Old 10-22-2002, 07:56 PM   #1291
imataquito's Avatar
Send a message via ICQ to imataquito Send a message via Yahoo to imataquito
alvin......... um ... checked ur shaft to see if its bent ... or did u install it the corect way ....
and yea my 414m centre one way is also feeling tight but its smooth ....
mite just pop in my kawada's one way ... cause i think both fits ...
imataquito is offline   Reply With Quote
Old 10-22-2002, 07:57 PM   #1292
Trader Rating: 49 (100%+)
Send a message via AIM to weaponx
my mistake i just assumed that because they came in my kit that it was a standard item with the 414m2 sorry about that
weaponx is offline   Reply With Quote
Old 10-22-2002, 07:59 PM   #1293
rccarracer's Avatar
I would say a bent centre shaft...check that.
Also what are you using to oil the oneway bearing? I heard you need a special grease for them, that if you use regular bearng oil they no longer work correctly (slip on the shaft).
rccarracer is offline   Reply With Quote
Old 10-22-2002, 08:01 PM   #1294
rccarracer's Avatar
No problem, your lucky though, I had to pay good money for the 2 diff pullies for my 414M. (The original silver bulkhead one...)
Old 10-22-2002, 08:10 PM   #1295
imataquito's Avatar
hm ... special oil??? i have been using mobil 5w engine oil since i got te car on all my bearings ( strip clean and apply oil) and my one way unit and all seems well ....
i even loaded the frontal one way with quite a lot of oil inside and its running super smooth ...
Old 10-22-2002, 08:19 PM   #1296
well i must be lucky also i just bought mine a few hrs ago and i got all the alum pully's as well and i got a m2
Chris@WeaponR is offline   Reply With Quote
Old 10-22-2002, 08:59 PM   #1297
TRF-Powered's Avatar
hummm... two people in a roll getting aluminum pulleys!?.... Maybe people owns M2 can send in the plastic one and get the aluminum ones now?......
TRF-Powered is offline   Reply With Quote
Old 10-22-2002, 09:02 PM   #1298
a friend of mine at the track also got aluminum pulleys with his m2
Old 10-22-2002, 09:15 PM   #1299
just wonder... which pulley are you talking about?? the one that's used in the rear ball diff and front oneway? the the center two pulleys (one regualr pulley/one one way).
Old 10-22-2002, 09:38 PM   #1300
reflekt's Avatar
Send a message via AIM to reflekt
i think they might be confusing the front one way with the pulleys. cuz to the best of my knowledge, aluminum pulleys are sold separately as hop ups. i mean, in the kit, you had to assemble the plastic pulley itself. so i dont kno...
-reflekt
~new TRF414M2 racer
reflekt is offline   Reply With Quote
Old 10-22-2002, 09:51 PM   #1301
Aurra Sing's Avatar
The silver and blue TRF shocks are the same thing, except for the color and the collars. The front one-way on the 414M, 414M2, WRC are the same TA04 one-way.
Aurra Sing is offline   Reply With Quote
Old 10-23-2002, 12:34 AM   #1302
rccarracer's Avatar
Are you guys talking about the two 15 tooth pulleys on the layshalf or the 32 tooth diff pulleys?
If your talking about the 15 tooth one, the WCR comes with alloy ones....
The 32 tooth diff pulleys are plastic throught the 414M series....the Alloy ones are hop ups! Only the TRF414 came with alloy throughout...
Old 10-23-2002, 12:35 AM   #1303
rccarracer's Avatar
-reflekt
~new TRF414M2 racer
Exactly what I thought and still think...
Old 10-23-2002, 03:58 AM   #1304
Hi Guys,
Just want to add in. I don't think Tamiya can make such a clumsy mistake (ie. mistakenly put the aluminium center pulley in 414M2). But if they do, you are the lucky ones then. I have seen a lot of 414M2 at my local track and none came with the aluminium center pulley (ie. the teeth). Unless, you are speaking about the item where the pulley sits (ie. the center one way housing).
Anyway, the opinion I gave earlier was just based on my personal experience with ALL 3 models that I have and race them, ie. 414M, 414M2 and 414M WRC. Thus, I can assure you, that there is no bias opinion towards certain model here.
You may also check with your LHS, if you buy the shock separately, the price of the silver shock is more expensive than the blue ones. It shows the different in quality. Logically, the blue anodized should be more expensive, right? (because of the anodizing and stuff). But it doesn't. The same logic is applied to the bearings. After I raced both 414M and the 414M2.... the blue shield bearing actually is much smoother.
Anyway, I love all of them, with all their plus and minuses. So, I hope no one get offended with my opinion. Again, it was just my opinion based on my personal experience with all those great models.
Keyence is offline   Reply With Quote
Old 10-23-2002, 09:16 AM   #1305
when i said i got the alum pulley i was talking about the diff pulley. my center is plastic.
everone on here is so questionable about what people have, yok guys are never like you. it makes me now want to have my 414 anymore
414x x414x R/C Items: Wanted to Buy 3 06-30-2010 11:17 AM
looking for a tamiya 414x subaru73 R/C Items: Wanted to Buy 0 06-07-2006 08:50 PM
Tamiya 414x meche R/C Items: For Sale/Trade 2 09-12-2004 06:25 PM
Tamiya 414X icon R/C Items: Wanted to Buy 6 10-02-2002 07:58 PM
Looking for a 414x,414m,or TB Evo grinch77 R/C Items: Wanted to Buy 0 07-24-2002 05:22 PM
