Old 06-17-2010, 09:23 AM   #1771
Aha I see, makes sense. So, will I be able to use my 26 mm X-Patterns or do I need to get some 24mm wheels for the car?
nbla is offline   Reply With Quote
Old 06-17-2010, 09:24 AM   #1772
Hebiki's Avatar
Trader Rating: 26 (100%+)
you can use the 26mm xpatterns just fine.
Hebiki Design Works
Custom R/C Vinyl Graphics & Apparel: Your gear, your way!
Web Design - Web Development - Logo Design - Graphic Design
www.facebook.com/HebikiDesignWorks
Hebiki is offline   Reply With Quote
Old 06-21-2010, 08:27 PM   #1773
encore75's Avatar
Send a message via AIM to encore75
Quick question...
Are the D Parts suspension arms of the TB03 (Tamiya part 51535) the same length & design as the Short Reversible Suspension Arms (Tamiya 53928) but just in a regular plastic (not the graphite-reinforced plastic)?
Tamiya TB-Evolution V & TA05-R | Kyosho Ultima SC & RB5 | Associated FT RC18T
encore75 is offline   Reply With Quote
Old 06-21-2010, 08:41 PM   #1774
tamiyarcracer's Avatar
Send a message via Yahoo to tamiyarcracer
Originally Posted by encore75 View Post
Quick question...
Yes you are correct, as are all the other suspension parts, they are the same as the 416 parts, but made as standard plastic
tamiyarcracer is offline   Reply With Quote
Old 06-21-2010, 09:33 PM   #1775
encore75's Avatar
How much of a difference in stiffness is there between the two?
Is there enough for an occasional club racer like myself to notice...and justify paying more than twice as much for a set of the option reversible arms over the plain TB03 ones?
Also, would the plain arms be a bit more forgiving/durable due to their softer material?
Old 06-22-2010, 02:31 AM   #1776
hey there.
Starting unpacking the TB03R tonight (rims but no tire ???)
Does anyone have the part numbers for the 2 gearbox/diff bevel gears??
I think its probably a good idea to get some spares, rather than wait 3weeks if/when I break anything.
Just how strong are these bevel gears ??
Any other spares I should get? (I have spare front steering arms & C hubs)
1101 is offline   Reply With Quote
Old 06-22-2010, 01:53 PM   #1777
fat500's Avatar
Trader Rating: 29 (100%+)
gears should lasta long tome unless your running mod. I race RCGT 17.5 and beat the heck out of the car. I run a spool up front and have not broken a gear yet. shim the car per the manual and you should be ok.
fat500 is offline   Reply With Quote
Old 06-23-2010, 12:32 AM   #1778
I found the info I need for bevel gears
Parts list
http://www.rccarsrtr.com/index.php/t...arts-list.html
TB03 uses 51256 TB Evolution 5 Ball Differential Gear Set.(I hope)
So cheap I bought a spare. . I'm gonna run a 9T ezrun so i thought :Rather have & never use than the other way around.
The plastic diff looks a bit fragile (outdrives) . How well do they hold up??
Bought a metal diff for the rear, I assumed the front diff wont be under as much stress.
Old 06-24-2010, 07:33 PM   #1779
Core Creations's Avatar
Trader Rating: 93 (100%+)
Send a message via AIM to Core Creations
Tamiya TB03 Calsonic GT-R NIB Cheap!! TCS-TRF
Core Creations paint thread
Mini Mafia Kansas Chapter - where the monster minis grow!
Core Creations is offline   Reply With Quote
Old 06-25-2010, 05:47 PM   #1780
Default TB03R setup sheet :please
Hi there. The stock (as per manual) setup really looks off (camber/toe etc)
Anyone have some working setups (for 10T, indoor & outdoor) to try.
cheers
Old 06-25-2010, 06:20 PM   #1781
fat500's Avatar
my machine after raceday
Old 06-25-2010, 07:04 PM   #1782
RedBullFiXX's Avatar
Trader Rating: 34 (100%+)
Very Nice !
--> 12th scale Information Source <--
"Men do not quit playing because they grow old; they grow old because they quit playing."
― Oliver Wendell Holmes Jr.
Old 06-30-2010, 03:51 AM   #1783
So I was going to get the TB03R, but I found the Arta TB03 new at 105 dollars and couldn't resist :P Going to check what upgrades are most essential later and order some
Old 07-01-2010, 12:40 AM   #1784
You may end up better off.
I got the tb03R & still had to get upgrades !!! The PRO version & I still get bushes I need to replace with bearings..arrrgh
Definfitely upgrade the sloppy, sloppy, steering (just get bearings for it, cheap upgrade)
Seems to be alot of slop in the C-Hubs/steering arms as well.
edit: first run yesterday> it drives like a dream, much better than expected. Stock pinion was far too small (as expected). Will probhably change to 48pitch. Lots of grit on the track (after 3 weeks of rain). It would have killed the belts & spur/pinion on my Xray.
Fully enclosed gears, so just shake out the grit & keep going.
I'm thinking about getting the Carbon re-enforced tub. Is that a worthwhile upgrade??. Stock tub is pretty flexy at the ends .
Old 07-07-2010, 10:59 AM   #1785
Trader Rating: 30 (100%+)
Hey, guys,
Just got my TB03R up and running, but don't go mocking me for using mine as a drifter. Been using my EVO 5 all this time, but I must say that I really love this TB03R much much more! A friend also helped me to mod mine to fit the Yokomo FCD rear diff & drive gear.
Anyway, on to my question. Sorry, if this has been asked before, but I wasn't about to go read through a hundred some odd pages to not find my answer. My EVO5 can fit a 64P 98T spur without mods to the chassis and a 64P 100T spur with slight grinding of the chassis. However, looks like the TB03 might be able to fit the 100T spur or possibly larger without any mods. Anyone know what the biggest spur gear that will fit in the TB03? Thanks in advance!
wrxnfx is offline   Reply With Quote
Selling Schumacher Mi2, Tamiya M02, Tamiya TA04-S, Tamiya TB Evolution 3 Surikarn Ltd st_rob Australia For Sale/Trade 4 12-23-2008 06:37 PM
Tamiya 415 MSX, legacy 2.0, NIP Type A tires, Tamiya towel for sale or trade Fastburn R/C Items: For Sale/Trade 16 09-05-2008 11:45 PM
FS: Tekin Rebel 2 ESC w/ Tamiya GT Tuned Motor & Tamiya AM Radio & Receiver wrxnfx R/C Items: For Sale/Trade 6 06-10-2008 05:40 PM
Tamiya M03 / Trinity Brushes / Muchmore Battery Cooler / Tamiya M Chassis Wheels bluejays R/C Items: For Sale/Trade 2 12-16-2007 08:31 PM
Hpi rs4, tamiya tt01, tamiya tg-10, tamiya sprint! MORE!!!!! Genuinekid R/C Items: For Sale/Trade 10 09-10-2007 03:21 PM
