Old 12-20-2009, 10:59 PM   #1516
SoCalGuy's Avatar
Thanks Redbones. I appreciate your insight.
Anyone else out there with some helpful suggestions, please feel free to chime in!
SoCalGuy is offline   Reply With Quote
Old 12-21-2009, 04:35 AM   #1517
berserk's Avatar
I suggest that you install a spool instead of the differential at front. and be careful not to forget the shims in the shaft . also try to look on the previous pages for the parking lot setup of timmie. it really works well on low traction parking lot surfaces.
berserk is offline   Reply With Quote
Old 12-21-2009, 11:16 AM   #1518
Hebiki's Avatar
Trader Rating: 26 (100%+)
Regarding upgraded TRF shocks:
Please suggest a good starting weight for the oil (will probably start with the 3 hole piston as recommended), and any hints you may suggest in their assembly.
Thanks in advance; I appreciate all the good advice!
use the tamiya 400 weight oil (approx. 40wt). ive always been told 3 hole pistons for asphalt/rubber racing.
Hebiki Design Works
Custom R/C Vinyl Graphics & Apparel: Your gear, your way!
Web Design - Web Development - Logo Design - Graphic Design
www.facebook.com/HebikiDesignWorks
Hebiki is offline   Reply With Quote
Old 12-21-2009, 12:27 PM   #1519
SoCalGuy's Avatar
Thanks guys for the great advice I should probably take a little trip to the track here in Camarillo and see what the locals have to say.
Regarding the suspension mounts (1XD, 1F, etc...), there seems to be dozens of flavors of them. What would be a good starting set to use, and where can I get more information on their differences?
Thanks again for your time, and thanks for your patience with another Noobie!
Old 12-21-2009, 01:39 PM   #1520
Racecrafter's Avatar
Trader Rating: 25 (96%+)
The stock blocks work the best for the TB03.
If you are using the TRF shocks go with 400 and two hole or 600 with three hole pistons to start.
List what hop ups you have purchased and I can better help you with a set up.
Jimmy Wright
www.trackstarrc.com ~ www.facebook.com/TrackStarRC ~ Home of the 2x's Stock Nationals Champion TS-Gold & TS-Black tire sauce, TS-1+ lubricants, TS-Precision bearings, XRG Xtreme Racing Grease, Scale Auto Engineering, ElevenTech, WRD2, Carbon 12, Stiff Products
Racecrafter is offline   Reply With Quote
Old 12-21-2009, 02:14 PM   #1521
SoCalGuy's Avatar
Thanks Jimmy; Here ya go...
All Tamiya part numbers:
53993 Aluminum Rocker Arm Set
53999 Rocket Nut
42102 TRF Special Damper Set
54052 Aluminum Propeller Shaft
54053 Aluminum Propeller Joint
54094 Aluminum Spur Gear Mount
53500 Universal Assembly Shaft Cross Joint
54076 Wheel Axles
54077 Aluminum 44mm Swing Shafts
54054 Aluminum Motor Adapter
54150 Aluminum Motor Mount
54056 Aluminum Diff Joints
51000 Servo Saver
54095 Aluminum Racing Steering Set
54097 Carbon Steering Link
54121 Aluminum Servo Saver Horn
Futaba BLS551 Servo
Castle Creations Mamba Max Pro w/ 5700kV brushless motor
(a bit concerned the stock gearing may not be correct for above motor)
Spektrum DX3R Radio with SR3520 Receiver
Have yet to decide on a good lipo battery
I may not be able to drive worth a darn, but it will sure look cool
Thanks again!
Don
Old 12-23-2009, 02:51 PM   #1522
Waltrip55's Avatar
Im debating if I should run GT-3 or GT-1 with my TB-03D I'm about to get for TCS. What spur/pinion do you recommend for a 13.5 (to get around a 4.5 fdr) and for a silver can in GT-3? Also, what is the internal ratio? Thanks!
Brett Steller <><
HPI Blitz ESE 17.5--HPI Blitz 17.5(wife's)--Tamiya TT-01R--Tamiya TB-01 Rally (retired)
Waltrip55 is offline   Reply With Quote
Old 12-23-2009, 03:20 PM   #1523
Ciao Waltrip55,
the internal ratio is 2,348, which kind of spur are you using pitch 48 or 64?
ciao
Max
mtaddei is offline   Reply With Quote
Old 12-23-2009, 03:27 PM   #1524
Waltrip55's Avatar
I would like to run 48p...but I wouldn't mind either one. Which ever one is easier to get to 4.5 fdr.
Brett Steller <><
Old 12-23-2009, 03:28 PM   #1525
Hebiki's Avatar
Originally Posted by mtaddei View Post
Ciao Waltrip55,
ciao
Max
its actually 2.438
Hebiki Design Works
Old 12-25-2009, 12:30 AM   #1526
Waltrip55's Avatar
Ive done some math and a 52t spur with a 28t pinion would work...a 55t spur and a 30t pinion would also work. I've also worked out a few 64p combos...but I'm not sure if any would fit. Would the two above combinations fit properly?
Brett Steller <><
Old 12-25-2009, 03:18 AM   #1527
Trader Rating: 4 (83%+)
Does anyone happen to know what type of shocks are on the TB03D and what springs will fit it? I bought some Tamiya Soft Red Springs but they require huge spacers because they leave a massive gap in the shocks. What size are they?
DriftWoof is offline   Reply With Quote
Old 12-25-2009, 02:29 PM   #1528
dodo's Avatar
Send a message via Yahoo to dodo
these are the short springs. you should get the normal red springs instead.
the short ones are more suitable if you run it for m-chassis cars.
CMIIW
dodo is offline   Reply With Quote
Old 12-25-2009, 04:04 PM   #1529
Where do I get the normal red springs?
Old 12-25-2009, 04:27 PM   #1530
CSaddict's Avatar
I run Reds on the rear of mine and they are quite long compared to M03 springs. They came in the 53440 hard on road spring set.
TLR 22
Losi SCTE
Blitz Open
Xray T3 RCGT
www.rcmadness.freeforums.org
CSaddict is offline   Reply With Quote
Selling Schumacher Mi2, Tamiya M02, Tamiya TA04-S, Tamiya TB Evolution 3 Surikarn Ltd st_rob Australia For Sale/Trade 4 12-23-2008 07:37 PM
Tamiya 415 MSX, legacy 2.0, NIP Type A tires, Tamiya towel for sale or trade Fastburn R/C Items: For Sale/Trade 16 09-06-2008 12:45 AM
FS: Tekin Rebel 2 ESC w/ Tamiya GT Tuned Motor & Tamiya AM Radio & Receiver wrxnfx R/C Items: For Sale/Trade 6 06-10-2008 06:40 PM
Tamiya M03 / Trinity Brushes / Muchmore Battery Cooler / Tamiya M Chassis Wheels bluejays R/C Items: For Sale/Trade 2 12-16-2007 09:31 PM
Hpi rs4, tamiya tt01, tamiya tg-10, tamiya sprint! MORE!!!!! Genuinekid R/C Items: For Sale/Trade 10 09-10-2007 04:21 PM
SEO by vBSEO 3.5.0
