Old 09-27-2012, 03:22 AM   #2041
yobouno's Avatar
Originally Posted by WongTamiya View Post
Meh. Funny I actually prefer the Tb03 over the ta05 v2 R in touring. The last three people who won TCS must have done something right. I don't know about drift, but I've been looking into it. You never know, when you're young you wanna try so many different things.
both cars are actually quite similar in terms of parts, TB03 parts are used widely across many of Tamiya's product line including the TRF series.
I guess with TCS you have to use tamiya supported pitch gears. In tourers, I've changed to 48 pitch gears, in order to get a final gear ratio that is below 4:1; and this is with TA05 V2 (internal gear ratio of 2.055). TB03 can also do that, but with an internal gear ratio of 2.48:1, it's a lot harder to get below 4:1 final ratio without exploding your motor.
TAMYA M05, TB03, TA05 V2, TRF417X
yobouno is offline   Reply With Quote
Old 09-27-2012, 06:53 AM   #2042
rtypec's Avatar
At the TCS Finals, we can use any spur/pinion gear combination we wish and I believe the top runners were running 64 pitch gears in their TB03s, geared in the low to mid 3's with 17.5T motors. I was geared at 3.894 with a 13.5T lol.
The thing with shaft cars is that throttle feels very direct and could have more acceleration off corners. That, along with a drivetrain that is very free, will allow you to carry even more gearing.
But what do I know, I don't even have a TB03R
rtypec is offline   Reply With Quote
Old 09-27-2012, 07:09 AM   #2043
yobouno's Avatar
The X-rays and Yokomo I run with goes all the way down to 2.8 - 3.2, we are running club spec, 0 timing esc + 21.5T brushless but you can adjust motor timing. My motor was running at 65 - 70'C at 3.87 ATM. Am going to go down to around 3.01:1, will see what happens to the motor... BTW, this is with the TA05. I will do the same with the TB03 and see if I can achieve the same kind of speed. And yes, I do agree, shaft drive cars give better throttle output, a lot more torque compared to belt cars, just need to get the setup right.... which is something I am not quite prepared to do due to the high internal gear ratio. But if you think it's possible. I'll more than happy to give it a go. Personally, I do think TB03 is a better balanced car, just need to keep up with those Yokomos, ATM, it's like running my own race. I just don't have the speed to keep up with them on the straights. It's like a Mclaren vs Caterham. Same formula but the gap between the two are just really big.
BTW, I won't drive anything but tamiya. I've got a TC6, Sakura zero, all unbuilt. I even bought a BD5 and a Xray2010 and end up sold them at a lost....
Old 09-30-2012, 09:51 PM   #2044
NewWestF1's Avatar
Default light system
so i want to install a light system on my TB-03 .. i've seen these frames for holding the lights in the body ... can someone tell me which ones fit the TB-03 bodies?
.. Sakura FGX; Novak power plant, Exotek, Lotus/Renault #9 ..
.. TB-03 Calsonic GT-R . reventon s/ultra v.3 power plant . yeah racing ..
.. M-05 Mini Cooper, Silver Can 104BK speedo, fakkin' cute!
...one of these days, life will get easier...
NewWestF1 is offline   Reply With Quote
Old 10-02-2012, 06:33 AM   #2045
yobouno's Avatar
the frames will tell you which body it is for. ABC hobby has the best selections, they actually do it for their bodies though. The next option is get yokomo car shells, they have light bucket included as well.
Most of new tamiya bodies comes with light buckets as well. My Artaiya comes with front light buckets. for the rear, I've decided to just rim out a couple of holes and put the LED half way thru and fix the LED with a glue gun.
Old 10-02-2012, 10:30 AM   #2046
NewWestF1's Avatar
i'm guessing that the Impul Calsonic has these buckets as well. they have inserts you put the stickers on that attach in behind the lens. i can try to work it.
Old 10-03-2012, 07:02 AM   #2047
yobouno's Avatar
Yes, they comes with 2 options. Option one, colour everything thru and just use sticker.
Option 2, mask (as provided) then cut out the light buckets that comes with the car. The would be the best fit.
I might be doing the attaching of LED wrong, but it's effective neverthe less. What I do is use a rimmer and open a hole at the desired location. Put the LED in, the stuck it with a glue gun.
Old 10-03-2012, 11:05 AM   #2048
NewWestF1's Avatar
that's my project after painting this weekend .. when it's all done i'm going to take some photos before the girl gets a little banged up racing ..
Old 10-08-2012, 09:44 AM   #2049
NewWestF1's Avatar
Default TB-03 .. 2012 ..
TB-03 done .. Spaz Stix Holographic base coat, Spaz Stix Tribal mask, Tamiya Mica Blue, Spaz Stix Orange/Purple/Teal colour changing paint .. Speed Passion Ultra Sportsman v.3 / Reventon S .. Spektrum rx, HPI rubber .. Yeah Racing adjustable rear spoiler .. more tricks to come but other than the this stuff it's all stock for now ...
Tamiya TB-03-tb03_side.jpg   Tamiya TB-03-tb03_rear.jpg   Tamiya TB-03-tb03_top2.jpg   Tamiya TB-03-tb03_top.jpg   Tamiya TB-03-tb03_front.jpg
Old 10-10-2012, 09:30 PM   #2050
yobouno's Avatar
Nice
I've got 2 TB03R new in box mint condition listed on ebay. Please check it out.
http://www.ebay.com.au/itm/271078586...#ht_500wt_1138
Old 10-10-2012, 09:59 PM   #2051
NewWestF1's Avatar
ooooooh, that's a sweet deal! my wife would kill me though . i made a promise that i was a 2 car guy for now . very tempting though .
Nice
Old 10-11-2012, 07:26 PM   #2052
Any TB03 folks change their hubs and hub carrier to the TRF416 carbon reinforced ones? I find the TB03 ones have a little too much slop, not sure if it got worse over time though.
Thanks!
stocker is offline   Reply With Quote
Old 10-11-2012, 08:13 PM   #2053
WongTamiya's Avatar
-_-
WongTamiya is offline   Reply With Quote
Old 10-12-2012, 12:12 PM   #2054
DaveG28's Avatar
Trader Rating: 60 (100%+)
Hi guys, in case anyone's interested:
BNIB Tamiya TB-03R and Options
Viper ESC's ~ Xpert Servo's ~ Sanwa Radio
DaveG28 is offline   Reply With Quote
Old 10-13-2012, 04:53 AM   #2055
maxepower's Avatar
Talking plastic vs reinfored!
Thanks!
They get very sloppy over time. I like the reinfored hubs and the plastic hub carriers. The threads on the reinforced hubs last longer and the reinforced carriers can break if your not a perfect driver like me.
The plastic carriers are more forgiving if you hit a dot, they bend but not break.
Just my 2$
Tamiya Track Local. 10,000 Watts of power! ($5 donations for gas appreciated)
Proud Father of GT-1 Past Champion!"Hey, I got to go to Japan too!
FF03,TA-05V2 ,EXO-6,TA-07,TRF419,EVO-6
"Tamiya Racer to Infinity and Beyond!"
maxepower is offline   Reply With Quote
Selling Schumacher Mi2, Tamiya M02, Tamiya TA04-S, Tamiya TB Evolution 3 Surikarn Ltd st_rob Australia For Sale/Trade 4 12-23-2008 06:37 PM
Tamiya 415 MSX, legacy 2.0, NIP Type A tires, Tamiya towel for sale or trade Fastburn R/C Items: For Sale/Trade 16 09-05-2008 11:45 PM
FS: Tekin Rebel 2 ESC w/ Tamiya GT Tuned Motor & Tamiya AM Radio & Receiver wrxnfx R/C Items: For Sale/Trade 6 06-10-2008 05:40 PM
Tamiya M03 / Trinity Brushes / Muchmore Battery Cooler / Tamiya M Chassis Wheels bluejays R/C Items: For Sale/Trade 2 12-16-2007 08:31 PM
Hpi rs4, tamiya tt01, tamiya tg-10, tamiya sprint! MORE!!!!! Genuinekid R/C Items: For Sale/Trade 10 09-10-2007 03:21 PM
