Old 03-25-2010, 04:29 AM   #1696
the last
Tamiya TB-03-immagine-058.jpg   Tamiya TB-03-immagine-056.jpg   Tamiya TB-03-immagine-055.jpg   Tamiya TB-03-immagine-054.jpg
mtaddei is offline   Reply With Quote
Old 03-25-2010, 10:12 AM   #1697
rcwanaB's Avatar
Trader Rating: 14 (100%+)
Default TB-02 cnversion
Starting off I am not all that familiar with Tamiya on road cars. My buddy was given a TB-02 subaru and he is trying go VTA racing with this chassis. Its brand new, and to me it looks very similar in design to a Assoc. tc3-4 and should work fine but the first problem we are running into is gearing. We want to run a brushless motor and at our local track im seeing various cars with a FINAL drive ratio ranging from 3.8-3.3 when running 1cell lipo & 17.5 brushless. Unless im reading the manual wrong the closest we can get is 5.72 or around that. I have seen a TB-02 to TB-03 conversion kit for 90 bucks is this what im looking for? It looks like the motor mount in that kit is the slideing adjust type. Can i switch to 64 pitch gearing with that? Can this car be converted with out spending a fortune? Ive seen the 415,416 cars and they look bad a-- but $400+ is not an option right now. Any help is greatly appreciated.
rcwanaB is offline   Reply With Quote
Old 03-25-2010, 09:38 PM   #1698
Default Noise in Front End?
Hello, I recently completed a TB-03D kit, with the non-IFS front suspension. It is a very smooth running car. However, I'm noticing a high pitch 'squeak' coming from around the front wheel axle assemblies that increases in severity when the wheels are turned left or right. Installed are the Tamiya front on-way unit with 42mm dog bones.
What might be causing this noise, and is it normal for this setup? I'm new to Tamiya cars. Thanks to everyone for any help.
VeryGiantPanda is offline   Reply With Quote
Old 03-26-2010, 12:37 AM   #1699
Ciao, when you are building the tb03 you must pay attention to coupling the transmission pinion shaft with the diff. If too much play between pinion and diff you can have lot of problems. You must assembly the diff case with diff and pinion, then check the transversal clearance of the diff, the if more of 0,2 or 0,3 mm you must shim the diff in order to reduce such clearance.
Anyhow if you check previous post there is one of Timmie that explain it much better then me.
Ciao
Max
Old 03-29-2010, 03:33 PM   #1700
Default RE: Noise in front end
Since the squeaking noise from the front end of my TB-03D did not improve after running thru a battery pack, I investigated further and found it was coming from the area where the wheel axle, 1050 bearing, and part C1 (inner) meet. Sprayed some lithium grease on this area for both the left & right, and voila, noise gone!
When I get the chance to replace the front dog bones with universal shafts I'll check to make sure the bearings aren't already going bad. Don't know what quality of bearings Tamiya includes in these kits.
Old 03-29-2010, 10:09 PM   #1701
Racecrafter's Avatar
Trader Rating: 25 (96%+)
RCGT spec TB03R wins the Surf City 700 3 hour endurance race yesterday!
"0" issues with the car. It went the whole distance on one set of Pro compound X patterns and handled great all day with the new ALMS M3 BMW body from Tamiya.
Pictures coming soon!
Jimmy Wright
www.trackstarrc.com ~ www.facebook.com/TrackStarRC ~ Home of the 2x's Stock Nationals Champion TS-Gold & TS-Black tire sauce, TS-1+ lubricants, TS-Precision bearings, XRG Xtreme Racing Grease, Scale Auto Engineering, ElevenTech, WRD2, Carbon 12, Stiff Products
Racecrafter is offline   Reply With Quote
Old 04-01-2010, 03:09 PM   #1702
Ciao Timmie,
last week end as i told you i raced the first round of the italian championship, the race was on carpet surface, permanent track with very high grip, tire additive on full tire surface both on front and rear tire.
I used the 3racing chassis, very bad choise, too rigid eith the consequence that i was 2 seconds slower than 2 weeks before when i was there to make some tests with the original chassis, next time (i don't know when) i'll test it on asphalt and i hope to have a better result.
Ciao
Max
Old 04-01-2010, 09:49 PM   #1703
The Surf City 700 Winning TB03R and the four man crew who piloted it to Victory!
Gil Losi Jr. / Chris (Birthday Boy) Vierra / Me / Pres Ilog
Jimmy Wright
Old 04-07-2010, 06:41 PM   #1704
Waltrip55's Avatar
^^^great looking TB-03
This weekend I will be racing my TB-03D at Trackside for the TCS event. I feel really competitive in GT-1 and I can't wait to see what happens! My brother and best friend will be racing their TB-03D's too. I feel this will be my best run since I started racing TCS in 2006. I'll give the update after the weekend!
Brett Steller <><
HPI Blitz ESE 17.5--HPI Blitz 17.5(wife's)--Tamiya TT-01R--Tamiya TB-01 Rally (retired)
Waltrip55 is offline   Reply With Quote
Old 04-08-2010, 05:21 AM   #1705
LOSI123's Avatar
Trader Rating: 63 (100%+)
can anybody tell me what the screws are made from in the standard tb-03 kit?
they seem like a cheap alloy?????
will the titanium screw kit be a weight saving, as the original ones dont seem like steel.
LOSI123 is offline   Reply With Quote
Old 04-08-2010, 06:51 AM   #1706
The screw supplied with the kit are of first steel quality phillips type, personally i prefer the hex type.
Ciao
Max
Old 04-08-2010, 03:17 PM   #1707
LOSI123's Avatar
thanks max.
Does anyone know how many grams weight ill save approx , by changing to titanium screws and also titanium turnbucks as well.
Old 04-12-2010, 12:40 PM   #1708
encore75's Avatar
Trader Rating: 26 (100%+)
Send a message via AIM to encore75
Hey Tamiya-heads,
How does the TB-03R compare to a TB-Evo V (non-MS version)? I was thinking of getting a TB03R, but came across a good deal on a used Evo V and considering picking it up...I would be using it for the stock 17.5T (outdoor asphalt) class as an alternative to my TA-05R.
Are parts hard to come by for the Evo V? Any major weaknesses in the Evo V? My only experience so far with Tamiya on-road has been with a TT-01 and my current TA-05R.
Thanks in advance!
Tamiya TB-Evolution V & TA05-R | Kyosho Ultima SC & RB5 | Associated FT RC18T
encore75 is offline   Reply With Quote
Old 04-12-2010, 02:05 PM   #1709
thanks max.
Ciao Losi,
i don't know, but i'm thinking that the difference is not so much.
ciao
Max
Old 04-12-2010, 04:55 PM   #1710
Waltrip55's Avatar
Originally Posted by encore75 View Post
Hey Tamiya-heads,
Thanks in advance!
The Evo V is a much better car overall. The only advantage the TB-03 has are its sealed spur/pinion for outdoor racing. The TB-03 has an Evo V drivetrain and is meant to be more entry level. That said, I finished 4th in GT-1 at the Trackside TCS this weekend against Evo V's and 416's. Should have finished 3rd overall but got in a late wreck in the final main.
Brett Steller <><
Selling Schumacher Mi2, Tamiya M02, Tamiya TA04-S, Tamiya TB Evolution 3 Surikarn Ltd st_rob Australia For Sale/Trade 4 12-23-2008 07:37 PM
Tamiya 415 MSX, legacy 2.0, NIP Type A tires, Tamiya towel for sale or trade Fastburn R/C Items: For Sale/Trade 16 09-06-2008 12:45 AM
FS: Tekin Rebel 2 ESC w/ Tamiya GT Tuned Motor & Tamiya AM Radio & Receiver wrxnfx R/C Items: For Sale/Trade 6 06-10-2008 06:40 PM
Tamiya M03 / Trinity Brushes / Muchmore Battery Cooler / Tamiya M Chassis Wheels bluejays R/C Items: For Sale/Trade 2 12-16-2007 09:31 PM
Hpi rs4, tamiya tt01, tamiya tg-10, tamiya sprint! MORE!!!!! Genuinekid R/C Items: For Sale/Trade 10 09-10-2007 04:21 PM
