Like Tree1Likes
Old 10-17-2002, 07:21 AM   #1246
rccarracer's Avatar
Default Re: RCCARRACER
Originally posted by TRF512
judging from your signature, I assume you own/have owned a TRF414 and the TRF414M?
If so, is the TRF414 rear belt the same size as that of the TRF414M?
Ok, firstly, yes I own both a TRF414 and TRF414M, and soon to be owner of the WCR edition as well.
Now, as pyramid said earlier, the TRF414 belt is considerably smaller than the TRF414M belt....
rccarracer is offline   Reply With Quote
Old 10-17-2002, 08:28 AM   #1247
superk's Avatar
Hm...wonder where can I get that 414M II WCR ??? Used to own a TRF414M .... now I run EVO II ....... I like to have my 414M WCR... who have it for sale? and how much?
superk is offline   Reply With Quote
Old 10-17-2002, 09:04 AM   #1248
Pyramid's Avatar
Just read couple pages from last posts (1 page behind I think) and you will find the answer...
Edited: Sorry, it is actually in the Prices in Hongkong under "Hong Kong R/C" regional section (HKD3650)
Pyramid is offline   Reply With Quote
Old 10-17-2002, 07:12 PM   #1249
Default Thanks
Alvin, Rough : NIce Pictures
RCCARRACER, Pyramid : Thanks for the info
TRF512 is offline   Reply With Quote
Old 10-19-2002, 05:52 PM   #1250
Alvin : nice car. but can i ask what is that blue thing near the spur gear? is that a motor plate heatsink? TIA!
topgun is offline   Reply With Quote
Old 10-20-2002, 01:33 AM   #1251
Can someone tell me if the bearings on the bulkheads and center shaft holder are removeable? I'd like to replace the crummy metal shielded one with some better bearings (teflon). Its just that they seem pretty well secured and may need some force to wedge out.
itchynads is offline   Reply With Quote
Old 10-20-2002, 02:13 AM   #1252
imataquito's Avatar
Send a message via ICQ to imataquito Send a message via Yahoo to imataquito
put something woden and soft over the bearings and lightly tap it ....
(lightly!!)
till it comes out .....
imataquito is offline   Reply With Quote
Old 10-20-2002, 03:01 AM   #1253
(lightly!!)
Thanks, I'll try it
Old 10-20-2002, 05:00 PM   #1254
Aurra Sing's Avatar
Minez 1
Aurra Sing is offline   Reply With Quote
Old 10-20-2002, 05:00 PM   #1255
Aurra Sing's Avatar
[edit]oops[/edit]
Old 10-20-2002, 05:01 PM   #1256
Aurra Sing's Avatar
Minez 2
Old 10-20-2002, 05:27 PM   #1257
imataquito's Avatar
um ....... here are pics of my car
btw i need more sensitivity on my stearing response and i need MORE stearing + more rear end bite ...
can anyone tell me what to do ... most changes i made did not give what i was looking for ...
http://www.rctech.net/forum/attachme...&postid=180876
http://www.rctech.net/forum/attachme...&postid=180873
http://www.rctech.net/forum/attachme...&postid=180872
http://www.rctech.net/forum/attachme...&postid=180866
http://www.rctech.net/forum/attachme...&postid=180865
Old 10-20-2002, 05:53 PM   #1258
Aurra Sing's Avatar
Try:
- Front uprights: make sure that Left is C1 and Right is C2. It will lower the front roll center (if you had it opposite.)
- Raise the rear roll center. It will have a more gentle entrance then break loose in the mid-corner.
- If your track is low traction, remove the rear swaybar. I learned that because of the low traction, the rear tires won't reach the peak slip angle. With a rear sway-bar, the weight will be transferred to the outside of the tire, thereby increasing the rear grip. So remove it!
- Mount all shocks on outer-most holes (but it will be more twitchy.) Usually whenever I try this, I need to use the TA04 10deg. castor blocks to smoothen it out again.
- Play around with the steering exponential on your radio.
- Flip the steering rack backwards to change the ackerman (but you may scrub corner speed.)
- Make sure you have the right tires! (this car is very sesnsitive to different tires and inserts, like any other car!)
Old 10-20-2002, 06:02 PM   #1259
Alvin's Avatar
Aurra, I could be mistaken but won't C1 on the right (ala same side as the spur) lower the roll centre for the front? With C1 on the right the tires are mounted lower. Anyway on the track I feel with C1 on the right the car has more front bite.
~Alvin
Alvin is offline   Reply With Quote
Old 10-20-2002, 06:07 PM   #1260
Aurra Sing's Avatar
Here's my current setup. It has a lot of corner speed and steering, but a lot of turn-in. I need to dial that out next time. For a soda traction, asphault, very technical track.
Front: Blue sway bar, -1.5 camber, 1.0 toe-out, 3mm under upper link, droop 3mm
Rear: No sway bar, -2.0 camber, 1.5 toe-in (one-dot block on the RF block) 3mm under upper link, droop 4mm
Roll center: FF: 0.7mm FR: 2mm RF: 2mm RR: 0.7mm
TA04 10 Caster Block
Associated Blue Springs, 60wt oil all around, shocks mounted outer most
Alvin - Nah, I think you have it backwards... I think
414x x414x R/C Items: Wanted to Buy 3 06-30-2010 11:17 AM
looking for a tamiya 414x subaru73 R/C Items: Wanted to Buy 0 06-07-2006 08:50 PM
Tamiya 414x meche R/C Items: For Sale/Trade 2 09-12-2004 06:25 PM
Tamiya 414X icon R/C Items: Wanted to Buy 6 10-02-2002 07:58 PM
Looking for a 414x,414m,or TB Evo grinch77 R/C Items: Wanted to Buy 0 07-24-2002 05:22 PM
