Old 05-25-2004, 03:08 PM   #3091
FUK_WRX's Avatar
Send a message via ICQ to FUK_WRX Send a message via AIM to FUK_WRX Send a message via MSN to FUK_WRX Send a message via Yahoo to FUK_WRX
Originally posted by Cobra81li200
put them in boiling water for some time.
Agree.............. had to do this when i got my new racy bulkheads. Had to boil some water and placed the alum bulkheads in them.
But i recommend just changing bearings.
FUK_WRX is offline   Reply With Quote
Old 05-25-2004, 04:12 PM   #3092
Registered User
Calvin Ng's Avatar
Send a message via ICQ to Calvin Ng
Originally posted by WC
1150 = 11mm outer, 5mm inner and 4mm wide.
You mounties hibernate for winter??
Bearings are all 1150 (axles)- 11mm outer, 5mm inner, 4mm wide
1510 (bulkhead diffs)- 15mm outer, 1mm inner???, 4mm wide
the second one sounds wrong 1 mm? or is it right
Calvin Ng is offline   Reply With Quote
Old 05-25-2004, 04:25 PM   #3093
Turbonium's Avatar
Trader Rating: 27 (100%+)
Send a message via Yahoo to Turbonium
diff bearings are going to be 15 x 10 id...
Wes
Team Novak
Turbonium is offline   Reply With Quote
Old 05-25-2004, 06:00 PM   #3094
Registered User
Calvin Ng's Avatar
ok thanx!!!
so all 4mm wide
Old 05-26-2004, 09:19 AM   #3095
Baluga's Avatar
For how long? Assuming I only want to change the bearing for the pulleys on the rear bulkheads, will boiling it affect the diff bearings?
Baluga is offline   Reply With Quote
Old 05-26-2004, 09:22 AM   #3096
Baluga's Avatar
Default 415
Is it possible to install a 415 front and rear damper stay on a 414M kit?
Old 05-26-2004, 09:37 AM   #3097
John Doucakis's Avatar
The rear shock tower is too wide at the point where it is screwed on the rear bulkhead. The 414 has a narrower rear end.
I have not tried the front.
John Doucakis is offline   Reply With Quote
Old 05-26-2004, 12:04 PM   #3098
Baluga's Avatar
Too bad... It would be nice to have a different looking 414.
Old 05-26-2004, 03:18 PM   #3099
FUK_WRX's Avatar
Boil some water and let it cool down for about 1min. Drop the bulk heads in, by doing this the alloy stretches temporarily therefore loosen its grip on the bearing.
Preety much the same technique used one removing bearing on a real car block. Hope this helps.
Luie
Old 05-26-2004, 03:44 PM   #3100
Send a message via ICQ to Cobra81li200
Luie
Actually not
The bearings are glued to the bulkheads they're not kept in place by constraint, so you need to break the glue, and how do you do that ? You put the part in BOILING (I insist on that) water for like 10 minutes and then you need to hit the bearings. They won't come easily either.
When you put them back in, don't glue them it's not really useful.
Cobra81li200 is offline   Reply With Quote
Old 05-29-2004, 09:00 AM   #3101
Ok I just bought a 414m2 and need to know something. Are the TA04 belts the same?
stumper is offline   Reply With Quote
Old 05-29-2004, 09:10 AM   #3102
Baluga's Avatar
The front low friction belts can be used for the 414M. I'm not sure on the TA04 rear belts.
Old 05-29-2004, 12:38 PM   #3103
you can use the 415 rear belt, but not the front. TA04 belts are the same as on the 414M.
Old 05-29-2004, 02:49 PM   #3104
Where can I get Hop Ups for my TRF 414M2?
kabam is offline   Reply With Quote
Old 06-01-2004, 10:03 AM   #3105
speedtechrc.com
414x x414x R/C Items: Wanted to Buy 3 06-30-2010 12:17 PM
looking for a tamiya 414x subaru73 R/C Items: Wanted to Buy 0 06-07-2006 09:50 PM
Tamiya 414x meche R/C Items: For Sale/Trade 2 09-12-2004 07:25 PM
Tamiya 414X icon R/C Items: Wanted to Buy 6 10-02-2002 08:58 PM
Looking for a 414x,414m,or TB Evo grinch77 R/C Items: Wanted to Buy 0 07-24-2002 06:22 PM
