Old 04-13-2010, 05:29 PM   #1711
Originally Posted by Racecrafter View Post
RCGT spec TB03R wins the Surf City 700 3 hour endurance race yesterday!
"0" issues with the car. It went the whole distance on one set of Pro compound X patterns and handled great all day with the new ALMS M3 BMW body from Tamiya.
Yup, you guys made an impressive run with that car. It sealed the deal for me. I also noted your performance in last year's RCGT series with the TB03.
So..... look what showed up yesterday, wahoo!!!!
DM1-S Tekin 2650Kv
MTX-3 MR .12
TA05 IFS-R Tekin 17.5
TA03R Cirtix 17.5 club spec
F109 Tekin 21.5
danketchpel is offline   Reply With Quote
Old 04-14-2010, 09:09 AM   #1712
Originally Posted by LOSI123 View Post
can anybody tell me what the screws are made from in the standard tb-03 kit?
they seem like a cheap alloy?????
Ya, I'm not impressed with the screws. They are not very hard and philips type screws bugger easy if you are not super careful.
I called Tony at Tony's screws and he's in the process of putting together a screw kit for this car and it should be out shortly.
I will definitely be replacing the factory screws on this car and my TA05 IFS-R.
DM1-S Tekin 2650Kv
MTX-3 MR .12
F109 Tekin 21.5
Old 04-14-2010, 01:43 PM   #1713
The Surf City 700 Winning TB03R and the four man crew who piloted it to Victory!
Gil Losi Jr. / Chris (Birthday Boy) Vierra / Me / Pres Ilog
Jimmy, it this the same M3 body that comes with the TT01 chassis? Is that the kit wing?
DOTMAN is offline   Reply With Quote
Old 04-17-2010, 02:54 PM   #1714
Nice kit man...! I didnt know the existence of the R version..
If I knew it before I would buy it , at the end my chassis will end looking like the R version..
Ok , I am in the building process of my TB03 chassis (normal version), all ok the quality of the kit is fine and I love the design of this chassis but have find some rare problems...
-Is normal the amount of side to side play of the differentials inside of its housing..? the originals shims are not enought to correct it , I have had to order more 10mm shims.
-Is normal the play of the wheel axels...? I move the wheel with my hand and I can see the external point of the wheel moves about 2mm (inside-out movement)
the wheel nut is tigh , the play comes from the bearings inside the hub .... too loose Tamiya bearings....? the play is on all the 4 wheels.
When I turn the wheels they move like crazy.
-The screws are really tight on the plastic parts...! I will have to order an hex screw kit beacuse my screwdriver have already torn several heads.
Thanks for your advices....!
danieluki is offline   Reply With Quote
Old 04-17-2010, 06:13 PM   #1715
Hawk6's Avatar
Trader Rating: 50 (100%+)
[QUOTE=danieluki;7284720]
QUOTE]
When I bought my first Tamiya kit, the owner of the hobby shop (some guy named Scotty Ernst) recommended I buy a Tamiya screwdriver. I did and I've never had problems with Tamiya screws. Apparently, metric phillips screws are different than standard ones. And, it's great only having to have one tool (the screwdriver) rather than several hex wrenches.
Hawk6 is offline   Reply With Quote
Old 04-17-2010, 06:42 PM   #1716
Got a question for one of you Tamiya experts.
What is the difference between the Flourine Shocks and the Hard Black Coating shocks?
If you had a choice which would you go with?
Any info would help.
Freezer7676 is offline   Reply With Quote
Old 04-18-2010, 12:06 AM   #1717
A Ilievski's Avatar
Trader Rating: 39 (100%+)
Hey guys
Have a few questions regarding the TB-03R.
- What is the internal ratio of the car?
- What additional hop ups are required?
I was thinking
- spool
- alloy spur gear adapter
- alloy diff halves
- alloy blue motor mount
- alloy/bearing steering system
- How does it handle being like the TA-05 with inclined front shocks?
- Any weak points of the car?
Alex
Alex Ilievski
*AWESOMATIX * R1 WURKS * PLAIG BEARINGS*
A Ilievski is offline   Reply With Quote
Old 04-18-2010, 03:42 AM   #1718
Bundy_Bear's Avatar
Hi
I have just ordered myself a new Tamiya TB03R, looking forward to building it when it arrives. I was impressed with my Girlfriends M03 i built for her last year.
MissMooRC Racing
Find us on Facebook https://www.facebook.com/missmoorc
Bundy_Bear is offline   Reply With Quote
Old 04-18-2010, 06:13 PM   #1719
RandomFellow's Avatar
Originally Posted by kid TT-01 View Post
Hey guys
Alex
2.438
RandomFellow is offline   Reply With Quote
Old 04-18-2010, 06:15 PM   #1720
The Hard Black shocks have a different coating on the outside, but I think it's still flourine on the inside. They also come with titanium coated shock shafts. The hard black shocks are the latest, greatest ... definitely the way to go.
Old 04-19-2010, 06:32 AM   #1721
Trader Rating: 114 (100%+)
What were the electronics used?
Chris Furman is offline   Reply With Quote
Old 04-19-2010, 01:30 PM   #1722
Racecrafter's Avatar
Trader Rating: 25 (96%+)
Yes it is.
I actually purchased a TT01E kit to get the body and light kit.
That is the kit wing. Though we used the RCGT legal Lexan wing in competition.
Jimmy Wright
www.trackstarrc.com ~ www.facebook.com/TrackStarRC ~ Home of the 2x's Stock Nationals Champion TS-Gold & TS-Black tire sauce, TS-1+ lubricants, TS-Precision bearings, XRG Xtreme Racing Grease, Scale Auto Engineering, ElevenTech, WRD2, Carbon 12, Stiff Products
Racecrafter is offline   Reply With Quote
Old 04-19-2010, 01:33 PM   #1723
KO Propo 2345 ICS servo
Tekin RS ESC
Fantom 17.5 motor
Fantom Lipo batteries 3200-5000mah 40C
Jimmy Wright
Old 04-19-2010, 01:49 PM   #1724
Tekin RS ESC
Fantom 17.5 motor
With RCGT were you allowed to use v203?
Old 04-19-2010, 02:19 PM   #1725
Hey guys
I was thinking
- spool
- alloy diff halves
Alex
I just finished building my TB03R and here's what I'd do:
- spool
Got it but haven't run it yet, running the front diff for now
- alloy diff halves
Yes for sure
Yes for sure
I'd skip this as it doesn't help anything and you can't see it. The stock piece is precision cast aluminum and does the job well.
What is MORE important is the little motor adapter that is part of the motor mounting system. It should be upgraded for sure as it's plastic. The part number is 54054
Yes for sure. Make sure to include the carbon steering link as the plastic link uses bushings and the fit is super sloppy.
I upgraded the front shock rocker arms to the aluminum ones with ball bearings. I'd rate that as important just to get the ball bearings in addition to the reduced flex in the arms.
I did the upgraded prop shaft but I'm not sure it's super necessary. The stock shaft is OK. The only weak part is the plastic pin/clips that holds the drive cups to the diff input shaft. The upgraded shaft kit(s), it requires two kits for the complete install, uses hard pins and an O-ring to hold them in. The upgraded shaft uses a CVD style joint at the front and dogbone at the rear. The prop shaft kits also include aluminum input shafts which does help reduce rotating mass helping acceleration. My prop shaft was bent right out of the bag so I had to straighten it, not cool. I would have exchanged it if I'd had more time.
As for the handling, I have a TA05 IFS-R and I think it's very similar, maybe a bit better. I used a similar chassis setup to my TA05 to start with and now I need to fine tune it.
I didn't see any particular weak points other than what I mentioned. I still plan to upgrade the screws as I'm not a fan of philips head screws.
Some people like the upgraded rear shock tower as it's stiffer and moves the body posts out further to make the body more stable on the chassis. Maybe something to consider for the future.
DM1-S Tekin 2650Kv
MTX-3 MR .12
F109 Tekin 21.5
Selling Schumacher Mi2, Tamiya M02, Tamiya TA04-S, Tamiya TB Evolution 3 Surikarn Ltd st_rob Australia For Sale/Trade 4 12-23-2008 06:37 PM
Tamiya 415 MSX, legacy 2.0, NIP Type A tires, Tamiya towel for sale or trade Fastburn R/C Items: For Sale/Trade 16 09-05-2008 11:45 PM
FS: Tekin Rebel 2 ESC w/ Tamiya GT Tuned Motor & Tamiya AM Radio & Receiver wrxnfx R/C Items: For Sale/Trade 6 06-10-2008 05:40 PM
Tamiya M03 / Trinity Brushes / Muchmore Battery Cooler / Tamiya M Chassis Wheels bluejays R/C Items: For Sale/Trade 2 12-16-2007 08:31 PM
Hpi rs4, tamiya tt01, tamiya tg-10, tamiya sprint! MORE!!!!! Genuinekid R/C Items: For Sale/Trade 10 09-10-2007 03:21 PM
