Like Tree4Likes
Old 09-19-2014, 08:45 AM   #3436
gtrmx's Avatar
Originally Posted by Juan Aveytia View Post
42mm
Thank you Juan!!!
gtrmx is offline   Reply With Quote
Old 09-19-2014, 09:36 PM   #3437
Originally Posted by gtrmx View Post
Thank you Juan!!!
Thats for the original 414 suspension. If you've switched to Tamiya's other suspensions use 44mm
Juan Aveytia is offline   Reply With Quote
Old 10-12-2014, 09:46 PM   #3438
Looking to get a gear diff, but I'm having difficulty locating the part numbers. I need the gear diff and the outdrives.
Rugrat is offline   Reply With Quote
Old 01-27-2015, 06:38 AM   #3439
EDWARD2003's Avatar
Will TA05 V2 sway bars work on the 414M?
EDWARD2003 is offline   Reply With Quote
Old 01-27-2015, 08:11 AM   #3440
I can't remember the sway bar kit part number. But it's an all black away bar kit. I think for the 417.
Old 01-28-2015, 10:45 PM   #3441
EDWARD2003's Avatar
Thanks Juan. I would like to stick with the same sway-bars that the 414M came with. When I say this, I don't necessarily need to have 414M specific, but rather the same dimensions but from another kit. I don't know if running reversible light weight suspension makes a difference.
Old 01-28-2015, 11:15 PM   #3442
I like the newer style sway bars sets over the original sway bars for this car because there is no thick powder coating. No other kit will have the same dimensions. You just make things work. I also use Evo4 sway bar holders for this car.
Old 01-28-2015, 11:31 PM   #3443
EDWARD2003's Avatar
I also use the EVO 4 sway bar holders as well, you told me too
So, you mentioned the newer sway-bar set. Is this the 417 sway bar set Tamiya (#84208) your talking about?
I think I found some for TA-05 and 417 kits available. The only difference between the two is one is covered in a coating and the other is not.
Old 01-29-2015, 03:34 AM   #3444
Yes that's the item number.
Old 04-13-2015, 09:08 PM   #3445
byteme909's Avatar
Just bought a BNIB TRF414 (not 414m) to build and considering to make it a runner. What parts should I change to bring it up to date? I.E. suspension, drivetrain etc. I read some of the older posts but not sure if anyone is still working on this very classic chassis.
byteme909 is offline   Reply With Quote
Old 04-13-2015, 09:28 PM   #3446
Why would you want to risk damaging an old and beautiful new car?
12th Scale - The premier class (if you can make runtime)
Besercoe is offline   Reply With Quote
Old 04-13-2015, 09:55 PM   #3447
EDWARD2003's Avatar
https://www.facebook.com/photo.php?f...type=1&theater
Still going strong
Check out my YouTube channel for 1/12th scale and 1/10th Touring maintenance tips!
YouTube Search https://www.youtube.com/c/EdwardPickering?gvnc=1
                 VBC 12M - D08 - FX
Old 04-14-2015, 08:03 AM   #3448
byteme909's Avatar
It's because I have 2 NIB of this car. I originally bought one last fall to build as a shelf queen and I acquired a second just 2 days ago. Trying to figure out what to do with the second one.
Old 05-04-2015, 09:21 PM   #3449
rough512's Avatar
Hi, were you able to make any progress? I also have a TRF414, it's been raced before by the previous owner but not a lot by me. I had just recently returned to the hobby and looking at restoring the old car.
rough512 is offline   Reply With Quote
Old 05-04-2015, 10:03 PM   #3450
byteme909's Avatar
It's been a slow progression. I have some option parts and spares piled up on the side. I purchased the 414M2 WCR front stabilizer set as the front stock bulkheads does not have any mounting holes for the sway bars. I also have some MIP CVDs that will fit the car. I was lucky to find a NIP Cross Racing aluminum rear hub carrier. Lastly I bought some titanium screws for the build.
The trouble is getting replacement parts for the drivetrain. You can fit the 414M/TA04 stuff in there such as the diff, but once you do you have to convert the drive shafts over as the size of the bones are different. Also I have been unable to find a rear replacement belt that will fit the car.
414x x414x R/C Items: Wanted to Buy 3 06-30-2010 12:17 PM
looking for a tamiya 414x subaru73 R/C Items: Wanted to Buy 0 06-07-2006 09:50 PM
Tamiya 414x meche R/C Items: For Sale/Trade 2 09-12-2004 07:25 PM
Tamiya 414X icon R/C Items: Wanted to Buy 6 10-02-2002 08:58 PM
Looking for a 414x,414m,or TB Evo grinch77 R/C Items: Wanted to Buy 0 07-24-2002 06:22 PM
