Old 02-19-2014, 07:08 AM   #256
Rodarbal's Avatar
Trader Rating: 36 (100%+)
Send a message via Yahoo to Rodarbal
Bumpin fo life...
Here's a bracket I made to mount my Tamiya Mini Cooper body to my Genetic without drilling new holes:
RJ Labrador
On Road: Tamiya & XRay
Off Road: Losi, Mugen & XRay
Rodarbal is offline   Reply With Quote
Old 02-19-2014, 07:19 AM   #257
Trader Rating: 25 (96%+)
well done RJ, very professional looking... I like the looks of that A-Spec 4.2A and Speed Passion 25.5T too!
billdelong is offline   Reply With Quote
Old 02-19-2014, 07:27 AM   #258
Rodarbal's Avatar
Thanks, Bill! Man, I'm so anxious to run this thing! Can't wait for my gears to show up!
RJ Labrador
Old 02-19-2014, 06:09 PM   #259
macavant's Avatar
Trader Rating: 62 (100%+)
It will be like a JL10E with better steering, quicker response, and built like a tank.
likes the oldskool RC action...
F103.F201.F103GT.F1R3☆F104WGP.F1Ultra☆M01.M05.YR4MSe.TA05.XV-01Pro.ABC_Genetic(Exotek)☆microRS4-Motek☆TA02SW☆WR02.CC-01☆TRF201☆TRF417X.TRF101.TRF101W
macavant is offline   Reply With Quote
Old 02-20-2014, 06:50 AM   #260
mkiiina's Avatar
Trader Rating: 69 (100%+)
Anxious to see how you do with her RJ! Glad to see its going to turn a wheel in anger again
mkiiina is offline   Reply With Quote
Old 07-16-2014, 04:17 AM   #261
32819toon's Avatar
Anyone still racing the ABC Genetic Mini ?
I bought one and gave it a first outing last Sunday on a low grip outdoor track. I used stock set up with the rear diff loosened a bit. Rear end grip wasn't good as per earlier posts here. I've since put softer springs on the rear shocks and expect better performance next time.
Here are some photos. It has a shorty lipo, held in with Mardave battery holders. I couldn't get the stock ones to fit without taking off so much plastic that they would likely break. It has a HPI Mini bodyshell.
The car came with the Mugen body which I don't need and is for sale if anyone is interested.
ABC Hobby Genetic (4wd Touring Mini)-img_20140714_083800342.jpg   ABC Hobby Genetic (4wd Touring Mini)-img_20140714_083747825.jpg   ABC Hobby Genetic (4wd Touring Mini)-img_20140714_083830718.jpg   ABC Hobby Genetic (4wd Touring Mini)-img_20140714_083821440.jpg   ABC Hobby Genetic (4wd Touring Mini)-img_20140627_181042627.jpg
32819toon
VBC Wildfire D08, Yokomo BD7 RS, Schumacher Atom, Tamiya M03, M05 (outdoor Mini), M03RWD, MF01-X, BSR M-Rage, ABC Gambado, Associated TC4 (outdoor car).
32819toon is offline   Reply With Quote
Old 07-16-2014, 05:46 AM   #262
We have a couple of Genetics currently in use at our local track here in Austin. We are in the process of merging the defunct Cup Racer class into a new M12 class.
Old 11-07-2014, 07:01 PM   #263
I'm looking into tire and wheel options for my Genetic (still painting the body).
I won't likely be doing any racing, but i'd like to have 3 sets: Grippy, General Purpose, and Drift.
Where would the stock tires fall in regards to being grippy/loose? And can you guys recommend any other tires that compliment them? Thanks!
Nixzero is offline   Reply With Quote
Old 11-07-2014, 09:58 PM   #264
I've tested about a half dozen different brands of tires and nothing has come close to both the performance and durability of RiDE tires, they also make the thickest tread of any tire I've tested too which explains why they provide the longest tire wear too. I've found that the Hard compound on front and Medium compound on rear work best for me. Here is a demo with that tire combination on an outdoor parking lot track here:
http://www.rcmart.com/ride-3027-mini...?cPath=35_1386
http://www.rcmart.com/ride-3035-mini...?cPath=35_1386
+ YouTube Video
Old 11-08-2014, 05:05 AM   #265
Rodarbal's Avatar
Originally Posted by Nixzero View Post
IWhere would the stock tires fall in regards to being grippy/loose?
Compared to the Ride tires Bill mentioned, or even any of the Sweep compounds for that matter, the stock tires are quite hard.
RJ Labrador
Old 11-08-2014, 11:09 PM   #266
firefoxussr's Avatar
Originally Posted by RC MARKET View Post
Active Lotus but not fit
fit Active A210SS mini kit only !
I want this shell badly. Anyone know where to find one?
firefoxussr is offline   Reply With Quote
Old 11-14-2014, 09:10 AM   #267
Default ABC Genetic Front axle
Does anyone know if a solid front diff unit from a TC4 will work in a genetic? The gear itself seems identical.
matrat611 is offline   Reply With Quote
Old 11-14-2014, 09:55 AM   #268
Rodarbal's Avatar
I have my doubts that it would, considering the TC4 was constructed with SAE imperial hardware and dimensions, not metric.
RJ Labrador
Old 11-15-2014, 02:18 AM   #269
OK thanks. I just see how they both have same internal gear ratio, so I was wondering. I have the one way unit now, but I just ordered my second Genetic and wanted to put something different in it. I like the one way except for when you hit the brakes the car spins out. Wish they still had that aluminum solid axle for it, if anyone has one they want to sell let me know (pm)
Old 11-15-2014, 07:30 AM   #270
If having a front spool is that important, then I would consider running a Nanda NRX-12, it comes loaded with upgrades and includes a front locked spool in the kit. I was able to reverse the arms, thus extending the wheelbase from stock 210mm to about 220mm on my NRX-12 and was able to squeeze a 225mm body to fit without much effort. I feel that my NRX-12 performs significantly better than my Genetic and my Genetic is fully loaded with most upgrades including a front spool. I feel that a 220mm wheelbase is an excellent tuning option to balance between most other mini wheelbase options on the market. Here is what you can expect with a NRX-12 running a brushed Axial 27T motor, note that the red car I was chasing down was a 21.5T USGT car and the car that chased me down was a 5.5T Mod TC:
+ YouTube Video
1:10 Mini (i.e Tamiya M-03, ABC Genetic) Race Tyres TOA57Y Electric On-Road 1 05-04-2008 05:43 PM
ABC Hobby Mini Genetic AWD Shaft Drive Mini w/ Hopups wrxnfx R/C Items: For Sale/Trade 34 12-08-2007 03:15 PM
ABC HOBBY GENETIC MINI 1/10 Chassis Kit (NIB) RamFit R/C Items: For Sale/Trade 0 10-30-2007 05:48 PM
ABC Hobby Genetic Kit! Alfie R/C Items: For Sale/Trade 2 05-06-2007 09:55 AM
WTB - ABC Hobby Genetic old-man Singapore R/C Racers 2 09-27-2006 05:27 PM
