Losi Xcelorin Brushless
#121
Just a heads up to those of us out there switching from a Novak brushless to the Losi sensored system. I have had nothing but trouble with the new losi 6.5 brushless system. It runs intermitten the truck goes 5' then stops then five more and the same thing happens. The ESC gives a 214 read error. So horizon sent me out a new at my cost (still waiting for refund) and the truck acts the same way. Today their telling me that my Jr z8800s servo draws to much power and that's why my brushless won't run, and that I need to add a BEC board. Supposedly the novak produces more amps for higher spd/torq servosthen does the Losi. So the choices seem to be spend more cash for the BEC, or upgrade to the new Jr z9100s (uses less amps), or stay with Novak. Anyone else having this problem?
#131
Yep we tried a cap. and a 9100s and it was working fine, we were at the track on monday and Tim was helping us with it, we tried a new receiver, servo, capacitor. and we had no luck, so horizon said to a a novak BEC board because that is what one of their tech guys did with the same servo and it worked.
Alex
Alex
#132
Ron, YGPM.
#133
Matt, first off thank you for your help over the last couple of weeks. I understand that it's tough to enjoy your day racing when everyone else wants your assistance. We will be out his weekend it's SS I know Alex would like to race. We should also be there wednesday night running mini's we'll bring it with us in case you happen to be there. If not we'll see you this weekend. Once again thanks. Doug
#134
Yesterday we tried several different servos (airtronics 94357, 94358, jr z270, futaba s9451). we had the same results with all execpt the futaba. Now the system runs but the speed isn't consistent it goes fast for a lap or so then it slows down for a short distance then the speed will pick back up. But it never completely stops it just acts as if the truck is dragging dead weight. Maybe we're getting closer least we can get lap or so before it slows.
#135
A strange issue I've had is that changing the Timing on the ESC does not seem to change anything. Even sitting on the bench with a 0-deg to 8-deg timing change, the motor spins the same RPM's, nor do I notice any difference on the track. I've confirmed the Timing change on the ESC with the Quick Program Card on the PC Interface, and the timing reads exactly as set with the Card. With a Novak motor you can manually adjust the timing ring and hear the motor change RPM's while moving it, and you can see the difference on the track times too. Why when changing the timing on the Losi ESC electronically does this not have the same effect?
