Old 10-06-2010, 06:46 AM   #1816
Questions?? what ratio?
hey!, ive just ordered a lrp Brushless Combo SXX TC spec/ Vector X12 Modified 3.0T kit and plan to run this with 50C 2S 5000mah 7.4v LiPO batteries. all this is hunky dory but i was wondering what gearing setup will i need? i am building this project solely for drifting, gunna run lp32-front/lp35-rear drift tyres from hpi on a hb tcx. and also will i need to change the diffs to tougher items or will the tcx parts work fine? so puting long story short, i would like to know what pinion/spur gears and if necassary, what diffs will i need?
DEIGIMA is offline   Reply With Quote
Old 10-11-2010, 12:23 AM   #1817
Hebiki's Avatar
Trader Rating: 26 (100%+)
Default Last TB-03
im selling the last of my 3 TB-03s...and this has the most goodies.
perfect for VTA, RCGT, SuperGT+, 21.5...silver can.... GT3 racing
FS: Tamiya Hopped Up TB-03
Hebiki Design Works
Custom R/C Vinyl Graphics & Apparel: Your gear, your way!
Web Design - Web Development - Logo Design - Graphic Design
www.facebook.com/HebikiDesignWorks
Hebiki is offline   Reply With Quote
Old 10-17-2010, 05:28 PM   #1818
Trader Rating: 8 (90%+)
Does anyone know the part number for BC24 in TB03R? The blue aluminum piece that goes across the two IFS rocker nut.
TenzoR is offline   Reply With Quote
Old 10-17-2010, 06:59 PM   #1819
C5R01's Avatar
Send a message via Yahoo to C5R01
No part number yet, r chassis only. Tamiya America been trying for months and to no avail.
Current Cars:
Tamiya Garage:TB03; TA05V2-IFS; 414X #60;F104 V2;TA03r-s:TA03F:TA03R: FF01: FF03: M01: M03: M06: 1/14 Mercedes Semi truck- w/Reefer trailer ( fully functional): Tamiya Juggernaut 4X4X4, Tamiya RC Freightliner Cascadia Evo.; Honda City Turbo WR-02C; TRF102 F1
OTHERS:Kyosho 1/8th scale nitro Corvette C6R: Yokomo GT4 nitro, Slash 2WD,TA SCm5
C5R01 is offline   Reply With Quote
Old 10-17-2010, 07:07 PM   #1820
Phat-Boy's Avatar
Trader Rating: 25 (96%+)
ff03 has plastic damper mount #19115284(K14)
Phat-Boy is offline   Reply With Quote
Old 10-19-2010, 06:14 AM   #1821
Default propeller shaft length
just wanted to know the length of the stock TB03 propeller shaft
TIA
sadig is offline   Reply With Quote
Old 10-21-2010, 11:18 PM   #1822
TIA
154mm pin to pin or 160mm overall.
regards,
David.
Tamiya TB-03R - Sanwa MT-4s/RX-472/SRG-BLS v2/Super Vortex Zero - LRP X20 13.5
nzitr is offline   Reply With Quote
Old 10-23-2010, 08:47 PM   #1823
thanks a lot David!
Old 10-25-2010, 10:28 AM   #1824
Hey guys, does anyone have a baseline setup for the tb-03 on carpet? Ive searched the net, I found a couple baselines for the 416, but figured maybe you gents could help me out with a more specific tb-03 setup.
We run 17.5, stock spec ESC settings (no turbo/esc timing), rubber tires. Ill be running solaris soft or medium, or sweep 32's.
Ill be running at MSI racing in roseville MI, for those of you who know the track. Its a large track with a large amount of corners. Two decent straights that end with low speed corners. Not really what you would consider a "flowing" track setup.
PaintVagrant is offline   Reply With Quote
Old 11-07-2010, 12:42 PM   #1825
Trader Rating: 114 (100%+)
ok guys.. so what is the story with this car?
Why are they no longer available? Is tamiya releasing a new version or is there a production problem?
Chris Furman is offline   Reply With Quote
Old 11-07-2010, 06:01 PM   #1826
MD
MD's Avatar
Trader Rating: 111 (100%+)
Here's what I found on the Tamiya website. The TB03R appears to be the newest.
http://www.tamiyausa.com/search.php?....x=0&image.y=0
MD is online now   Reply With Quote
Old 11-07-2010, 06:13 PM   #1827
It is also non-existant and listed as discontinued on Tower.
Old 11-08-2010, 10:54 AM   #1828
Are TB03 compatible with the older type of suspension block e.g. from TRF415 and TA05? I know you need to add 5mm at the inner block to achieve the same height as the TB03/TRF416 style but other than that what's the difference?
Old 11-08-2010, 11:05 AM   #1829
AWK
AWK's Avatar
Just because Tower shows it as discontinued means nothing besides they are not carrying it anymore. I was told there are more on the way. www.speedtechrc.com is a good place to put an order in though.
AWK is offline   Reply With Quote
Old 11-08-2010, 11:12 AM   #1830
Racecrafter's Avatar
TB03 kits are in stock the TB03R kits are currently out of stock at Tamiya.
If you want a great deal on a kit either go through speedtechrc or www.trackstarrc.com
They are both very knowledgeable and TrackStarRC has the race experience to build and setup what ever you want.
http://www.trackstarrc.com/trackstar...mart&Itemid=64
Jimmy Wright
www.trackstarrc.com ~ www.facebook.com/TrackStarRC ~ Home of the 2x's Stock Nationals Champion TS-Gold & TS-Black tire sauce, TS-1+ lubricants, TS-Precision bearings, XRG Xtreme Racing Grease, Scale Auto Engineering, ElevenTech, WRD2, Carbon 12, Stiff Products
Racecrafter is offline   Reply With Quote
Selling Schumacher Mi2, Tamiya M02, Tamiya TA04-S, Tamiya TB Evolution 3 Surikarn Ltd st_rob Australia For Sale/Trade 4 12-23-2008 06:37 PM
Tamiya 415 MSX, legacy 2.0, NIP Type A tires, Tamiya towel for sale or trade Fastburn R/C Items: For Sale/Trade 16 09-05-2008 11:45 PM
FS: Tekin Rebel 2 ESC w/ Tamiya GT Tuned Motor & Tamiya AM Radio & Receiver wrxnfx R/C Items: For Sale/Trade 6 06-10-2008 05:40 PM
Tamiya M03 / Trinity Brushes / Muchmore Battery Cooler / Tamiya M Chassis Wheels bluejays R/C Items: For Sale/Trade 2 12-16-2007 08:31 PM
Hpi rs4, tamiya tt01, tamiya tg-10, tamiya sprint! MORE!!!!! Genuinekid R/C Items: For Sale/Trade 10 09-10-2007 03:21 PM
