4mm gold banana connectors
Anybody knows where i could find some of them but the best quality?
I just picked up some from NexusRacing.com:
Gold Plug 4mm - M 3pcs (fits Orion LiPo) http://nexusracing.com/product_info.php?products_id=851 Price = $3.95 These are from Orion, and are some of the better one. Nexus has a few others to choose from as well if you don't like the Orion plugs. |
or T-Bang.ca $1.50 for 2pc. (One Pair).
Shawn. |
http://www.onlybatterypacks.com/items.asp?db=14
2mm Gold Power Plug Connector 2 pair- 2 male & 2 female included Low Resistance: Gold Plated Amperage Rating: 30 Amps Maximum Wire Size: 16awg $2.50 A lot of stuff there.... |
Thanks guys.
These right here are the best I have seen. Super thick gold plating. The only thing about these is the wire has to be soldered from the top. They dont have the cut out that dips down on one side if you need to solder your wire horizontally.
Soldering those isn't hard. Might actually hold better.
Originally Posted by jla8874
(Post 4408225)
