Old 09-27-2011, 04:24 AM   #1966
Trader Rating: 8 (90%+)
Originally Posted by TB03Racer09 View Post
I have Spec R Gear diffs in the front and rear and the rear diff keeps stripping every 3 runs, any reasons why this keeps happening? Do you guys have any rear gear diff stripping problems too, with either the spec r diffs or the tamiya ones?
If some fluid leaks onto the gear, can it cause it to strip? If yes, how do u seal it.
What greases are you using? The spec r diff gear is made of nylon.
I am using an ezrun 8.5t 4000kv motor with 3s Lipo. I have the punch on the highest setting, would that really make a difference in wear?
I really like this car, I have no issues at all except the rear diff.
Thank You
Either your gears are too tight or too loose. You need to polish it and shim it accordingly. I believe using a bit of AE green slim around the joint and rubber seal helps a great deal. Also the felt they include may not be as good, you can make your own by going to an automotive store and getting their gasket and cut it yourself. Don't tighten the covers too much, just enough.
TenzoR is offline   Reply With Quote
Old 09-27-2011, 11:22 PM   #1967
TB03Racer09's Avatar
Default Spec R diffs
Thanks, How do you know that it has been meshed correctly, do you juts keep adding and subtracting shims until it feels the smoothess you can make it?
TB03Racer09 is offline   Reply With Quote
Old 09-28-2011, 10:15 AM   #1968
Hard to say, I polished my gears with 600 grit polish paper. I didn't need to add any additional shims. It felt tight at first but after some break in, it was good. No leaks yet. I also added a bit of Tamiya AW where the two covers meet the gasket.
The annoying part must be chopping cross joint to fit. I skipped the knife and sanded it off so I can be more precise.
Old 09-28-2011, 04:51 PM   #1969
Thank you very much for your help, I'm going to try that as soon as my parts come in (tracking say that its at my local post office
Do you prefer to use the IFS setup or the shocktower setup?
Old 09-29-2011, 01:18 AM   #1970
Default ?
Ok I received the parts and I built the car from scratch using the new bearings. I realised that the Rear bevel gear shaft is moving up and down when the gear box is removed from the car (but still sealed with the bevel gear and diff inside)
I looked closer to discover that the bearing housings in the gear caseare slightly too big for the bearing, causing the bearing to wobble with the shaft in it. Can this explain the stripping of the rear diff and the spur? I am using the carbon reinforced gear cases btw. Is this kind of wobbling normal, it happens to the front too but the front doesn't strip as easily as all the weight goes to the rear under acceleration.
If this gear case is the problem, what do you think I should do so the bearing is held tighter by the bearing housings?
Old 09-29-2011, 02:02 AM   #1971
http://www.youtube.com/watch?v=_MYKhz7ZHTU
here is a video of what I think could be the issue, I need this solved quickly so I can take my car overseas
Old 09-29-2011, 05:28 AM   #1972
I am using the front shocktower, it's easier to deal with when I need to change setup.
Old 09-29-2011, 05:31 AM   #1973
The only thing I can think of is you mixed up the bearings. One of them is 1060 and the other one is 1050.
Old 09-29-2011, 10:32 AM   #1974
WC
WC's Avatar
Trader Rating: 28 (100%+)
not easy to mixup, they be different widths
if your bearing is wobbly you can wrap some tape around the outside.
Tamiya yellow masking tape or cut a strip of vinyl sticker.
www.PandaGFX.com
www.MelbRC.org
WC is offline   Reply With Quote
Old 10-01-2011, 01:51 AM   #1975
Default ?
there is a 1060 bearing? Anyway I fixed the problem by carefully shimming and breaking in the drivetrain properly.
Now that the car has been fixed the car drives so well. I'm going to take this to the track for 17.5t boost, need to get a xerun combo now
Old 10-10-2011, 08:34 PM   #1976
Send a message via AIM to Profoxcg
sorry for the double posting, but I ordered an TB03 ( because I really wanted a garaiya body) anyway, I noticed that some people were using in their cars "gun metal" TRF FLUORINE COATED dampers/ # 53571.
How do these compare to blue ones that come on the TA06 PRO and TB03 Pro.
Profoxcg is offline   Reply With Quote
Old 10-11-2011, 04:42 PM   #1977
maxepower's Avatar
Cool which coating is better?
I believe the blue shocks have the titanium (gold colored coating) coated shafts and the fluorine coated is black. So, the titianium coating is harder and won't wear as fast as the fluorine coated shafts!
Tamiya Track Local. 10,000 Watts of power! ($5 donations for gas appreciated)
Proud Father of GT-1 Past Champion!"Hey, I got to go to Japan too!
FF03,TA-05V2 ,EVO-6,TA-07,TRF419W,EXOTEK-6
"Tamiya Racer to Infinity and Beyond!"
maxepower is offline   Reply With Quote
Old 12-16-2011, 11:51 PM   #1978
Hi guys.
I will be heading to Japan soon and plan on bringing back a drifter.
After researching for the past week or so I have narrowed down my choice to a TB-03D witch I can get for about 12,000 yen.
Is this a sturdy chassis? I don't plan on bashing it but I would like the thing to last.
Im planning on grabbing an alloy shaft and perhaps some stronger front arms
Are there any hop ups that you guys recommend picking up while im at it?
CompactDisk is offline   Reply With Quote
Old 12-18-2011, 08:21 PM   #1979
visual_rabbi's Avatar
Default Tamiya TB-03D roller for sale
Thought I'd drop this in here. TB-03D for sale - like new. Just trying to get it off my bench. Decided to go in another direction. Bought the kit brand new, assembled it, ran it 3 times in my driveway for testing, and then put it back in the box. Insane price.
FS: Tamiya TB-03D - like new for sale
What we do in life echoes for eternity.
- TBD...4WD SCT
- HPI Blitz
- Traxxas 2WD
- Xray M18 - Losi Micro Desert Truck - Team Associated SC18
visual_rabbi is offline   Reply With Quote
Old 12-31-2011, 06:47 AM   #1980
Lethal Enforcer's Avatar
Trader Rating: 97 (100%+)
Hi I am racing in a 540 class. I am going to try 64 pitch gearing. Anyone know a good starting point on a small technical track? Thanks
Axial Scorpion ,Team Associated TC5R , Tamiya M03R, Tamiya RC Onroad.com
2012 TCS Best of show Mini
2012 TCS Best of show TT01
Lethal Enforcer is offline   Reply With Quote
Selling Schumacher Mi2, Tamiya M02, Tamiya TA04-S, Tamiya TB Evolution 3 Surikarn Ltd st_rob Australia For Sale/Trade 4 12-23-2008 06:37 PM
Tamiya 415 MSX, legacy 2.0, NIP Type A tires, Tamiya towel for sale or trade Fastburn R/C Items: For Sale/Trade 16 09-05-2008 11:45 PM
FS: Tekin Rebel 2 ESC w/ Tamiya GT Tuned Motor & Tamiya AM Radio & Receiver wrxnfx R/C Items: For Sale/Trade 6 06-10-2008 05:40 PM
Tamiya M03 / Trinity Brushes / Muchmore Battery Cooler / Tamiya M Chassis Wheels bluejays R/C Items: For Sale/Trade 2 12-16-2007 08:31 PM
Hpi rs4, tamiya tt01, tamiya tg-10, tamiya sprint! MORE!!!!! Genuinekid R/C Items: For Sale/Trade 10 09-10-2007 03:21 PM
