Like Tree4Likes
Old 07-02-2015, 02:15 PM   #3481
I've seen his vids. Since he's like only one of the very few drifting a 414M lol. I messaged him a few days ago. Haven't got a reply yet tho.
Jah2000 is offline   Reply With Quote
Old 07-02-2015, 02:18 PM   #3482
website glitch..again..lol
Old 07-02-2015, 02:31 PM   #3483
For steering-set:
http://www.ebay.com/itm/380953049554...%3AMEBIDX%3AIT
or
http://www.ebay.com/itm/181777233360...%3AMEBIDX%3AIT
or
http://www.ebay.com/itm/281732862060...%3AMEBIDX%3AIT
or
http://www.ebay.com/itm/251468195994...%3AMEBIDX%3AIT
For axles & shaft:
http://www.ebay.com/itm/250919978815...%3AMEBIDX%3AIT
or
http://www.ebay.com/itm/161201164724...%3AMEBIDX%3AIT (might require MST KPI knuckles? …idk)
or
http://www.ebay.com/itm/Overdose-Axl...item1e8ea27ef8
For knuckles (optional, since I can just modify oem knuckle and/or do the c-hub delete mod, for now):
http://www.ebay.com/itm/MST-Aluminum...item1e9a5f1d5a
or
http://www.raikoudrift.com/store/product139.html
For arms (optional):
http://www.ebay.com/itm/131508556473...%3AMEBIDX%3AIT
http://www.ebay.com/itm/381233395720...%3AMEBIDX%3AIT
You think the above parts will fit? Which steering-set and which axles/shafts would you pick? Which are the highest quality?
The one thing I did notice in particular though, that might be a concern - the MST KPI knuckles. They appear to use a different size inner and outer axle-bearing. The outer bearing looks like it uses a standard 5x11, while the inner uses a bigger bearing that fits over the axle’s “cup” it looks like. So this might be a compatibility issue for different axles. Maybe they’re only compatible with MST axles?
http://www.maxspeedtechnology.co.uk/...l-colours.html
There’s also the Wrap-Up-Next knuckles. I’m not sure if they work with 4wd front axles though, or if they’re just meant for Rwd.
Old 07-02-2015, 02:36 PM   #3484
SagadSetup's Avatar
Trader Rating: 38 (100%+)
I love the car the way it is. It's a classic.
If I owned that, I would keep it on display and buy another beater car.
Just my humble and respectful 2 cents.
Are you right where you're supposed to be?
Think. Learn. Play. Plan. For soon you'll become.
SagadSetup is offline   Reply With Quote
Old 07-02-2015, 02:56 PM   #3485
My picks (unless you can advise otherwise please):
Steering set: WUN. Because it looks to be the most universal and compatible, given it’s T (or X) shape, with “arms” on each 4 sides.
Axles/shafts: Any looks like they’ll work. Choose MST cvd’s if using MST KPI knuckles (to be safe).
Knuckles: MST KPI. Since they look easier-available and for sure they work on 4wd (from manual/pics). The WUN knuckles might be only for Rwd (?), uses odd flanged bearings and doesn’t even list bearing sizes (might be hard to find spare bearings). MST knuckles just look better designed overall and actually shaped like a knuckle (WUN looks like a block, lol).
Upper and lower arms:
WUN arms are looking good.
Old 07-02-2015, 02:57 PM   #3486
I'll get another car...but not for a bit (I'm not rich). I'll do some drift mods to it, then when I get a 2nd beater, I'll revert the 414M WE back to stock, for shelf-queening
Old 07-02-2015, 03:00 PM   #3487
SagadSetup's Avatar
Ayt!
Old 07-02-2015, 11:37 PM   #3488
Did more searching within this thread. Some say that TA04, TB Evo3, 416, 418, 419 steering racks fit. So that's promising.
Wondering if this might fit. Seems like the same fore-aft arm design like the 414M (ie: no 90º arm on the right side for servo); but with longer and curved extensions.
http://www.ebay.com/itm/251468195994...AIT&rmvSB=true
Old 07-08-2015, 12:19 PM   #3489
Will either the TA05 (53877) or TB04/TB-Evo6 (54592) direct-coupling spools fit in the Rear of a 414M?? (for drift purposes) ...They appear to have different widths, but irdk.
ps: I’ve already found which WA steering-rack/set fits (probably the hardest part figuring out). I also know that 42mm (someone says 44mm fits too) WA axles/shafts fit (obviously). I’ll most likely just use the stock c-hubs (modified) and stock knuckles (I’m on budget and not looking to spend a lot). Going to use the stock arms too.
So everything is pretty much sorted (just need to find out which spools will fit the rear).
Old 07-08-2015, 12:34 PM   #3490
SagadSetup's Avatar
If they are different widths. it will not fit.
Why don't you just lock your rear? Saves you money too.
http://www.melbrc.org/vB/showthread.php?t=4530
I also did research, the TA04 one way diff will fit your 414M
http://www.amazon.com/Tamiya-53411-T.../dp/B00061HCT0
Old 07-08-2015, 12:47 PM   #3491
SagadSetup's Avatar
As for WA cvds, I also wouldn't try 44mm. That 2mm difference is a lot!
Here's one.
http://www.ebay.com/itm/Tamiya-TA05V...item3a6bff073f
Old 07-08-2015, 01:32 PM   #3492
Here's one.
That exact listing is on my watchlist
Old 07-08-2015, 01:34 PM   #3493
Ah I see. So both won't fit the rear, or just one of the ones I listed??
I'd rather have a nice solid aluminum Rear spool, than a ghetto diy tape/card-stock kinda thing. But I guess I'll cut up some card-stock for the mean time.
As for the front one-way...the 414M already comes with one stock
Old 07-08-2015, 01:35 PM   #3494
SagadSetup's Avatar
It's on my watchlist too. I plan to use it on my XV01
Old 07-08-2015, 01:39 PM   #3495
SagadSetup's Avatar
Here's another
http://www.rcmart.com/3racing-sakd33...Path=1102_1106
Cheaper than the one on Ebay.
414x x414x R/C Items: Wanted to Buy 3 06-30-2010 12:17 PM
looking for a tamiya 414x subaru73 R/C Items: Wanted to Buy 0 06-07-2006 09:50 PM
Tamiya 414x meche R/C Items: For Sale/Trade 2 09-12-2004 07:25 PM
Tamiya 414X icon R/C Items: Wanted to Buy 6 10-02-2002 08:58 PM
Looking for a 414x,414m,or TB Evo grinch77 R/C Items: Wanted to Buy 0 07-24-2002 06:22 PM
