Old 11-23-2008, 10:06 AM   #3271
GCT69's Avatar
Originally Posted by Turbonium View Post
yea, i dunno... you are on foam, right? not my thing, but if you post your general setup ill try to give you an idea.
front:
white short springs
2nd hole (shock mount)
4 mm spacer on front suspension shaft
2mm spacer on tie rod (from c hub to front bulk head)
rear:
blue springs
3rd hole on shock mount
4mm spacer on rear susp. shaft
2mm spacer under front susp. block, 1mm under rear susp. blk.
17.5 bl with 2400 mah lipo.
will take pics of my current set up.
GCT69 is offline   Reply With Quote
Old 11-23-2008, 05:43 PM   #3272
Turbonium's Avatar
Trader Rating: 27 (100%+)
Send a message via Yahoo to Turbonium
like mentioned, i dont run much foam ever, but from what i do know, you will probably need a much stiffer spring that Tamiya will offer. i would look for some Associated springs, they will fit on your TRF shocks fine. dont remember the actual color springs, but look in the area of 27 lb front, 20 rear. oil, try 70-f, 40-r.
and seems lke the few foam setups i have seen were using some swaybars, as well...
thats probably where i would start... your results might vary, lol.
Wes
Team Novak
Turbonium is offline   Reply With Quote
Old 11-24-2008, 12:14 PM   #3273
TRF415boy's Avatar
look for tamiya grey and silver springs...
TRF415boy is offline   Reply With Quote
Old 11-24-2008, 12:17 PM   #3274
Trader Rating: 112 (100%+)
Originally Posted by GCT69 View Post
front:
white short springs
rear:
blue springs
What kind of run time do you get with this combo(17.5/2400lipo)?
Dave
dragracer72nova is offline   Reply With Quote
Old 11-24-2008, 06:02 PM   #3275
GCT69's Avatar
Dave
around 7mins or more but less than ten.
gearing is 100/52
Old 11-24-2008, 06:03 PM   #3276
GCT69's Avatar
i'll try purple and gray.
Old 11-25-2008, 02:06 AM   #3277
TRF415boy's Avatar
oops my bad what was I thinking when I wrote that, yeah purple and grey...
Old 11-29-2008, 02:13 PM   #3278
Anyone in this thread with 414/414x (not 414m and above) rear bulkheads they'd be willing to part with?$?
x414x is offline   Reply With Quote
Old 11-30-2008, 07:59 AM   #3279
After seiing this thread i really should drag my 414 out of the loft and work on it again, must be two years ago since i last used the car and fitted EVO III suspension blocks.
weekendracer_uk is offline   Reply With Quote
Old 11-30-2008, 12:18 PM   #3280
GCT69's Avatar
I have been using it since carpet season started, all I can say is that I like it alot. I've got it set up to where I can drive it. Only draw back is parts are getting harder to find.
Old 12-01-2008, 08:28 AM   #3281
Does anyone on this forum have a 414 they want to sell? I want to try one of these out for a project I have. (preferably in the UK)
http://www.theRcRacer.com/
TRF419, TBEvo6, TT02, VDF, TRF501x, TRF201, TRF101, Mi5, X-Ray T4-13, BD7 2014, A700 Evo, WR-02G
Qatmix is offline   Reply With Quote
Old 12-01-2008, 01:57 PM   #3282
GCT69's Avatar
will the rversible arm fit the 414? any mods needed?
Old 12-01-2008, 02:03 PM   #3283
Yes they do. I have to clean my car from racing this past week, but I get some pics of my 414Hybrid. You will have to go with longer CV axle shafts. My car has a 414 chassis, bulkheads, steering rack, with 415 Lite weight suspension and 416 front & rear shock towers and finish it off with 416 front hubs.
Dave
I will post some pics when I get the car clean
Old 12-01-2008, 02:07 PM   #3284
GCT69's Avatar
Dave
and if you don't mind I would need details (parts wise) and does it handles better. That would be my next project.
tnx
Old 12-01-2008, 02:26 PM   #3285
Na, but here's some inspiration
414x x414x R/C Items: Wanted to Buy 3 06-30-2010 11:17 AM
looking for a tamiya 414x subaru73 R/C Items: Wanted to Buy 0 06-07-2006 08:50 PM
Tamiya 414x meche R/C Items: For Sale/Trade 2 09-12-2004 06:25 PM
Tamiya 414X icon R/C Items: Wanted to Buy 6 10-02-2002 07:58 PM
Looking for a 414x,414m,or TB Evo grinch77 R/C Items: Wanted to Buy 0 07-24-2002 05:22 PM
