Old 04-23-2002, 05:14 AM   #601
rccarracer's Avatar
Originally posted by Aurra Sing
rccarracer - Aren't the stock turnbuckles already titanium? There's really no weight difference between tem and Lunsford.
No, the stock ones are tamiyas regular steel turnbuckles.
And there is a weight difference, if you take all the stock ones out and then compare the with the set of lunsford Ti turnbuckles there is a big difference!
rccarracer is offline   Reply With Quote
Old 04-23-2002, 07:03 AM   #602
Where to find Lunsford parts for TRF 414M ?
I had a look on Lunsford website and didn't find any references for TRF 414M nor TA04.
Ralf is offline   Reply With Quote
Old 04-23-2002, 07:48 AM   #603
NANAKO's Avatar
Ralf...you pretty much have to measure your TAMIYA turnbuckles and go to your LHS and buy them one by one. There is no set for the 414M. Most of the stores sell them for about $4-5 each. There is Technacraft and Lundsford brands. I think Technacraft ones have the one hole in the center and the Lundsford has it where you can use a wrench.
NANAKO is offline   Reply With Quote
Old 04-23-2002, 09:21 AM   #604
Pyramid's Avatar
In case Yokomo could be your alternatives, here are what you need (with the condition of both front and rear upperlink are mounted on shock tower):
YOK-ZCTB20 Ti Turnbckl 20mm Pair Steering
YOK-ZCTB25 Ti Turnbckl 25mm Pair Front Upper Link
YOK-ZCTB27 Ti Turnbckl 27mm Pair Rear Upper Link
YOK-ZCTB35 Ti Turnbckl 35mm Pair Front Support
Just for info, I do not think TRF414M2 comes with lightweight outdrives. Here what it says on the outside sticker (Japanese Version Box) : Body, Dodge Stratus made by Protoform company* Sticker for Body* Masking seal for window* Wing* TRF sticker* Aluminum Swing Shaft* Lightweight Suspemsion Ball* Wheel Wrench* Hex Wrench DDriver* Turnbuckle Wrench.
Pyramid is offline   Reply With Quote
Old 04-23-2002, 01:33 PM   #605
Thank you guys for the infos,
I thought that TRF414M2 comes with Delrin outdrives, the LHS told me that and when you look at the pictures on Tamiya website you can see them in Delrin.
Did someone buy the new TRF414M2 can confirm the outdrives are in Delrin ?
Old 04-23-2002, 02:00 PM   #606
Ralf: the M2 comes with Delrin Outdrives.. If you want to confirm jwwu has a M2.
JC
tiggersz is offline   Reply With Quote
Old 04-23-2002, 02:05 PM   #607
I should be receiving my M2 very soon I'll let you guys know then
jwwu is offline   Reply With Quote
Old 04-23-2002, 06:30 PM   #608
Kenneth Tan's Avatar
I GOT MY NEW AVATAR!
Anyway, Has any of you tried the mod of putting the front roll bar on the upperdeck? I understand that I will need to purchase a set of rear roll bars. I have seen on magazines that an extra hole has to be drilled on the front arms to accomodate the ball studs. However I have heard that I could also use the hole at the front of the castor blocks. Which one works better?
Kenneth Tan is offline   Reply With Quote
Old 04-23-2002, 09:28 PM   #609
Pyramid's Avatar
About the differences on which holes to use, I have no idea. But the upper front sway bar did gives more steering respons (don't know how much more either as I also relocating the servos positions).
I'll try to get my camera working again and share some pics.
Old 04-23-2002, 09:38 PM   #610
Pyramid's Avatar
To Kenneth Tan,
How much is the cheapest street selling price for M2 in Singapore?
Old 04-23-2002, 10:46 PM   #611
I think the pricing of the M2 (Red Box) is ESTIMATED to be below SGD600.
Old 04-23-2002, 11:53 PM   #612
Usagi's Avatar
Well i seen a few of those M2 kits in tokyo. I was in osaka and I did not seen any around in the shops.
I thought about buying the M2 but i going to buy a Ova T4 instead in a few months.
Usagi is offline   Reply With Quote
Old 04-24-2002, 05:40 AM   #613
ijnek's Avatar
Send a message via ICQ to ijnek
Originally posted by Pyramid
To Kenneth Tan,
let's c,...the red box 1 is abt s550 and the black box 1 is s8++...
i got these prices frm winnie's n she has oni 1 red box 414m2 left at this moment...
ijnek is offline   Reply With Quote
Old 04-24-2002, 06:50 AM   #614
Jack's Avatar
u sure is about 550???
hmmm
Jack is offline   Reply With Quote
Old 04-24-2002, 08:17 AM   #615
Pyramid's Avatar
I assume the black box is Japanese version that comes with everything. It's equal to about SGD700 here in Surabaya, Indonesia.
Winnie was selling the Japanese Version at SGD1050 when she has it about a month ago. SGD8++ still consider high I think.
414x x414x R/C Items: Wanted to Buy 3 06-30-2010 11:17 AM
looking for a tamiya 414x subaru73 R/C Items: Wanted to Buy 0 06-07-2006 08:50 PM
Tamiya 414x meche R/C Items: For Sale/Trade 2 09-12-2004 06:25 PM
Tamiya 414X icon R/C Items: Wanted to Buy 6 10-02-2002 07:58 PM
Looking for a 414x,414m,or TB Evo grinch77 R/C Items: Wanted to Buy 0 07-24-2002 05:22 PM
