Old 03-02-2002, 07:42 AM   #376
INITIAL D's Avatar
Send a message via ICQ to INITIAL D Send a message via AIM to INITIAL D Send a message via Yahoo to INITIAL D
I don't like the 414M with the blue stuff. I think it looks better with the silver parts.
INITIAL D is offline   Reply With Quote
Old 03-02-2002, 05:54 PM   #377
Regional Moderator
daniz24's Avatar
Yup...... The silver aluminum parts make the 414M looks Luxury and Cool
daniz24 is offline   Reply With Quote
Old 03-03-2002, 11:48 PM   #378
Kenneth Tan's Avatar
I am having some problems with the centre oneway pulley of the 414m. I does not feel as smooth as the other oneway pulleys I have seen. I tried to clean out the bearing with motor spray and lubricating it with Serpent oneway oil, but doesn't work.... Any ideas please? Thanks.
Kenneth Tan is offline   Reply With Quote
Old 03-04-2002, 07:18 AM   #379
K. Tan: The standard center one-way (c/w 414M kit) doesn't last that long. it is time for you to change the 414M center one-way wit the new Tamiya TA04 alum. one-way.
MIKA is offline   Reply With Quote
Old 03-04-2002, 10:42 AM   #380
InitialD......right now I am running the red swaybar in front only(no rear sway bar). 70wt front, 60wt rear. Asc. gold springs all around. No torque rods and steering rack pointed forwards for more ackerman. Diff/center oneway/diff. One dimple rear block. Other settings are stock
Its an agressive setup. Very turny. It seems to suit my style of driving very well. The car rotates well without the rear fighting the front end. Throttle/off throttle steering is easy with this setup.
Gavin
gavin is offline   Reply With Quote
Old 03-06-2002, 01:11 AM   #381
Trader Rating: 32 (100%+)
Default 414M Center One-Way
Kenneth Tan
MIKA is right, replace those standard ones with the aluminum center one-way. I also had problems with those standard ones in my 04
Rnold is offline   Reply With Quote
Old 03-06-2002, 01:17 AM   #382
Default TRF414M
Here's a picture of my TRF414M. I replaced the plastic diff pulleys and center pulleys with aluminum.
Old 03-06-2002, 05:08 PM   #383
How do you measure droop on the 414m? I've seen several set-up sheets on the japan website and most of them have a measurement of 3mm. What does that mean? I have also seen measurements of 24mm and 23mm for the height of the alxes when the car is laid flat on ground....
What is the part no. of the front and rear belts? The hinge pins? Thanks a lot!
Old 03-06-2002, 10:14 PM   #384
Kenneth Tan:
Droop is usually measured from the bottom of the chassis to the bottom of the arm/hub.
The part number for the front belt is the same as the ta04 belt.
The part number for the rear belt is 6244004
The part number for the Hinge Pins is 9805741
tiggersz is offline   Reply With Quote
Old 03-07-2002, 12:30 AM   #385
Are the bearings in the aluminum part of the 414M replaceable? They look like they are pressed in, can they be taken out?
Potato is offline   Reply With Quote
Old 03-07-2002, 02:11 PM   #386
Potato: Yes they are.. Your going to have to heat the bulkhead to get them out.
Old 03-07-2002, 02:16 PM   #387
Ack, that sucks, why did they design it that way?
Old 03-07-2002, 02:48 PM   #388
INITIAL D's Avatar
Cheap TAMIYA screws that came with the 414M are striped under the chassis where it screws into the bulk-head! How am I surpose to get those out? Any ideas?
Old 03-07-2002, 02:51 PM   #389
INITIAL D's Avatar
Thanks Gavin for you set up!
Old 03-07-2002, 03:32 PM   #390
Potato: its just so you have a good fit with the bearings you can heat up the bulkhead and the bearings will fall right out. Are you having a problem with one of the bearings?
414x x414x R/C Items: Wanted to Buy 3 06-30-2010 11:17 AM
looking for a tamiya 414x subaru73 R/C Items: Wanted to Buy 0 06-07-2006 08:50 PM
Tamiya 414x meche R/C Items: For Sale/Trade 2 09-12-2004 06:25 PM
Tamiya 414X icon R/C Items: Wanted to Buy 6 10-02-2002 07:58 PM
Looking for a 414x,414m,or TB Evo grinch77 R/C Items: Wanted to Buy 0 07-24-2002 05:22 PM
