Old 09-07-2014, 06:20 AM   #3421
EDWARD2003's Avatar
Motor plate
EDWARD2003 is offline   Reply With Quote
Old 09-07-2014, 06:22 AM   #3422
EDWARD2003's Avatar
Overhead view of the slightly modified pulleys
Old 09-07-2014, 08:38 AM   #3423
Nice, but your camber links should be raised up to the top hole. Add at least 2mm spacers under the blocks. If you can get a set of evo4 sway bar holders. That will get the sway bars to the correct height. Looking good
Juan Aveytia is offline   Reply With Quote
Old 09-14-2014, 12:29 PM   #3424
I need (2) (15t) center pulleys for this car. Anyone have any they're willing to sale?
Old 09-14-2014, 11:34 PM   #3425
CL
CL's Avatar
Trader Rating: 32 (100%+)
What is the diameter of the top shaft? If the diameter is 4mm, you can use the pulley from 3Racing.
http://www.tqrcracing.com/shop/produ....asp?p_id=6083
Believe in yourself!
CL is offline   Reply With Quote
Old 09-15-2014, 04:42 AM   #3426
EDWARD2003's Avatar
What are you guys using for suspension blocks? After my suspension arm conversion, I now only have 1.5 degrees of rear toe.
What's the hot ticket for front and rear suspension blocks?
Old 09-15-2014, 06:19 AM   #3427
I don't know if its the hot ticket. But I go back and forth between 1B-1B and 1C-1C in the front. And 1XA-1D or 1E
Old 09-15-2014, 06:19 AM   #3428
Those would work. But are never in stock
Old 09-15-2014, 09:58 AM   #3429
CL
CL's Avatar
You can get them from ebay:
http://www.ebay.com/itm/3Racing-Alum...item58a7ea9413
Old 09-15-2014, 04:13 PM   #3430
Old 09-16-2014, 06:18 PM   #3431
EDWARD2003's Avatar
Battery options, so I'm deciding on whether to get a shorty, block, or saddle pack. Which one would be the best choice?
As for making a custom chassis, there's a company called Fiberlyte based in the U.K. They already have the lower chassis mocked up already. I might email them and ask them to eliminate the cell holes and narrow the chassis along it's outer edges.
Old 09-16-2014, 08:34 PM   #3432
EDWARD2003's Avatar
http://www.fibre-lyte.co.uk/fl/cars/tamiya/414ssd.html
So here's the link to the 414M chassis. Now, there are 2 other variants of the chassis. I think this one would do. I'm thinking of asking them to use this layout, but eliminate the battery cutouts and leave the battery loop holes. remove the outer servo hole. Those two unwanted holes on the left hand side.
Narrow the existing width by ?? mm.
Cutouts underneath the pulleys.
Additional holes for optional steering crank system.
Lipo stops?
Old 09-17-2014, 12:16 AM   #3433
Lipo stops?
The rear area where the front suspension blocks are. Needs to be wider for split blocks. And maybe they can redesign the front of the chassis to use the 418 style plastic bumper and push the steering holes back a bit to support 418 style steering rack. And (2) holes for a floating servo mount. Shock towers should be redesigned. 3mm thick, lowered where shorter shocks can fit and camber holes installed. And rear shock tower body post moved to the outside
Old 09-18-2014, 12:36 PM   #3434
gtrmx's Avatar
Default TRF414MII swing shaft length
Does anybody know then length of the swing shafts for the TRF414MII??
39mm??
42mm??
I lost one and it is the only part I am missing to complete this car...
Thanks!!
gtrmx is offline   Reply With Quote
Old 09-19-2014, 05:37 AM   #3435
39mm??
42mm??
Thanks!!
42mm
414x x414x R/C Items: Wanted to Buy 3 06-30-2010 12:17 PM
looking for a tamiya 414x subaru73 R/C Items: Wanted to Buy 0 06-07-2006 09:50 PM
Tamiya 414x meche R/C Items: For Sale/Trade 2 09-12-2004 07:25 PM
Tamiya 414X icon R/C Items: Wanted to Buy 6 10-02-2002 08:58 PM
Looking for a 414x,414m,or TB Evo grinch77 R/C Items: Wanted to Buy 0 07-24-2002 06:22 PM
SEO by vBSEO 3.5.0
