel is offline   Reply With Quote
Old 03-15-2014, 09:53 PM   #2193
TB03Racer09's Avatar
Thanks guys
I advice you don't get the spec r diffs, I had 2 of them on my tb03 using a 4000kv motor on 3s, the ring gears strip very fast (5 runs if I'm lucky) and replacements are expensive. I went through 6 sets of $10 gear replacements in 4 months. I changed to the original Tamiya ball diffs then never stripped a gear again.
TB03Racer09 is offline   Reply With Quote
Old 03-16-2014, 09:36 AM   #2194
thanks for the advise.
I tried rebuilding the tamiya diffs as solide diffs and snapped the cups.
I picked up these ball diffs from broadtech. I couldnt find any info on them to see if they came with aluminum cups.
ww.broadtech.hk/eagleshop/shop/ShopProductDetail.aspx?id=3814
Old 03-16-2014, 09:53 AM   #2195
SteveM's Avatar
Trader Rating: 127 (100%+)
You can use Tamiya #54424 3x3mm bushings in place of diff balls to create a limited slip diff. The end result is close to a spool, but the bushings allow some slip.
SteveM is offline   Reply With Quote
Old 03-16-2014, 11:25 AM   #2196
Trader Rating: 29 (97%+)
hi I have some hopups for the tb03 for sale, these are brand new and in packages,
all are Tamiya
motor mount, motor mount adapter, spur gear holder, precision motor mount bearing holder, rear prop shaft, main prop shaft, selling everything for $99 usd shipped Canada and usa
zaraz is offline   Reply With Quote
Old 03-17-2014, 07:07 PM   #2197
whitrzac's Avatar
Trader Rating: 93 (100%+)
Are these all tamiya parts?
The 1B is tamiya, but IDK about the other 3...
whitrzac is offline   Reply With Quote
Old 03-17-2014, 07:52 PM   #2198
VooDooPH's Avatar
Trader Rating: 18 (100%+)
Send a message via Yahoo to VooDooPH
yes... the 1B is the reversible block made available around the same time as the TB03. the others are the earlier non reversible type (except the 1XB which is also reversible but of the older type).
[TRF418][TB-04Pro][FF-03Pro][M-05v2][TRF102][F-104 WGP][TT-01R TypeE]
[Cross CF-01'08][Yokomo R12][Team C TC02Evo][Team C T8E v3]
VooDooPH is offline   Reply With Quote
Old 03-19-2014, 08:37 AM   #2199
So my goodies from broadtech/Eagle Racing came in today. Ordered Sunday morning came in Wednesday from Japan to Maryland. WOW
These ball Diffs come with metal outdrive and came pre-assembled and adjusted.
Old 03-20-2014, 06:12 PM   #2200
Anybody looking for a nice TB03r I have 2 going up forsale. Very nice ones with hop ups
Selling as rollers or RTR. One has even competed at the worlds in japan.
Pm for pics or details if interested
Atechbh is offline   Reply With Quote
Old 03-21-2014, 06:16 PM   #2201
Send a message via AIM to A-Ko
what has been the lowest FDR on this car?
Jeffrey
teamgravityrc.com - motivrc.com
USVTA National Points Member #101
A-Ko is offline   Reply With Quote
Old 03-21-2014, 06:58 PM   #2202
big al's Avatar
I currently have a 55 spur and 38 pinion for a 3.53 with plenty of room to gear up.
big al is offline   Reply With Quote
Old 03-23-2014, 09:20 AM   #2203
Can't PM you for some reason. Try to PM me please.
salvine is offline   Reply With Quote
Old 03-23-2014, 06:20 PM   #2204
Thanks.
Jeffrey
Old 03-29-2014, 03:37 PM   #2205
Complete TB03R roller $210 shipped
TB03R
Selling Schumacher Mi2, Tamiya M02, Tamiya TA04-S, Tamiya TB Evolution 3 Surikarn Ltd st_rob Australia For Sale/Trade 4 12-23-2008 06:37 PM
Tamiya 415 MSX, legacy 2.0, NIP Type A tires, Tamiya towel for sale or trade Fastburn R/C Items: For Sale/Trade 16 09-05-2008 11:45 PM
FS: Tekin Rebel 2 ESC w/ Tamiya GT Tuned Motor & Tamiya AM Radio & Receiver wrxnfx R/C Items: For Sale/Trade 6 06-10-2008 05:40 PM
Tamiya M03 / Trinity Brushes / Muchmore Battery Cooler / Tamiya M Chassis Wheels bluejays R/C Items: For Sale/Trade 2 12-16-2007 08:31 PM
Hpi rs4, tamiya tt01, tamiya tg-10, tamiya sprint! MORE!!!!! Genuinekid R/C Items: For Sale/Trade 10 09-10-2007 03:21 PM
