Old 07-25-2015, 08:06 AM   #3526
SagadSetup's Avatar
Trader Rating: 38 (100%+)
Originally Posted by subaru73 View Post
Yes it was now I have 2 414 and a 414m
Do you plan to assemble it?
Are you right where you're supposed to be?
Think. Learn. Play. Plan. For soon you'll become.
SagadSetup is offline   Reply With Quote
Old 07-25-2015, 08:44 AM   #3527
subaru73's Avatar
Trader Rating: 41 (100%+)
I am having a hard time deciding if I want to or not.
Tamiya Ta07 Tamiya evo5 ms,Tamiya Ta05r Tamiya FF04 rm01 Tamiya Ff03R
Futaba 4Px radio lrp speed control
Cfx paint works Fantom Racing apex Rc tq hobbies acer racing Hebki design works
subaru73 is offline   Reply With Quote
Old 07-25-2015, 09:16 AM   #3528
SagadSetup's Avatar
Your're also a collector like me.
If ever you decide to assemble will you run it?
Old 08-13-2015, 03:39 PM   #3529
I just received a beautiful Tekin Gen2 10.5T motor for it. And, since it's a modern brushless, it doesn't quite fit. What's the best solution to make it fit? It's off by only a couple millimeters. Do I just add Spacers between the bulkhead and motor mount?
Jah2000 is offline   Reply With Quote
Old 08-13-2015, 04:33 PM   #3530
Yes. If you can find a TA04 center shaft. You will be able to completely center the motor
Juan Aveytia is offline   Reply With Quote
Old 08-13-2015, 05:32 PM   #3531
Ended up using 4mm of spacers for the motor-mount (5-6mm would work better; but then the motor mount plate would hit the spur-gear-holder), and 2mm of shims between the spur-gear-holder and motor-mount so it doesn't rub.
Thanks. I'll keep my eye-out on that center-shaft.
And, how many millimeters of spacers to make it "perfectly" centered with the aforesaid shaft?
Old 08-13-2015, 06:17 PM   #3532
Depends on the motor. But 7mm-8mm
Old 08-13-2015, 06:44 PM   #3533
Didn't know that TA04 center-shaft part is rare/expensive until now. Plus, another $25 for the required spur-gear-holder (since it's different than the 414M). Making it a total of $50+ just for that small TA04 center-shaft upgrade.
I think I'll pass, and just stick with the stock 414M center-shaft, with the upper motor-mount screw removed (to give room for the spur-holder).
Old 08-13-2015, 10:13 PM   #3534
I use the 414m spur gear holder. Tighten the set screw into the hole where the pin goes. Works perfect. And I highly recommend installing all 3 screws in the motor plate
Old 08-13-2015, 11:02 PM   #3535
Ah..cool to know I can use the same 414m spur holder.
But there's gotta be an alternative center-shaft that works. Maybe Yokomo, Overdose, MST or other Tamiya car. The only TA04 center-shaft is a whopping $50 bones on ebay :/
Old 08-14-2015, 12:29 AM   #3536
EDWARD2003's Avatar
If anyone is interested, I'm considering parting ways with my 414M updated chassis. No time to race it and rather have someone else keep it on the track. It's a great car and performs nicely. Won its first outing. pm me if interested.
Check out my YouTube channel for 1/12th scale and 1/10th Touring maintenance tips!
YouTube Search https://www.youtube.com/c/EdwardPickering?gvnc=1
                 VBC 12M - D08 - FX
EDWARD2003 is offline   Reply With Quote
Old 08-15-2015, 12:03 PM   #3537
If anyone knows where I can get a TA04 Center-Shaft for a reasonable price (ie: Not $25-50 lol), pleease let me know
Old 08-15-2015, 12:55 PM   #3538
SagadSetup's Avatar
http://www.vellrip.com/store/product...asp?p=1099&c=5
Old 08-15-2015, 01:12 PM   #3539
Thanks. But I already contacted them (and also RCJaz) after google searching a few days ago. Unfortunately, none of them have it in stock.
Old 08-15-2015, 01:32 PM   #3540
SagadSetup's Avatar
Goodluck. Hope you find it eventually.
414x x414x R/C Items: Wanted to Buy 3 06-30-2010 11:17 AM
looking for a tamiya 414x subaru73 R/C Items: Wanted to Buy 0 06-07-2006 08:50 PM
Tamiya 414x meche R/C Items: For Sale/Trade 2 09-12-2004 06:25 PM
Tamiya 414X icon R/C Items: Wanted to Buy 6 10-02-2002 07:58 PM
Looking for a 414x,414m,or TB Evo grinch77 R/C Items: Wanted to Buy 0 07-24-2002 05:22 PM
