Old 11-07-2002, 09:09 AM   #1426
Default need part # urgently...pls help
i just know the number that is on the manual...i need to order these stuffs so part# would be helpful
MK4 - Suspension arm block A
MK3 - Suspension arm block B
ML4 - rear stabilizer (soft red)
ML5 - rear stabilizer (medium yellow)
ML6 - rear stabilizer (hard blue)
fReShJiVe is offline   Reply With Quote
Old 11-07-2002, 09:26 AM   #1427
Vic
Vic's Avatar
Hi,
I have them privately.
I am located in Europe, if that helps.
Bye
Vic is offline   Reply With Quote
Old 11-07-2002, 03:38 PM   #1428
rccarracer's Avatar
Default Re: need part # urgently...pls help
Check the back page of your manual, it will list the part# there.....
rccarracer is offline   Reply With Quote
Old 11-07-2002, 08:47 PM   #1429
Default Re: Re: need part # urgently...pls help
could u help me in looking for the parts number on the back page....as i dont have the original manual...only a photocopy of it
thanks
Old 11-07-2002, 09:03 PM   #1430
rccarracer's Avatar
This is from the original 414M.....however same as all 414M cars, with exception to the WRC 414M.
Rear Stabilizer set - 9805737
Suspension Block A - 3454073
Block B - 3454074
Block C - 3454075
Block B in the WCR 414M is different.....
It's part# is 3454156.
Hope this helps.
Old 11-07-2002, 09:14 PM   #1431
thnaks rccarracer,
by the way what's the diif between the WCR B-block with the normal 414 B-Block???i did the surikarn mod myself so i would like to know if i could use that part
thank
really appreciate your help
Old 11-07-2002, 09:27 PM   #1432
reflekt's Avatar
Send a message via AIM to reflekt
it's anodized blue.....
reflekt is offline   Reply With Quote
Old 11-07-2002, 09:38 PM   #1433
rccarracer's Avatar
The WCR B Block has the slot twice a wide as the original one as the WCR block is mounted upside down.....
Old 11-07-2002, 10:51 PM   #1434
reflekt's Avatar
n/m..... ..............
Old 11-07-2002, 11:05 PM   #1435
imataquito's Avatar
Send a message via ICQ to imataquito Send a message via Yahoo to imataquito
HUH???? pics anyone?
imataquito is offline   Reply With Quote
Old 11-07-2002, 11:09 PM   #1436
reflekt's Avatar
question!
does this paint work for lexan bodies? i'm assuming so? it says "for clear bodies". so i guess it works for our lexan bodies??? cuz if it does, omg ....tamiya has the dopest colors available! forget pactra!
http://shopping.rcmodel.com.hk/eshop...exd.asp?id=510
i thought these paints wont work for lexan??? peace.
-reflekt
Old 11-07-2002, 11:11 PM   #1437
reflekt's Avatar
omg! i did some research, and these paints DO work! woooo hooo. awesome...
-reflekt
Old 11-07-2002, 11:32 PM   #1438
rccarracer's Avatar
Polycarbonate = Lexan
Tamiya paint is by far the best you can find in a can!!
Old 11-07-2002, 11:39 PM   #1439
rccarracer's Avatar
OK, let me explain.....this will get complicated, but bare with me.
As you all know the WCR 414M is a replica of Surkarn's winning worlds car, right? Well not exactly.....
On his car he raise his suspension blocks around 4.5-6mm, depending on which block you talk about. On the WCR 414M, they are only raised 2-3mm....got it?
Now on the WCR 414M, Block B is mounted like all other 414Ms, but with larger spacers under them.
To use the set up of Surikarn, Block B has to be flipped in order to clear the belt. And in doing so the "slot" where the belt runs through is reversed. So the block has a larger cut out to be able to do this....
Old 11-07-2002, 11:49 PM   #1440
Alvin's Avatar
I find that blue block to be very weak due to the very thin material left on it. It flexes very easily. I went to dremel out a stock 414m block and it holds up much better.
~Alvin
Alvin is offline   Reply With Quote
414x x414x R/C Items: Wanted to Buy 3 06-30-2010 12:17 PM
looking for a tamiya 414x subaru73 R/C Items: Wanted to Buy 0 06-07-2006 09:50 PM
Tamiya 414x meche R/C Items: For Sale/Trade 2 09-12-2004 07:25 PM
Tamiya 414X icon R/C Items: Wanted to Buy 6 10-02-2002 08:58 PM
Looking for a 414x,414m,or TB Evo grinch77 R/C Items: Wanted to Buy 0 07-24-2002 06:22 PM
SEO by vBSEO 3.5.0
