Old 06-28-2011, 11:30 AM   #1936
Urabus23's Avatar
tdunster, Racecrafter...thanks for the info. I have some new gears in the mail so I'll be able to test them out soon.
I'll have a go at that setup sheet as well
Tamiya TB-03 : Speed Passion Club Race 17.5 : Airtronics MX-Sport
Urabus23 is offline   Reply With Quote
Old 06-29-2011, 03:43 AM   #1937
Originally Posted by Racecrafter View Post
This weekend at the King of Cal race the Sportsman winner was running a TB03 with the EXACT same combo you mentioned with a 3.65 final drive ratio.
Jeff is using my RCGT set up from the showdown two years ago.
Awesome information in that setup sheet.
Thanks for posting.
TB-03, M-03, M-04,M-05, TT-01, DF-03ra, TRF201, SCX10, Stampede
tdunster is offline   Reply With Quote
Old 06-30-2011, 07:44 AM   #1938
Racecrafter's Avatar
Trader Rating: 25 (96%+)
You both are very welcome.
The TB03 is still an awesome race car for the money.
Jimmy Wright
www.trackstarrc.com ~ www.facebook.com/TrackStarRC ~ Home of the 2x's Stock Nationals Champion TS-Gold & TS-Black tire sauce, TS-1+ lubricants, TS-Precision bearings, XRG Xtreme Racing Grease, Scale Auto Engineering, ElevenTech, WRD2, Carbon 12, Stiff Products
Racecrafter is offline   Reply With Quote
Old 07-01-2011, 06:15 PM   #1939
TB03Racer09's Avatar
Default Tamiya TB03
I have 8.5t brushless with 3s lipo, in speed, is it the equal to a 3.5t,4.0t or 4.5t motor?(remember I can gear it from 6.5-8fdr for my motor compared to 9fdr+ for the lower turns, currently geared stock).
Do you prefer rubber or foam when yo bashing?
TB03Racer09 is offline   Reply With Quote
Old 07-05-2011, 07:50 PM   #1940
Default DIFFS
The Diffs for the HP Shaft Drive Cars at R2 look the same as the tb03. Check the first page of that cars spare parts list on r2 to find the diff halves and diff gears. Check the last page of that cars spare parts to find the complete diff.
They look so similar. I might get the CF chassis from R2Hobbies soon. Does the handling increase?
And how fast do things get back in stock at R2Hobbies, the chassis is out of stock
Old 07-06-2011, 09:42 PM   #1941
Track Star drivers Jimmy Wright, Chris Vierra and Jeff White will be attending the Tamiya Fun Race this Saturday at Tamiya's world class race facility in Aliso Viejo Calif.
We will be fielding our new TA06 along with two of our Championship Winning TB03's.
We will be in attendance to not only race but to be there for anyone who needs help with car set up or driving instruction. Stop by and say Hello.
Jimmy Wright
Old 07-11-2011, 03:16 PM   #1942
visual_rabbi's Avatar
Default DB-03 to Rally car?
Ok. I got beat up on this on another forum, but I'm going to ask anyway.
Does anyone have any experience or suggestions about converting the TB-03 to a rally car? I've looked at two other cars (Exceed Champion/Drift Star and the Thunder Tiger Sparrowhawk VX) compared to the Tamiya, and it seems like this might offer the best performance and upgrade options.
Yes, I've considered the DF03ra, but it has major limitations with the battery compartment, and parts compatibility. A Tamiya rep said that by removing the "droop screws" and using shock spacers you could achieve the same ride height as the DF03ra.
What we do in life echoes for eternity.
- TBD...4WD SCT
- HPI Blitz
- Traxxas 2WD
- Xray M18 - Losi Micro Desert Truck - Team Associated SC18
visual_rabbi is offline   Reply With Quote
Old 07-11-2011, 08:18 PM   #1943
maxepower's Avatar
Questions?? Tamiya Fun Race!
DIDN'T SEE YOU THERE?
DYING TO SEE SOMEONE RUN A TA06! Fred the track coordinator been promising to run a TA06, so far a no show!
Tamiya Track Local. 10,000 Watts of power! ($5 donations for gas appreciated)
Proud Father of GT-1 Past Champion!"Hey, I got to go to Japan too!
FF03,TA-05V2 ,EXO-6,TA-07,TRF419,EVO-6
"Tamiya Racer to Infinity and Beyond!"
maxepower is offline   Reply With Quote
Old 07-13-2011, 12:05 AM   #1944
So what does everyone think of the spec r gear diffs, i want to get two
Old 08-03-2011, 04:43 AM   #1945
Ray Kindstrom's Avatar
Trader Rating: 147 (100%+)
Jimmy - what changes would you make to your setup for VTA? Bought a TB03 for my son to drive (he's 11 and has the racing bug real bad!)
Also...what spur gears fit for 64p. Speedtech has a kimbourgh 82t in stock.
Thanks.
Ray Kindstrom is offline   Reply With Quote
Old 08-05-2011, 01:35 AM   #1946
yobouno's Avatar
Default Drifting with TB03
Hi, I'm a TC driver, wanting to do some drifting. I love my TB03 and am gonna get TB03VDS for drifting. What would be the best esc to go with it? Is there a minimum turns motor you need to drift?
Am currently thinking of
Hobbywing Xerun 60A + 13.5T Xerun
or
LRP AI + LRP Vector / X12 13.5T
or
LRP SXX v2 + LRP Vector / X12 13.5T
or
Novak Kinetic 13.5T combo
Will 13.5T be too much for novice drifter? Should I just do 17.5T?
Is there any drift specific ESC or Motor?
Also what is the best gearing for drifting?
TAMYA M05, TB03, TA05 V2, TRF417X
yobouno is offline   Reply With Quote
Old 08-05-2011, 03:09 AM   #1947
Thanks.
Ciao Ray,
on my tb03 i'm using 88t, if you use a smaller spur than the motor will sit too close to the shaft
ciao
Max
mtaddei is offline   Reply With Quote
Old 08-05-2011, 04:06 AM   #1948
alien rc's Avatar
Very interresting for me...
--> If someone has made the conversion please give us your input !!!
FB : ALIEN R/C
www.alienracing.fr
alien rc is offline   Reply With Quote
Old 08-05-2011, 08:48 AM   #1949
yobouno's Avatar
TB-03 can take a whole lot of beating...
Don't need much change....
Follow the build instruction for TB03D. Don't use in-board suspension system. Use the shock tower.
Instead of lower your COG (slide 13 & 15), you want to let it have a bit more clearance.
Set your damper to about 60 - 65mm in length.
Put some rally block tyres. I think you should be good to go.
Old 08-05-2011, 09:29 AM   #1950
Mr LowDown's Avatar
Trader Rating: 21 (100%+)
I saw on youtube guys in japan use TA05 for rally but they runs on pack dirt track, so it should be no Problem for the TB03 to go rallying since all the gears are enclosed. I've used tb01 for rally before and will consider my tb03 for that also..
Mr LowDown is offline   Reply With Quote
Selling Schumacher Mi2, Tamiya M02, Tamiya TA04-S, Tamiya TB Evolution 3 Surikarn Ltd st_rob Australia For Sale/Trade 4 12-23-2008 06:37 PM
Tamiya 415 MSX, legacy 2.0, NIP Type A tires, Tamiya towel for sale or trade Fastburn R/C Items: For Sale/Trade 16 09-05-2008 11:45 PM
FS: Tekin Rebel 2 ESC w/ Tamiya GT Tuned Motor & Tamiya AM Radio & Receiver wrxnfx R/C Items: For Sale/Trade 6 06-10-2008 05:40 PM
Tamiya M03 / Trinity Brushes / Muchmore Battery Cooler / Tamiya M Chassis Wheels bluejays R/C Items: For Sale/Trade 2 12-16-2007 08:31 PM
Hpi rs4, tamiya tt01, tamiya tg-10, tamiya sprint! MORE!!!!! Genuinekid R/C Items: For Sale/Trade 10 09-10-2007 03:21 PM
