Like Tree2Likes
Old 08-15-2015, 05:57 PM   #3541
Look for a TA04 for sale. Couldn't cost more than $25. The TA04 center pulley is better in my opinion than the 414 center pulleys
Juan Aveytia is offline   Reply With Quote
Old 08-15-2015, 07:47 PM   #3542
EDWARD2003's Avatar
I can hook you up with these.
http://page10.auctions.yahoo.co.jp/j...ion/m141207719
Check out my YouTube channel for 1/12th scale and 1/10th Touring maintenance tips!
YouTube Search https://www.youtube.com/c/EdwardPickering?gvnc=1
                 VBC 12M - D08 - FX
EDWARD2003 is offline   Reply With Quote
Old 08-16-2015, 10:10 AM   #3543
Originally Posted by EDWARD2003 View Post
Oh snap! Yes, hook me up please (since it's a set of 2, you'll have an extra one for yourself or for someone else that needs it)
Jah2000 is offline   Reply With Quote
Old 08-16-2015, 03:17 PM   #3544
Couldn't I just grind a notch, or drill a dimple, further out on the stock 414M center-shaft?
Even if I pushed the spur-holder out 8mm, there is still plenty of room left on the stock 414M center-shaft for the spur-holder to hold onto and be in place without any wiggle (like a good 10mm of shaft left still).
Old 08-16-2015, 05:46 PM   #3545
You wouldn't have to go 8 mm. That would be to far I think. Install 8mm and the motor plate. Then then drill or make the flat spot for the set screw just past the motor plate. Give it a shot. It should work
Old 08-16-2015, 09:18 PM   #3546
I actually did just that, a few hours ago (notched a flat slot with a saw) . Worked well and looks much better now (though, I still want a proper TA04 center-shaft).
I can actually use the top screw now and it even has good clearance. I also used 7mm worth of spacers (I might add 1mm more...8mm really seems like the perfect spacing for a Tekin Redline Gen2 motor). Look very nicely centered.
Old 08-16-2015, 09:56 PM   #3547
If you run a spoil or a diff in the front. The car rotates a lot better moving the camber links to shock tower. I usually use the longest hole on the top all around
Old 08-16-2015, 09:57 PM   #3548
And just bend the motor tabs slightly up so they don't scratch the bulkheads
Old 08-16-2015, 10:34 PM   #3549
Ya, I'm gonna bend the tabs when I solder and wire everything up. Don't want to cause any electrical mishaps either.
Old 08-16-2015, 10:42 PM   #3550
Since you removed the front diff, what are you going to do to get the gear ratio correct? I broke a belt on my tc one time and the car went half as fast. Just wondering what your plan is to resolve it as I like the Idea of a rwd tc chassis.
DMALMAD is offline   Reply With Quote
Old 08-16-2015, 10:56 PM   #3551
See my reply in my other thread.
It's going to be a Rwd drifter mainly.
Old 08-31-2015, 03:00 AM   #3552
Trader Rating: 8 (90%+)
Anyone know if the EVO4 blue steering arm (left and right) fit the TRF414M? They look quite similar.
TenzoR is offline   Reply With Quote
Old 09-01-2015, 10:05 AM   #3553
My 414M WE came with these 2 rear/rear blocks. Can someone please tell me what they mean and how much toe-in they each are supposed to provide?
At first, I had the blue 3-dot one installed. But, I found it had too much toe-in and gave me too much straight-line correction and stability. I then, installed the silver 1-dot block yesterday, to give me less toe-in. (also note: the rear/front block has no dots/markings).
My goal/desire is to have both 0 and 1 rear toe-in to play around with. Do I need new blocks to get 0 or 1?
Old 09-05-2015, 06:34 PM   #3554
(0000000000)'s Avatar
3 dots should mean 3' toe in the rear of the rear toe block (also known a RR). This will give you 3' total, if you are running 0' rear hubs.
The front of the rear toe block (also know as RF block) should have no markings, as it is the pivot point for where the rear toe is measured.
Hope this helps sort things out. Remember , put aw grease on the suspension shafts before they go into the toe blocks!
My Original USER ID was 0000000000. But now it doesn't seem to work.
(0000000000) is offline   Reply With Quote
Old 09-13-2015, 03:46 PM   #3555
Trader Rating: 30 (97%+)
any of you not using the battery holders and have new ones I need a couple of sets if you can sell me please pm thanks
zaraz is offline   Reply With Quote
414x x414x R/C Items: Wanted to Buy 3 06-30-2010 11:17 AM
looking for a tamiya 414x subaru73 R/C Items: Wanted to Buy 0 06-07-2006 08:50 PM
Tamiya 414x meche R/C Items: For Sale/Trade 2 09-12-2004 06:25 PM
Tamiya 414X icon R/C Items: Wanted to Buy 6 10-02-2002 07:58 PM
Looking for a 414x,414m,or TB Evo grinch77 R/C Items: Wanted to Buy 0 07-24-2002 05:22 PM
