Old 09-25-2004, 02:33 AM   #3121
Ok i have a 415 low friction rear belt , just ordered a front TAO4 low friction belt , diff halves will wait until i put an order in at R10 for some EVO IV parts as they cost far too much here in England.
Just got to start rebuilding it once the front belt turns up next week , anybody got a good base setup for running rubber slick tyres indoors on carpet as i have no idea.
May try making the wheelbase as short as possiable in order to cope with the tighter nature of indoor tracks after only racing outdoors on large tracks to date.
Xray X1 "16" driven by an idiot, me
weekendracer_uk is offline   Reply With Quote
Old 10-14-2004, 08:54 AM   #3122
ok guys....in your opinions do you think the 414 is still competitive today???.....what are your pro's and con's about the car.....
DirtyRacer is offline   Reply With Quote
Old 10-14-2004, 09:42 AM   #3123
Default 414M2
Hey,
I asked this question a few days ago. The response was the link to this current posting.
I've scanned thru the first third of the pages but nothing with any real meat. Those pages talk mainly about the original 414, and 414M.
Is there anyone out there that can give a good opinion about this car in contrast to any of today's current rides?
I wanted to get into this for carpet racing, but I think the chassis is really flexible compared to other cars out there. I assume it's 2-2.5mm???)
Does anyone know if this car can perform well on the rug?
Thanks!
Electro-MAX RC is offline   Reply With Quote
Old 10-14-2004, 10:24 AM   #3124
Send a message via ICQ to Cobra81li200
Default Re: 414M2
Originally posted by Electro-MAX RC
Hey,
Thanks!
A well prepared 414M/M2 can be just as competitive than any other touring car, specially on carpet where the drivetrain efficiency is not that important (it's not as good as a FK, but still it's quite good).
s for setup on carpet, I'd say start from the basic setup but using harder springs (white front and blue rear), use the two blue ARB aswell.
Cobra81li200 is offline   Reply With Quote
Old 10-14-2004, 10:53 AM   #3125
Cobra,
Thanks for the response, I've got an EVO2 w/c-hubs and low ratio pulleys. I race mainly 27T stock. I was just curious about the 414m2 b/c I can get my hands on a brandnew one is for a very reasonable price.
Just curious why you feel that drive-train effeciency isn't really important on carpet? Compared to your FK is the 414m2 a step down? Also how about chassis flex? Does the 414 soak up too much speed around the turns?
Sorry what are ARBs again?
Old 10-14-2004, 05:01 PM   #3126
I run the 414 on carpet....Its more consistant (and a bit quicker) my old TC3 or my Evo3
ARBs = Anti Roll Bars
IMHO: Its just a Tamiya T1FK w/o the low ratio pulleys
The Black Kat is offline   Reply With Quote
Old 10-15-2004, 09:03 AM   #3127
Talking
what are the pro's and con's of the 414 on asphalt?
can someone post setups for carpet & asphalt?
Old 10-15-2004, 09:15 AM   #3128
rough512's Avatar
What's a Tamiya T1FK ?
rough512 is offline   Reply With Quote
Old 10-15-2004, 01:02 PM   #3129
Cobra,
I don't own an X-Ray...
I say that there are less problems with duration and top speed on carpet because the tracks are much tinier than on asphalt tracks. On a long asphalt track, the 414 struggles a bit with duration and top speed (it is not THAT bad but it's not as good as the latest cars like the Ti FK or the 415).
The 414 is a car that have a lot of steering, especially off power, which is why I recommend you the white springs on front and the blue rll bar aswell. However, if properly setup, it will keep very good corner speed, it's still one of my favourite cars to drive.
Old 10-15-2004, 01:03 PM   #3130
On asphalt the 414 lacks a bit of top speed (you need to work a lot on the drivetrain to free it up). Handling wise, it's still very good.
Old 10-15-2004, 02:18 PM   #3131
so what do you recommend on how to free up the drivetrain???
Old 10-15-2004, 04:55 PM   #3132
Originally posted by rough512
What's a Tamiya T1 ?
Tamiya's version of the XRay T1 - TRF 414
Old 10-17-2004, 02:02 AM   #3133
Does anybody have a carpet setup for 414m with rubber tires. I will be racing in stockton Ca. and in the stock class
ptjonesus is offline   Reply With Quote
Old 10-17-2004, 11:41 AM   #3134
I run at Hobbyworld Gilroy (hundred + miles south of Stockton I belive)
My Setup:
Front/Rear
Tires: CS27 - CS 22
Springs: Yellow - Yellow
Shock Oil: Either AE 40wt or AE 60wt
Shock Position (Upper): Middle - Middle
Shock Position (Lower): Outer - Outer
ARB's: Yellow - Red
Camber: 1.5 - 1.5
Toe-In: 1 - 2
Ride Height: 5mm - 5mm
Wheel Base (Wheelnut to Wheelnut) 263 mm
No added Kick-Up/Caster
Camber Link Spacers: 2mm - 2mm
Secondary Front Camber Links Installed - Yes
Front/Center One-Ways - Yes
Jack The Gripper every few runs (only legal TC at Gilroy)
I use a different method of setting my droop but if you want me to measure using the AE style guages for you I can
Comments: This car is DIALED in the mornings/nights at Gilroy & would probably be even better on a better track (Stockton)
If it gets tail happy I'd say add 1/2 degree of Toe-in.
If you want to run outdoor. Put a set of CS-27's on the rear, Drop to a red sway bar up front and loose the secondary upper camber links
Old 10-18-2004, 12:27 AM   #3135
so now that I have the car what spare parts do I need for the 414m and who sell parts for this car
414x x414x R/C Items: Wanted to Buy 3 06-30-2010 12:17 PM
looking for a tamiya 414x subaru73 R/C Items: Wanted to Buy 0 06-07-2006 09:50 PM
Tamiya 414x meche R/C Items: For Sale/Trade 2 09-12-2004 07:25 PM
Tamiya 414X icon R/C Items: Wanted to Buy 6 10-02-2002 08:58 PM
Looking for a 414x,414m,or TB Evo grinch77 R/C Items: Wanted to Buy 0 07-24-2002 06:22 PM
SEO by vBSEO 3.5.0
