Old 12-31-2013, 07:40 AM   #2131
vivo quevas's Avatar
Trader Rating: 18 (100%+)
Originally Posted by tdunster View Post
I'm running the 04 module 96t Spur and 51t pinion - But it's still nowhere near the gearing I need.
What spur and pinion are required for 21.5t ?
Part numbers would be awesome.
Cheers.
I recommend between a 72/75 spur gear 55/60 pinion
Robinson Racing #4172-#4175
Originally Posted by Juan Aveytia View Post
Do you guys have a race schedule posted anywhere?
Check out our forum at our local website
http://localrcracing.com/hobbytown-usa/
Awesomatix A800 USGT, Awesomatix 800 VTA, , Tamiya Euro Truck, CRC WTF1
http://localrcracing.freeforums.org/
HobbyTown Fresno, Ca. McAllister Racing, Visa/MasterCard's
vivo quevas is offline   Reply With Quote
Old 12-31-2013, 08:36 PM   #2132
Thanks. I'll be converting the TB-03 to a VTA racer now.
TB-03, M-03, M-04,M-05, TT-01, DF-03ra, TRF201, SCX10, Stampede
tdunster is offline   Reply With Quote
Old 01-05-2014, 04:04 PM   #2133
What spur do you use for a 4.0 fdr ?
The gears from my 417 and ta05 seem thinner and
I need to chage the spur as the current one on it is a 96
Atechbh is offline   Reply With Quote
Old 01-05-2014, 05:55 PM   #2134
Also how does a spool work in this car on carpet?
Or should I stick with diff?
Old 01-05-2014, 05:55 PM   #2135
Old 01-05-2014, 09:27 PM   #2136
CraigMBA's Avatar
Trader Rating: 22 (100%+)
Spool only.
I tried a diff, but couldn't get it tight enough. I didn't try building one with tamiya anti wear grease, and the TB04 gear diffs weren't available when I last tested.
Anyway, spool only.
* Cee Lo Dizzle, the Secizzle * Red Bull * Team Homies * Pintura de Negro Mate * USVTA #152
CraigMBA is offline   Reply With Quote
Old 01-06-2014, 04:52 PM   #2137
Anybody looking to sell a TB03 please pm me. Have one I am running gt3 with but would like to replace my TA06 with one for GT2
Old 01-21-2014, 08:26 AM   #2138
Jethroz's Avatar
Trader Rating: 51 (100%+)
Will the TB-03 spool gear fit on the TB-04 gear diff? I see a few retailers who have all the parts to build a couple gear diffs for my TB-03, but haven't seen anyone mention mounting the 39T ring to the gear diff. They share the same bulkhead trees, so they should drop right in, right?
JustRacin'
"Shut up and Drive!"
Jethroz is offline   Reply With Quote
Old 01-21-2014, 08:31 AM   #2139
CraigMBA's Avatar
You need the ring gear from the TB03D spool. Also, do not use the carbon rein gear cases. They have slightly less side to side clearance, and you can't shim the diff properly.
Took me a week to figure that one out.
Old 01-23-2014, 01:48 AM   #2140
VooDooPH's Avatar
Send a message via Yahoo to VooDooPH
i'm running the TB03 carbon reinforced gear cases in my TBO4... TB03 spool and TB04 gear diff dropped right in (0.1 shim on either side). i'm using the stock TB04 small pinion gear though, paired with the TB03's 39T large bevel gear. hths
[TRF418][TB-04Pro][FF-03Pro][M-05v2][TRF102][F-104 WGP][TT-01R TypeE]
[Cross CF-01'08][Yokomo R12][Team C TC02Evo][Team C T8E v3]
VooDooPH is offline   Reply With Quote
Old 01-23-2014, 01:53 PM   #2141
Trader Rating: 30 (97%+)
does anybody know where I can find the aluminum bridge on top of the rocker arms, in the tb03 typr r kit, there is no stock number in the manual, and no one lists it thanks
zaraz is offline   Reply With Quote
Old 01-23-2014, 01:59 PM   #2142
Tamiya never sold it seperatley, special item only for the R kits.
back9monsta is offline   Reply With Quote
Old 01-23-2014, 10:43 PM   #2143
CraigMBA's Avatar
Your gear diff is shimmed side to side wrong, I'm sure of it. It will have zero side to side lash with the pinion installed. Take the pinion out and you'll be able to move it. This means it's too tight, it shouldn't change when the pinion is installed.
Will it work with the side clearances wrong? Yes. Is it right? Absolutely not. Being too tight makes extra friction, and needlessly wears out the pinion prematurely.
The TB 03d spool is no problem. All the TB03 stuff has more side to side clearance for some reason.
Old 01-24-2014, 03:24 PM   #2144
Jethroz's Avatar
Thanks for the info. I have the CR bulkheads installed now but still have the originals from the car on the tree. Hopefully the CR work, even with a little modification, as I tend to oblong the hole the ball studs are in with the softer plastic.
JustRacin'
Old 01-25-2014, 05:46 PM   #2145
What body works best with this chassis for gt2 21.5?
Selling Schumacher Mi2, Tamiya M02, Tamiya TA04-S, Tamiya TB Evolution 3 Surikarn Ltd st_rob Australia For Sale/Trade 4 12-23-2008 06:37 PM
Tamiya 415 MSX, legacy 2.0, NIP Type A tires, Tamiya towel for sale or trade Fastburn R/C Items: For Sale/Trade 16 09-05-2008 11:45 PM
FS: Tekin Rebel 2 ESC w/ Tamiya GT Tuned Motor & Tamiya AM Radio & Receiver wrxnfx R/C Items: For Sale/Trade 6 06-10-2008 05:40 PM
Tamiya M03 / Trinity Brushes / Muchmore Battery Cooler / Tamiya M Chassis Wheels bluejays R/C Items: For Sale/Trade 2 12-16-2007 08:31 PM
Hpi rs4, tamiya tt01, tamiya tg-10, tamiya sprint! MORE!!!!! Genuinekid R/C Items: For Sale/Trade 10 09-10-2007 03:21 PM
