Old 01-31-2011, 08:27 AM   #1876
I was just about to say are they the same thing! Sorry about all the questions but I'm a complete noob!
Jammin23 is offline   Reply With Quote
Old 01-31-2011, 08:50 AM   #1877
MD
MD's Avatar
Trader Rating: 105 (100%+)
I'm glad to help.
MD is offline   Reply With Quote
Old 01-31-2011, 10:37 AM   #1878
Does anybody know how good the 3racing steering racks are as they work half the price of buying the tamiya steering and graphite steering link!
Old 01-31-2011, 04:51 PM   #1879
fantapants22's Avatar
ive just spent the last couple hours reading this thread but cant seem to find the answer if anyone is having compatability issues trying to fit a standard size 7.4v lipo pack into the tub tray of the TB03? want to get one after reading how surprisingly good they go for a shaft driven car at that cost! what would be someones best bang for buck upgrade on this? steering sounds worth while by the sounds of it
Savage X with LRP.30, Team Associated RC8.2 With LRP.21, Kyosho MP9 CNC upgraded with JS Racing 521R, Kyosho Spada 09, Kyosho Mini Inferno 09 (nitro), Traxxas Mini Revo massively hopped up, Parkzone Radian Pro DX6i. Eflite Blade MCPx
fantapants22 is offline   Reply With Quote
Old 02-01-2011, 06:12 AM   #1880
Hi guys just got a quick question. In your opinion what would you class as the better the tb03r or evo 3 surikarn?
Old 02-01-2011, 11:01 AM   #1881
Trader Rating: 14 (100%+)
Any standard packs should fit.... I run a 7.4V Yeah Racing lipo in and it fit easily...
The evo3 is an older car seeing as the EVO 5 has been around for a while now... the 03r isnt bad tho, comes with better components vs the traditional 03
boza is offline   Reply With Quote
Old 02-01-2011, 11:20 AM   #1882
Cheers for that going to get the tb03r but was offered a surikarn so just wanted to check! Also does anyone have any gearing suggestions for a 5.5 ezrun bl on the tb not racing yet just want a few ideas for bashing atm
Old 02-01-2011, 11:41 AM   #1883
Trader Rating: 8 (90%+)
Originally Posted by Shqizy View Post
Hi guys,
This tread seems to be almost dead, I still want to post my newest mod to tb-03 Diff :
I fitted new 12-3/32 Ball Diff gear of TRF502x !
http://lh4.ggpht.com/_HlgEPPfoh78/TQ...6/IMG_0644.JPG
upper tb-03 gear , lower TRF502x gear
http://lh5.ggpht.com/_HlgEPPfoh78/TQ...6/IMG_0646.JPG
finished Diff:
http://lh6.ggpht.com/_HlgEPPfoh78/TQ...6/IMG_0668.JPG
It feels really smooth and moreover now it can stand 13.5 with boost!
You need:
Tamiya 51438 TRF592x Ball Differential Gear Diff
12pc 3/32 or 2.4mm Diff Balls
--> file about 0.5 mm off of the end of the shaft from shorter diff joint
http://lh4.ggpht.com/_HlgEPPfoh78/TQ.../Unbenannt.png
--> don't use the 0.5mm shim between the 850 bearings
have fun!
I wonder if you can use the TRF502X diff halves instead? They seem to be the same size, and best of all, made out of steel and looked much stronger. I am using the swing shaft protector on mine aluminum metal halves but it's still wearing like a mofo.
TenzoR is offline   Reply With Quote
Old 02-01-2011, 12:38 PM   #1884
Default sweet as thanx for that boza
sweet as thankyou for that Boza
Old 02-04-2011, 12:01 AM   #1885
A 5.5t is probably good for a 6 or 7 min run at best and will place huge demands on the drive train and drivers wallet as things will wear out at an alarming rate.
If you already have the Ezrun 5.5t combo then gear it around the 8.5:1 mark and try not to run the car for more than 7 mins at speed otherwise you will cook it.
If you don't already have an Esc/motor combo then I would recommend something sensored with a turbo feature like the Hobbywing 120a or 60a v2 ESC and 13.5, or 17.5t motor.
Either of those will be more than a match for a sensorless 5.5t and a lot easier to handle.
TB-03, M-03, M-04,M-05, TT-01, DF-03ra, TRF201, SCX10, Stampede
tdunster is offline   Reply With Quote
Old 02-04-2011, 12:41 AM   #1886
You need LIPos that are the same shape as a stick pack.
The brick style lipos don't fit properly unless you dremel the chassis and put some packing in the tub to stop them from hitting the shaft.
The standard steering has a bit of slop in it but it's hardly a problem considering the cars market segment.
If you want the bling though pay the extra for the TRF/Tamiya parts - they are a lot better.
cheers
Old 02-04-2011, 08:41 AM   #1887
superspeed's Avatar
Default TCS Race Ready TB03
Reposting an excellent article:
http://www.tamiyausa.com/articles/fe...article-id=435
superspeed is offline   Reply With Quote
Old 02-05-2011, 01:24 PM   #1888
RandomFellow's Avatar
I run a brick style lipo in mine without problem. You do need to put spacers under the battery strap screws to raise the height, and I also took a couple thick plastic spacers and shoe gooed them to the inside wall of the battery tray to prevent the battery from shifting and contacting the driveshaft.
RandomFellow is offline   Reply With Quote
Old 02-06-2011, 06:06 AM   #1889
Nice work.
is that with the brick style lipos that are flat on the bottom or the ribbed ones ?
If it's with the ones that are flat on the bottom then I might give it a go.
cheers
Old 02-06-2011, 03:11 PM   #1890
Thanks for the advice have already got the combo so il just try to gear it as you said and see how it goes!
Selling Schumacher Mi2, Tamiya M02, Tamiya TA04-S, Tamiya TB Evolution 3 Surikarn Ltd st_rob Australia For Sale/Trade 4 12-23-2008 07:37 PM
Tamiya 415 MSX, legacy 2.0, NIP Type A tires, Tamiya towel for sale or trade Fastburn R/C Items: For Sale/Trade 16 09-06-2008 12:45 AM
FS: Tekin Rebel 2 ESC w/ Tamiya GT Tuned Motor & Tamiya AM Radio & Receiver wrxnfx R/C Items: For Sale/Trade 6 06-10-2008 06:40 PM
Tamiya M03 / Trinity Brushes / Muchmore Battery Cooler / Tamiya M Chassis Wheels bluejays R/C Items: For Sale/Trade 2 12-16-2007 09:31 PM
Hpi rs4, tamiya tt01, tamiya tg-10, tamiya sprint! MORE!!!!! Genuinekid R/C Items: For Sale/Trade 10 09-10-2007 04:21 PM
SEO by vBSEO 3.5.0
