Old 07-08-2010, 07:24 PM   #1786
fat500's Avatar
Trader Rating: 29 (100%+)
I will be racing my new ta05v2 this sat. I am a BIG fan of the tb03 (see my pic below) but have always wondered what the difference between the two machines would be.
I will post my findings here and in the ta05v2 thread
I will be using the Cusco subaru body i run on the TB03 so we get an accurate test
fat500 is offline   Reply With Quote
Old 07-09-2010, 12:01 AM   #1787
JD Skyline's Avatar
Please keep me posted!! What kind of motor are you going to use for this test? I'm wondering and curious how a TB03 will hold with a 13.5T or 10,5T BL motor in a race. For the winter season I'm thinking TB03
I will be watching the TA05V2 thread
JD Skyline
"NO GUTS NO GLORY"
Still lookin.......
http://jdskyline.blogspot.nl
JD Skyline is offline   Reply With Quote
Old 07-09-2010, 12:07 AM   #1788
Originally Posted by wrxnfx View Post
Hey, guys,
Just got my TB03R up and running, but don't go mocking me for using mine as a drifter.
Is that metal bumper plate just to add weight to the front (for drifting)??
The plastic bumper assembly on mine seems a bit droopy.
I'd like to make mine a bit more crash proof with something like that ( for when idiots drive across the track into the path of other cars)
1101 is offline   Reply With Quote
Old 07-09-2010, 12:21 AM   #1789
Ciao JD, i'm currently using the tb03 with 10.5T, with all hop up suggested by tamiya, it works great with good handling, i replaced also the chassis with the carbon fiber ones of 3racing, but sometims its better the plastic ones.
ciao
Max
mtaddei is offline   Reply With Quote
Old 07-09-2010, 01:10 AM   #1790
Trader Rating: 30 (100%+)
Yes, that aluminum bumper plate is to add a little weight to the front for more steering. There is a carbon fiber one, too.
In regards to my question, I found the answer when I looked under the rear chassis brace. There isn't much room to go any larger than a 64P 98T spur. That is the max without hacking everything. The EVO 5 can fit a 100T with a little filing of the upper deck.
wrxnfx is offline   Reply With Quote
Old 07-13-2010, 10:39 AM   #1791
By any chance...Does anyone have a 3Racing TB03-16 Graphite Chassis Conversion for the TB03 they are willing to part with? Prefer new, but would consider used, too. PM me if you have one to sell and let me know what you would be asking for it. Thanks!
Old 08-21-2010, 11:04 PM   #1792
has any one used cvds for the tamiya tb03? right now i have the tb03d and im getting some dog bone chatter in the front turning right only, also i have turned down the end point for the right direction only to about 65% compared to turning left which is 90% with out any binding?? can someone help or in need of cvds?
azn87 is offline   Reply With Quote
Old 08-22-2010, 04:31 AM   #1793
Default cvds
Yep i do, i think everyone here does as well
Use the 416 outdrives and driveshafts (46mm i think)
Aluminium or steel is up to you, aluminium will bend especially on the front - you can use aluminium on the rear and steel on the front
hope that helps
junn is offline   Reply With Quote
Old 08-23-2010, 12:31 AM   #1794
y would it be 46mm long if the kit calls for 42mm??? any advantages on that? does anyone know where i can get 2 locked spools and a center one way for cheap? except ebay??
Old 08-23-2010, 07:46 PM   #1795
MOTORMAN29's Avatar
I think it depends if your using a spool or something, But I have the steel front and blue aluminum on the rear.
MOTORMAN29 is offline   Reply With Quote
Old 08-23-2010, 07:47 PM   #1796
MOTORMAN29's Avatar
i'm sure the answer is somewhere in this thread. you just gotta read.......
Old 08-24-2010, 03:30 PM   #1797
A low cost fix for this problem would be to get some nitro fuel tubing and cut a small portion to fill up the play between the dogbone and the differential. Did this to my friends TB03 and didn't need to spend big bucks for CVDs.
Old 08-30-2010, 07:59 PM   #1798
can someone tell me what are the advantages of using the IFS system compared to the usual front shock mount???
Old 09-03-2010, 10:28 AM   #1799
I believe the main advantage of the IFS front suspension is lower CG and the ability to use bodies that have a more sloped front for better aerodynamics.
Old 09-05-2010, 08:43 PM   #1800
RandomFellow's Avatar
Default Help! - Major Oversteer!
So, I ditched my TA-05 in hopes of falling in love again with shaft drive cars (my last one was a TC3). So, I've been running my TB-03 with a 17.5 for the last few weeks and I'm just stumped by how to resolve the really loose rear end on this car at speed. It doesn't matter if your on-power, off-power, neutral - going too fast (not necessarily too fast for the track, just too fast for the car) and the rear just goes.
Now, I'm running on indoor ozite with quite a traction groove laid into it. The car is just fishtailing all over the place, and I can't get a handle on it.
My setup is as follows:
Front:
Solid diff
30wt oil
Blue springs
1mm spacer on shock pivot mount
1C/1C
Suspension mounts as low as can go
arms 3.5mm towards the back
Upper link outside mount - 0mm
Upper link inside mount - 2mm in hole 3
1.5 camber
1 degree toe-out
Rear:
Ball diff
30wt oil
Red springs
Shock bottom - farthest outside hole
Shock top - 2nd to farthest outside hole on tower
1XA/1B with 1 degree hubs
Suspension mounts as low as they can go
Upper link outside mount - 1mm and farthest outboard
Upper link inside mount - 1mm in hole 4
2.0 degrees camber
I'm running A tires with medium inserts (trying to keep it TCS legal). The car is balanced and tweak-corrected.
If anyone can give me some advice, I would greatly appreciate it. I'm really getting frustrated with this car, and I'm ready to toss it and go back to the TA-05.
RandomFellow is offline   Reply With Quote
Selling Schumacher Mi2, Tamiya M02, Tamiya TA04-S, Tamiya TB Evolution 3 Surikarn Ltd st_rob Australia For Sale/Trade 4 12-23-2008 06:37 PM
Tamiya 415 MSX, legacy 2.0, NIP Type A tires, Tamiya towel for sale or trade Fastburn R/C Items: For Sale/Trade 16 09-05-2008 11:45 PM
FS: Tekin Rebel 2 ESC w/ Tamiya GT Tuned Motor & Tamiya AM Radio & Receiver wrxnfx R/C Items: For Sale/Trade 6 06-10-2008 05:40 PM
Tamiya M03 / Trinity Brushes / Muchmore Battery Cooler / Tamiya M Chassis Wheels bluejays R/C Items: For Sale/Trade 2 12-16-2007 08:31 PM
Hpi rs4, tamiya tt01, tamiya tg-10, tamiya sprint! MORE!!!!! Genuinekid R/C Items: For Sale/Trade 10 09-10-2007 03:21 PM
