TB-03 IFS
That's pretty cool. I raced my old TB-02 for two race seasons, and now my 13 year old brother runs it. I wonder if they fixed the bevel gear issue
Is that a TA05 tub? It looks like they've switched the drive train on the 05IFS for the shaft drive of an EVO? Have to see one before I buy one.
Hmm, T05 geometry in a TB02, could be nice running.
Looks like the battery and motor have been switch around, but that shouldn't effect the handling much?
I gather it's based on the Evo V drivetrain, as the TB-02 was from the Evo III at the time.. why make new parts?
If that's the case, you won't have to worry about the bevel gears.. I know a few people with Evo IV/V's who have to replace the spur gear more often after a hit, because the rest of it is so solid! The 02's bevel issues were the main reason I went to a TA-05, that damn shaft was never long enough. Use the one way, be sure to have a spare gear handy the next heat..
It was also on the heavy side compared to the TA-05, I'm sure it'll be a bit lighter with this new design and all the LWS components on it.. very TA-05 like..
Plus, They aren't making the same mistake as before with custom spurs and fixed motor placement.. what a pain in the A$$ that was!!
It should be a contender in GT-2...if you can gear it low enough. That's why I went with the TA-05R, I can gear it low enough for a 13.5.
am i missing something?
is the ifs suspension supposed to be an improvement in handling?
or is all the praise going to the low drag drivetrain with a more reliable ring gear?
As for the drive train, never driven an EVO so I can't say, I do have a hopped up TB02 and will say I prefer the belt drive. Anyone else want share their insights.
Either way, I'm looking forward to adding it to the fleet.
Its more of a scale thing. With traditonal stand up shocks the tower is too high to run bodies like the one pictured. It is commonly known that if you put a cantilever they won't work as well. Its not new technology; all the rc car engineers are aware of the cantilever system, but for Tamiya fans often scale is more important and something to tinker with.
Tag
