Old 06-12-2010, 09:24 PM   #1756
fat500's Avatar
Trader Rating: 29 (100%+)
see above post
fat500 is offline   Reply With Quote
Old 06-14-2010, 04:10 PM   #1757
fat500's Avatar
anyone have an answer to the post on the last page quiet in here
Old 06-15-2010, 02:32 AM   #1758
Send a message via MSN to jontang001
Originally Posted by fat500 View Post
has anyone tried the light wt. reversable SHORT suspension arms on their tb03? tam53928. I bought the set of four thinking that was what was on the car and BAM the stock arms are about 1.5-2mm longer. Using the short arms i think I will have to use the "C" mounts up front like the 416 does. The "A" mounts on the tb03 are too narrow to use with the short arms. anyone here play with this mod? thanks.
Hi
The arm comes with tb03 box is just the short arm that you talked about. It just a plastic one not the carbon mixed which you bought. I did my 03 to use D/D in the front and some times to use C/C to have aggrecive driving. The A is exactly too narrow. The back I aways use XA/E. When feel too lose in the corner, try XA/D or XB/D to get the same rear tole-in. Just a reference for you.
TAMIYA TRF416, EVO5MS, TB03 FullOP
Schumacher Mi4LP, CAT SXII, Cougar
jontang001 is offline   Reply With Quote
Old 06-15-2010, 02:22 PM   #1759
fat500's Avatar
ok thanks. my car had the 415 arms on it and that is why I was confused.
Old 06-15-2010, 08:58 PM   #1760
balongbalong's Avatar
can the wheelbase of the tb03 be shortened by reversing the rear suspension arms? from the standard 257 to the shorter 251 similar to the tt01 and ta05?
basing from pictures and hop up rear suspension arms, they're reversible but does not make the wheelbase shorter, correct?
balongbalong is offline   Reply With Quote
Old 06-16-2010, 03:21 AM   #1761
Ive just ordered the TB03R (& a few spares)
I want to run a EZRun 9T in it. Anything I need to do to cope with a 9T motor?? I bought the ali dif upgrade (for the rear)
Also thinking about removing the IFS & use 'normal' front suspension tower. Are the parts to do that included with it ?
Cheers
..too many broken belts/pullies on the Xray. Moving to shaftie
1101 is offline   Reply With Quote
Old 06-16-2010, 04:31 AM   #1762
Hello everyone, thanks for a great thread. I have read through most of it but I still have some information I need
First of all, some background. I recently came back to the hobby after a 15 year break. Back then I was ~15 years and ran a cheap Thunder Tiger nitro Celica.
About 2 years back I purchased a HPI E10 Drift to get back into the hobby again. Shortly after that I had 2 Tamiya TT-01 and one Tamiya DF-03Ra too.
Now I'm thinking about starting to run a little more serious car and after reading this thread I'm certain that the TB03R is the correct choice for me. I will be able to bash on parking lots, but also run tracks if I want to.
I will probably run a bl setup, so I have done some research on what I might need. (sorry for no links but not allowed to post them according to forum)
Steering upgrade, product-id=54097
Alu Motor Adapter, product-id=54054
Alu Diff Joint(rear), product-id=54056
Spool (front), product-id=54125
Alu Spur Mount, product-id=54094
None of these seems to be included in the TB03R set, so I thought they will be nice to have also. Can anyone please confirm and also tell me if some of these upgrades are unnecessary.
Thanks again for a super good thread!
/Tobias
nbla is offline   Reply With Quote
Old 06-16-2010, 06:15 AM   #1763
@ nbla / Tobias:
Concratulations! - TB03R is the best choice! I'd like to continue your list with
-Titanium Hex Screw Set Tamyia #49499 or the cheaper one from 3racing (the original Philips screw are crap!)
- TB03 reinforced Lower Deck #54147 (provides much better feeling - even better than the Carbon one from 3Racing)
- Onroad Spring set White #49382 (or those from Hot Bodies /HPI)
-Don't forget to buy tires - the kit has none included
Shqizy is offline   Reply With Quote
Old 06-16-2010, 06:39 AM   #1764
@Shqizy
Thanks for the reply
I will look in to the parts you suggested too, thanks. I was thinking about running with my 26mm X-Patterns to start with, will that work or do I need 24mm?
Old 06-16-2010, 10:21 AM   #1765
@Shqizy
Thanks for your list, I will check it out later
I was planning on running my 26mm HPI X-Pattern, is that possible or do I have to use 24mm wheels?
Old 06-16-2010, 10:25 AM   #1766
dodo's Avatar
Send a message via Yahoo to dodo
yes, correct, to make the wheelbase shorter you can play with the spacers on the hingepins to make the arm further back or front.
dodo is offline   Reply With Quote
Old 06-17-2010, 01:05 AM   #1767
Hey good thinking, I'll order some now. Hopefully all my parts will arrive same week as the car kit
Hey nbla,
There is a workaround if you want to try & save money only the steering kit, post 603 (thanks fat500). I'm going to try it
Tamiya TB-03
otherwise its 2 steering parts needed (another $42 right there).
tamiya 54095
tamiya 54097
All these 'extras' really bump up total cost !!
Old 06-17-2010, 02:22 AM   #1768
i see, so the TB03 is similar to TA05 then in terms of that regard.
do you know how much further back of front i could adjust them?
Old 06-17-2010, 03:43 AM   #1769
tamiya 54095
tamiya 54097
Thanks for the tip, I'll probably end up getting those two Fast question tho, on the Carbon Steering Link there is no mention about the Steering Set, but the Steering Set says it "can be used with 54097". Do I really need both of those from the start?
Thanks again
/Tobias
Old 06-17-2010, 06:51 AM   #1770
Thanks again
/Tobias
no you don't need both -
54097 get's you rid of most slackness
in addition you can either buy 54095 or simply replace the four bush bearings by four 850 ball bearings (there is no difference to 54095 if you have reinforced K-Parts) which is much lighter
Selling Schumacher Mi2, Tamiya M02, Tamiya TA04-S, Tamiya TB Evolution 3 Surikarn Ltd st_rob Australia For Sale/Trade 4 12-23-2008 06:37 PM
Tamiya 415 MSX, legacy 2.0, NIP Type A tires, Tamiya towel for sale or trade Fastburn R/C Items: For Sale/Trade 16 09-05-2008 11:45 PM
FS: Tekin Rebel 2 ESC w/ Tamiya GT Tuned Motor & Tamiya AM Radio & Receiver wrxnfx R/C Items: For Sale/Trade 6 06-10-2008 05:40 PM
Tamiya M03 / Trinity Brushes / Muchmore Battery Cooler / Tamiya M Chassis Wheels bluejays R/C Items: For Sale/Trade 2 12-16-2007 08:31 PM
Hpi rs4, tamiya tt01, tamiya tg-10, tamiya sprint! MORE!!!!! Genuinekid R/C Items: For Sale/Trade 10 09-10-2007 03:21 PM
