Old 07-08-2015, 05:35 PM   #3511
Originally Posted by EDWARD2003 View Post
Maybe you should look at posting your drift ideas in a drift thread
Yes and no
Maybe yes, since 414 heads are usually grip heads (the car's intended purpose). But ya, I admit I've posted too many drift specific questions. Sorry. I'll just stick with the more common parts-compatibility questions then
No, since this is the best thread with the most knowledgeable and experienced 414 people that know which components (from other Tamiya cars) are adaptable and compatible with the 414s (important aspect and information, for both drift and grip...basically, 414 upkeep and parts usage, spares and compatibility).
Jah2000 is offline   Reply With Quote
Old 07-08-2015, 05:55 PM   #3512
Originally Posted by SagadSetup View Post
Honestly, if you calculate all the parts+your labor+the agony of waiting for parts to come, it might have been better off that you just bought any of the chassis listed above.
I bought the 414M for $180... to convert it for Drift: WA axles ($25), WA steering-set ($30), pulley ($10), belt ($5), drift wheels/tires ($30) = $280
...and that'll be on a full carbon, aluminum and high-quality Tamiya chassis (No Eagle or Sakura stuff). Nicely balanced with center mounted motor and battery.
Idk about you...but <$300 for a Tamiya TRF chassis that's drift capable, sounds a LOT cheaper than those $500 chassis kits you've listed.
You also forgot..those chassis you've listed aren't really modded much and people STILL need to buy the parts I've listed. The chassis you listed are basically front bias layout and balanced for drift (and not much else). They still don't have WA front axles, WA steering, CS ratio overdrive, etc. If you search or read threads/blogs, people with those drift kits Still end up modifying for more WA.
So my current 414M car, and also my plan for mild (and reversible) drift mods, is cheaper and at the same time high quality.
Old 07-08-2015, 06:17 PM   #3513
SagadSetup's Avatar
Trader Rating: 38 (100%+)
Yes, your car is a drift 414M.
Are you right where you're supposed to be?
Think. Learn. Play. Plan. For soon you'll become.
SagadSetup is offline   Reply With Quote
Old 07-08-2015, 09:35 PM   #3514
It sure is
Just like these 414s
http://www.rc-drift-cars.com/rc-drift-car.htm
https://www.youtube.com/user/dencio1...?query=trf414m
https://www.youtube.com/watch?v=puZFr9uMzyw
Old 07-09-2015, 02:56 AM   #3515
SagadSetup's Avatar
Ok then, since you want to start a new modality, I suggest that you start a thread with that specific topic (414M drift) or post in another site specific to drifting.
I think that EDWARD2000's reply is correct. That way, you (and I) will not sidetrack the topics here saying that the 414M, 404x, 414x, 414 are touring cars and not drift cars.
Old 07-09-2015, 07:49 PM   #3516
No prob. I will refrain from posting Drift related stuff on this thread then.
Old 07-22-2015, 11:17 AM   #3517
Here's another 414M specific question:
My 414M didn't come with the stock plastic battery holder/mounts parts. Does anyone know the Tamiya part number for those 414m stock parts; or, a battery holder/mount that fits (without needing to drill)?
I bought battery velcro straps (for now); but I would like something more solid-holding and cleaner looking. Note: I am using stick-packs.
Old 07-22-2015, 12:31 PM   #3518
I believe you bought the worlds edition. The bottom deck came from the factory with the holes already removed from the chassis that holds those plastic parts. You'll have to design your own.
Juan Aveytia is offline   Reply With Quote
Old 07-22-2015, 01:18 PM   #3519
Yes, I have the WE. And yes, there seems to be no holes (except for slit-holes for straps). I guess straps are fine
Btw, Juan...I read your older post about Evo5 spools and Evo6 gear-diffs fitting very good on the 414M. Let's say if I wanted to put a rear spool in my 414M (for drift), which Spool do you think would fit better in the rear and which should I get - the Evo5 or Evo6 spool? (since the Evo6's gear-diff fits perfectly; I'm guessing the Evo6's related spool would be the same...I could be wrong though)
Old 07-24-2015, 03:21 AM   #3520
The Evo5 spool fits the best, but the Evo4 spool works really well all so. The Evo6 diff basicly drops right in. But the belt is slightly of centered. I purchased some 15t aftermarket pulleys to fix that problem. But since the gear diff is going in the front. You won't notice the diff pulley not being centered much. And since your drifting the chassis and racing it. It will be just fine. I can't remember at the moment, but there is a company that makes 32t pulleys out of metal that will work awesome for you. Will help with the bling factor as well. There chrome with Tamiya Blue on them. Should help you alot. You'll need (2) oneway pulleys for what your trying to do
Old 07-24-2015, 10:04 AM   #3521
Great! Perfect. I'll shoot for an Evo5 spool and a new pulley then
Old 07-24-2015, 06:21 PM   #3522
subaru73's Avatar
Trader Rating: 41 (100%+)
Default 414
My newest addition .
Tamiya Ta07 Tamiya evo5 ms,Tamiya Ta05r Tamiya FF04 rm01 Tamiya Ff03R
Futaba 4Px radio lrp speed control
Cfx paint works Fantom Racing apex Rc tq hobbies acer racing Hebki design works
subaru73 is offline   Reply With Quote
Old 07-24-2015, 06:41 PM   #3523
SagadSetup's Avatar
Thumbs up
Nice!
Old 07-24-2015, 09:33 PM   #3524
Is that the one that just recently ended on eBay? If yes, Very good price!
Nice one though!
Old 07-25-2015, 07:22 AM   #3525
subaru73's Avatar
Default 414
Nice one though!
Yes it was now I have 2 414 and a 414m
414x x414x R/C Items: Wanted to Buy 3 06-30-2010 11:17 AM
looking for a tamiya 414x subaru73 R/C Items: Wanted to Buy 0 06-07-2006 08:50 PM
Tamiya 414x meche R/C Items: For Sale/Trade 2 09-12-2004 06:25 PM
Tamiya 414X icon R/C Items: Wanted to Buy 6 10-02-2002 07:58 PM
Looking for a 414x,414m,or TB Evo grinch77 R/C Items: Wanted to Buy 0 07-24-2002 05:22 PM
