Old 10-25-2002, 01:49 AM   #1321
Pyramid's Avatar
imataquito,
The diff. grease (white clear color) is too light/thin for differential. The black grease (you apply to susp. ball) is too heavy/thick for such differential ball.
So what you need is somewhere in the middle in viscosity (near the black grease I prefer) for use when building differential gear.
I'm using Omega Brand (do not know the part number since it is given by local friend) and uses differential sticker cover (I believe Atlas make one for TA04 which is the same with 414M, but you could always made one yourself).
Has been tried in one day practice + 2 days race without cleanning and proves to be running smooth, still.
This idea may not be new, but I do not recall reading in this thread. Shouldn't be wrong to mention then
Edited: Lubricant Enggineerings, Inc - General Purpose #1223 should works fine.
Pyramid is offline   Reply With Quote
Old 10-25-2002, 03:04 AM   #1322
CristianTabush's Avatar
try using the yokomo super diff lube... It's purpose made (designed for R/C) and it is thicker than all the diff lubes that I've seen on the market. Have had a lot of success with it on my M2 as well as on the Yoke I had before it.
REFLEX RACING/ RSD/ GIZMO RACING USA/ HOBBYWING/ AXON/ QTEQ/ TEAM PRIME
CristianTabush is offline   Reply With Quote
Old 10-25-2002, 03:21 AM   #1323
black-knight's Avatar
R/C Tech Charter Subscriber
Originally posted by Pyramid
I'm pretty sure it is in Tamiya Japan Office since the 2002 W Champ drives #0002. Well, just in case someone could...
Do you guys find new setups or tricks that work best for 414M?
PS: Use external grade grease for differential + sticker cover for smooth long lasting run.
#1 is used in tamiya adds and box shots for the wcr.
Black-Knight - None shall pass!
www.nbhc.com.au - www.facebook.com/smaracing
black-knight is offline   Reply With Quote
Old 10-25-2002, 06:20 AM   #1324
I bet there is more than one #1 M2 WC edition. Rick
Rick Draper is offline   Reply With Quote
Old 10-25-2002, 07:04 AM   #1325
rccarracer's Avatar
I don't think they would produce more then one #0001.....possibly in the higher numbers where people may not notice, but that is not Tamiya's style.
rccarracer is offline   Reply With Quote
Old 10-25-2002, 07:28 AM   #1326
SNEEK PEEK of my 2002 Australian Nationals weapon in the nude!
weapon number 1621/1700
Old 10-25-2002, 07:46 AM   #1327
rccarracer's Avatar
Very nice BK, have you removed the Anti-dive for the nats or are you keeping it?
Old 10-25-2002, 07:50 AM   #1328
zero kick-up to start with...
Old 10-25-2002, 07:51 AM   #1329
rccarracer's Avatar
Ok, but you still running with raised suspension blocks?
Old 10-25-2002, 07:52 AM   #1330
rccarracer's Avatar
Looks like it on the back, so I'm guessing you are?
Old 10-25-2002, 07:52 AM   #1331
yes i like the roll center to be lower...
Old 10-25-2002, 06:46 PM   #1332
imataquito's Avatar
Send a message via ICQ to imataquito Send a message via Yahoo to imataquito
black knight: nice car !!!
how did u make the car look green ??
hm ..... how much anti squat are u runing on the rear ??
if u r running 0 degrees how high did u raise the suspension up in the rear??
i am curently running rear front at 3mm and rear rear at 2 mm it helped gain rear end bite and gives more stearing off and on power ...
pyramid: hm ..... never tried those grease... tried those avalible in cans like soft99 grease spray .... not holding up too well so i used genaral purpose grease ... brown suff which is *quite* thick
and it works good ...
diff cover?? never seen one ...got a pic ??
imataquito is offline   Reply With Quote
Old 10-25-2002, 06:55 PM   #1333
rccarracer's Avatar
Here is the pic with the Atlas diff cover, it's from a Japanese Mag if you can't tell...
http://www.rccarracer.com/images/tea...diffcovers.jpg
Old 10-25-2002, 06:57 PM   #1334
it looks greenish because certain bluemetals reflect like that with a camera flash. I'll take some pics today without flash so that the blue shows up correctly.
antisquat, i have 2mm extra spacing for the forward rear block. 0 degrees was in referenc to front kickup.
Old 10-25-2002, 08:39 PM   #1335
Pyramid's Avatar
black-night,
congrats on the car.. just for your info, original placement of front stabilizer holes in A arms is 2mm to far from the shock. After 3 bats, both of your inner edge rims and stab plastic cup will be broken.
Solution: drill new holes on front A arms 1mm nearer to the shock (more than 1mm will hit the shock itself) and use 1mm red spacer in wheel hub or use thicker wheel hub.
414x x414x R/C Items: Wanted to Buy 3 06-30-2010 12:17 PM
looking for a tamiya 414x subaru73 R/C Items: Wanted to Buy 0 06-07-2006 09:50 PM
Tamiya 414x meche R/C Items: For Sale/Trade 2 09-12-2004 07:25 PM
Tamiya 414X icon R/C Items: Wanted to Buy 6 10-02-2002 08:58 PM
Looking for a 414x,414m,or TB Evo grinch77 R/C Items: Wanted to Buy 0 07-24-2002 06:22 PM
SEO by vBSEO 3.5.0
