Old 10-20-2002, 10:53 PM   #1261
Where is the reference point for measuring droop on this 414M?
I've got the down-stop blocks already.
The other thing is on the official Tamiya page where Surikarn's setting was shown, they use the term 'rebound stroke'. It says rebound stroke front 1.5mm, rear 2mm. Again where am I suppose to find the point of reference? Could someone please help? Many thanks.
mandy is offline   Reply With Quote
Old 10-20-2002, 11:38 PM   #1262
over gear's Avatar
Trader Rating: 15 (100%+)
Originally posted by itchynads
Can someone tell me if the bearings on the bulkheads and center shaft holder are removeable? I'd like to replace the crummy metal shielded one with some better bearings (teflon). Its just that they seem pretty well secured and may need some force to wedge out.
Who sells better bearing kit for 414m2? The stock bearings are not smooth.....
over gear is offline   Reply With Quote
Old 10-21-2002, 12:01 AM   #1263
reflekt's Avatar
Send a message via AIM to reflekt
stock bearings for me are super smooth....
reflekt is offline   Reply With Quote
Old 10-21-2002, 12:02 AM   #1264
imataquito's Avatar
Send a message via ICQ to imataquito Send a message via Yahoo to imataquito
um .. stock setup is c1 left c2 right ....... that has less stearing
i am using c1 right and c2 left .... already tried it and yes it has more compared to stock .....
i am running on a med bite track ...
and i also do not use roll bars all around ...
stock rear A-arm holders ......
no spacer under the front camber links
2 mm for the rear
no droop limitations ...
just changed from 50W to 30W rear damping ....
front is at 50W..... stock springs ...
shortest wheelbase
anti dive = stock front
anti squat = rear 2mm on 'rear-front' A-arms holders (just changed from RF 2mm and RR 0.7mm)
( u refer to it as roll centres )
outermost hole on rear shocks mount and med hole on front shock mount ........
dual one ways
i still cant get the rear end to bite and still have enuff stearing to my liking .....
some guys say i take the turns too fast .... and i need fulltime 4wd for a better slow down to take the turns ....
but i am already VERY slow ...!!!
or should i change my slow-mo s3003 servo???
rite now the rear end is stuck but very unpredictable ... can just break traction very very suddenly - can deal with this tho
wondering what does putting spacers on the camber links on the bulkheads do ?? i think its the response through out the turn ....
on weather i want it more in the start middle or end point of a turn ??
but i just CANNOT get enuff stearing.............. (maybe i should slow down) ??
right now what i will try raising the rear roll centres to 5mm height and have a difference of 1.4-2 mm higher on the RF A-arm holder ..... waiting for spacers....
then will place harder prings at the rear and softer ones infront ...
pluz laying down the front shock mounting location all the way ...
imataquito is offline   Reply With Quote
Old 10-21-2002, 01:35 AM   #1265
ijnek's Avatar
Send a message via ICQ to ijnek
imataquito:
change away ur trusty s3003 lah,...
u've been eyeing a high-speed servo 4 sometime alreadi rite?...now's a good time to convince urself n get tat KOOL servo tat u r after...
hmmm,....errr...also,stop turning my steering wheel n telling mi how fast the servo is compare to urs,...heheheheee
ijnek is offline   Reply With Quote
Old 10-21-2002, 01:36 AM   #1266
Pyramid's Avatar
Maybe you have the regular M, silver bulkhead, which has a much better bearings with blue teflon? cover.
I agree the M2 and newer release including the WR equipped with cheaper bearings.
Pyramid is offline   Reply With Quote
Old 10-21-2002, 05:09 AM   #1267
rccarracer's Avatar
The original 414M is very smooth, but even so, I open the Teflon seals on mine and flushed the grease and then lubed them with Fantom bearing oil and replaced the seals.
rccarracer is offline   Reply With Quote
Old 10-21-2002, 05:13 AM   #1268
black-knight's Avatar
R/C Tech Charter Subscriber
Off Topic: how many 414 World Champs's left at Vaggs? I have another buyer!!!! (exclude the one my friend has on laybuy)
Black-Knight - None shall pass!
www.nbhc.com.au - www.facebook.com/smaracing
black-knight is offline   Reply With Quote
Old 10-21-2002, 05:21 AM   #1269
rccarracer's Avatar
None.....you bought one, I bought one, your mate has one on layby and the other was bought on saturday by someone else.
Old 10-21-2002, 05:22 AM   #1270
rccarracer's Avatar
By the way, what number did you get?
Old 10-21-2002, 05:32 AM   #1271
1621 of 1700
Old 10-21-2002, 05:37 AM   #1272
rccarracer's Avatar
1467 of 1700 for me....
Old 10-21-2002, 05:40 AM   #1273
whats the internal drive ratio of the 414m? is it 2.2??
Old 10-21-2002, 05:42 AM   #1274
rccarracer's Avatar
Come on even you should be able to work this out .....it's 2.13
Old 10-21-2002, 05:46 AM   #1275
i was been lazy...LOL
thanks
414x x414x R/C Items: Wanted to Buy 3 06-30-2010 11:17 AM
looking for a tamiya 414x subaru73 R/C Items: Wanted to Buy 0 06-07-2006 08:50 PM
Tamiya 414x meche R/C Items: For Sale/Trade 2 09-12-2004 06:25 PM
Tamiya 414X icon R/C Items: Wanted to Buy 6 10-02-2002 07:58 PM
Looking for a 414x,414m,or TB Evo grinch77 R/C Items: Wanted to Buy 0 07-24-2002 05:22 PM
