Old 09-05-2010, 09:05 PM   #1801
RandomFellow's Avatar
Here is a photo of the rear:
RandomFellow is offline   Reply With Quote
Old 09-05-2010, 09:07 PM   #1802
Here is a photo of the front:
Old 09-05-2010, 09:57 PM   #1803
transplantlife's Avatar
Trader Rating: 43 (98%+)
Anyone know where i can find a tb03r.....thanx
IM A SURVIOR OF A DOUBLE ORGAN TRANSPLANT KIDNEY/PANCREAS...PLEASE BE A ORGAN DONOR TO GIVE LIFE TO OTHERS!!
transplantlife is offline   Reply With Quote
Old 09-06-2010, 01:32 AM   #1804
Drew RCNZ's Avatar
Why not go back a ball diff in front?
A spool in front on a shaft drive car increase stress on diff, pin/spur gears, specially on high grip track.
I know this set up will have slight less in corner speed. But easy for the gears.
Having a TB03R, 3 months/ 6 times indoor races, I only have to rebuild the F/R diffs once. (LRP QC3, tamiya silver can).
For the loose rear end in your case, try increase droop 3-4mm or more before wheel lift off ground. My club not yet racing brushless, hence i dont know power different btw a 17.5 and a silver can.
hope this help
cheers
Originally Posted by RandomFellow View Post
So, I ditched my TA-05 in hopes of falling in love again with shaft drive cars (my last one was a TC3). So, I've been running my TB-03 with a 17.5 for the last few weeks and I'm just stumped by how to resolve the really loose rear end on this car at speed. It doesn't matter if your on-power, off-power, neutral - going too fast (not necessarily too fast for the track, just too fast for the car) and the rear just goes.
Now, I'm running on indoor ozite with quite a traction groove laid into it. The car is just fishtailing all over the place, and I can't get a handle on it.
here is my setup :
Front:
ball diff
40 wt oil
Blue springs
1C/1C
Suspension mounts as low, 4deg C hub
arms 2mm towards the back
Tamiya medium anti roll bar
Upper link outside mount - 0mm
Upper link inside mount - 0mm in hole2
1.5 camber
0 toe
4.5-5mm height and 3mm droop
Rear:
Ball diff
35wt oil
Red springs
Shock bottom - short outside hole
Shock top - 3rd to farthest outside hole on tower
1XA/1C with 0 degree hubs
Tamiya soft anti roll bar
Upper link outside mount - 0mm and out side hole
Upper link inside mount - 0mm in 2nd hole
1.5 degrees camber
5.5-6mm ride height and 4-5mm droop
Im using MM24-32 tyres out door slippy track, depends on temp. I m not the fastest but i've got consistance lap times with this setting.
Tamiya having the best clear illustration kits manual.
Drew RCNZ is offline   Reply With Quote
Old 09-06-2010, 01:22 PM   #1805
My setup is as follows:
Front:
Solid diff
30wt oil
Blue springs
1mm spacer on shock pivot mount
1C/1C
Suspension mounts as low as can go
arms 3.5mm towards the back
Upper link inside mount - 2mm in hole 3
1.5 camber
1 degree toe-out
Rear:
Ball diff
30wt oil
Red springs
Shock bottom - farthest outside hole
Shock top - 2nd to farthest outside hole on tower
1XA/1B with 1 degree hubs
Suspension mounts as low as they can go
Upper link outside mount - 1mm and farthest outboard
Upper link inside mount - 1mm in hole 4
2.0 degrees camber
I'm running A tires with medium inserts (trying to keep it TCS legal). The car is balanced and tweak-corrected.
If anyone can give me some advice, I would greatly appreciate it. I'm really getting frustrated with this car, and I'm ready to toss it and go back to the TA-05.
Hey there Ransom fellow, are you in rochester hills michigan or are you somewhere else. Also which carpet track do you run at. I run at MSI raceway and I also have a tb03 that I sometimes run, mainly in vintage or rcgt classes. It would be great if you could come to msi I could then show you my set up for carpet which is pretty good.
mrod is offline   Reply With Quote
Old 09-06-2010, 06:41 PM   #1806
mrod:
I used to run at Larry's, but haven't since they turned their track into stadium. They just moved, and we're hoping they put in an onroad track in addition to the stadium track (they have the room now).
I have been going to MSI lately, which is were I've been working on my setup. As an example, a decent lap in 17.5 rubber on that track is around 11 seconds. I'm ok at 14 seconds, but as I push the car to go faster, and start to get down in the low 13s/ high 12s, the speed is just too much for the car.
If you can give me any help, I would REALLY appreciate it. When do you usually go out there?
Old 09-06-2010, 10:06 PM   #1807
mrod:
I am usually there on wendsday, and sometimes fridays for some practice, but usually every wendsday.
Old 09-08-2010, 04:22 PM   #1808
fat500's Avatar
Trader Rating: 29 (100%+)
anyone looking for tb03 hop-ups email me at trfmarc@gmail.com all in mint condition very lightly used.
chassis has been modded so a lipo will fit in the chassis perfectly done.
carbon reinforced chassis and ft & rear stiffners
tamiya blue motor mount SWEET
tamiya spool
carbon reinforced ctr bearing holder
tamiya blue ctr uni shaft
tamiya blue spur gear mount
tamiya tamiya lt wt blue rear shaft
tamiya rear alum diff
tamiya blue susp mount 1a & 1xa
carbon steering link
carbon reinforced rear shock tower
blue alum shock tower mount
carbon ft and rear gear cases
some other misc parts.
all for 90.00 shipped paypal only
motor mt cost 55 alone....
fat500 is offline   Reply With Quote
Old 09-08-2010, 04:32 PM   #1809
fat500's Avatar
@ mrod check your droop screws in the arms. kit setting will do just that on high traction. try screwing them down ft and rear until the car feels better.try 5 ft 4 rear to start. or 4/3 always run slightly more up ft. and this car handles almost identical to my ta05v2 with the same set up. as all the parts are the same
Old 09-08-2010, 05:03 PM   #1810
Hebiki's Avatar
Trader Rating: 26 (100%+)
YGPM
Hebiki Design Works
Custom R/C Vinyl Graphics & Apparel: Your gear, your way!
Web Design - Web Development - Logo Design - Graphic Design
www.facebook.com/HebikiDesignWorks
Hebiki is offline   Reply With Quote
Old 09-08-2010, 05:06 PM   #1811
Hebiki's Avatar
mrod:
always start with the trusted tamiya set up of blue/yellow springs..and yellow/red sway bars.
try that...and see how it goes.
Hebiki Design Works
Old 09-10-2010, 11:42 AM   #1812
Hebiki's Avatar
Default TB-03 For Sale
guys im selling my LAST TB-03... PM me for details. this car has a TON of hopups at a great price.
Hebiki Design Works
Old 09-11-2010, 07:44 AM   #1813
FrankB's Avatar
Default TB03 on rubber gym floor surface
I am thinking of picking up a TB03 (stock version out of the box) for some indoor racing this winter.
I will be running it on a rubberized gym floor in a highschool. Any tips of setup? The traction should be really good (rubber on rubber). The organizer has run his GT car with HPI X-pattern tires and said it had really good bite.
My first guess is to drop the ride height (super smooth, no bumps), and stiffen everything up to help it rotate.
Suggestions.
FrankB is offline   Reply With Quote
Old 09-13-2010, 04:08 PM   #1814
If you're looking for a TB03, this is the car to get. He let me drive it once and it was absolutely "DIALED". It has all the goodies too.
DOTMAN is offline   Reply With Quote
Old 09-14-2010, 12:55 AM   #1815
Hebiki's Avatar
Thanks Dotman.. ive posted more pix here:
FS: Tamiya Hopped Up TB-03
Hebiki Design Works
Selling Schumacher Mi2, Tamiya M02, Tamiya TA04-S, Tamiya TB Evolution 3 Surikarn Ltd st_rob Australia For Sale/Trade 4 12-23-2008 06:37 PM
Tamiya 415 MSX, legacy 2.0, NIP Type A tires, Tamiya towel for sale or trade Fastburn R/C Items: For Sale/Trade 16 09-05-2008 11:45 PM
FS: Tekin Rebel 2 ESC w/ Tamiya GT Tuned Motor & Tamiya AM Radio & Receiver wrxnfx R/C Items: For Sale/Trade 6 06-10-2008 05:40 PM
Tamiya M03 / Trinity Brushes / Muchmore Battery Cooler / Tamiya M Chassis Wheels bluejays R/C Items: For Sale/Trade 2 12-16-2007 08:31 PM
Hpi rs4, tamiya tt01, tamiya tg-10, tamiya sprint! MORE!!!!! Genuinekid R/C Items: For Sale/Trade 10 09-10-2007 03:21 PM
