Old 04-03-2004, 12:37 AM   #3061
FUK_WRX's Avatar
Send a message via ICQ to FUK_WRX Send a message via AIM to FUK_WRX Send a message via MSN to FUK_WRX Send a message via Yahoo to FUK_WRX
Default Swap Racy nylon bulkheads for Tamiya Lite weigh bulkheads
Hey guys i want to swap my racy bulkheads for those lite weight tamiya bulkheads and motor mount. I have used these Bulkheads for two meetings only and are in excellent condition.
Please PM or email me for more detaisl.
FUK_WRX is offline   Reply With Quote
Old 04-08-2004, 11:18 AM   #3062
Default TRF414MII Gearing
My first post on this site-hope you can help me out:
Any idea what gearing/rollout I should be running on a TRF414M2
with a Monster stock motor.? Track is a mixture of tight turns and
1 medium straight. I'm just trying to get in the ballpark and any help would be appreciated!
Speedracer911 is offline   Reply With Quote
Old 04-12-2004, 08:43 AM   #3063
TVree's Avatar
Default Gearing
Hi Speedracer--
I would start with (48 pitch) 90/25, which with the internal ratio of 2.13 yields a 7.668. The Monster stock has such high RPM that it should be ok, at least for a starting point. I'm running on asphalt, btw. Most recently, I've been using a P2K and going about 3 pinion teeth higher, even on higher speed tracks. Most racers are running the Monsters, and usually at 7.0 or above.
Terry V.
TVree is offline   Reply With Quote
Old 04-12-2004, 10:46 AM   #3064
Terry, thanks for the info! I'm running 7.74 overall ratio right now (120/33). Maybe a little high, but I wanted to error on the safe side to start out. Tamiya recommended I gear the car between 6.5 and 7.0 with a Monster Stock, but I was cooking the motor...
Thanks again for the help!
Old 05-17-2004, 07:13 PM   #3065
WC
WC's Avatar
Trader Rating: 28 (100%+)
Default 414M/M2 CHASSIS PLATE DIFFERENCES - picky picky details
Hoping some of you diehard Tamiya-philes can answer this...
How many *different* chassis bottom plates did Tamiya make for 414M/M2??
414M black CF
414M2 black CF
414M2 SSG (exactly same as black CF in design?)
414M-WCR... is this chassis plate same as 414M's black CF?
www.PandaGFX.com
www.MelbRC.org
WC is offline   Reply With Quote
Old 05-17-2004, 07:17 PM   #3066
Registered User
Calvin Ng's Avatar
Send a message via ICQ to Calvin Ng
no its a bit bit diffrent
the 414m2 can hold stick packs... while the wrc one cant
so the wrc doesnt have that little bit on the battery slot holes
Calvin Ng is offline   Reply With Quote
Old 05-17-2004, 08:10 PM   #3067
I also believe the cells are closer together on the SSG version than the std.
12th Scale - The premier class (if you can make runtime)
Besercoe is offline   Reply With Quote
Old 05-17-2004, 08:10 PM   #3068
Registered User
Calvin Ng's Avatar
ssg the cells are closer to the center
Old 05-18-2004, 12:49 AM   #3069
WC
WC's Avatar
hmm, that is what I had suspected.
So the WCR's chassis is same as original 414M's ??
I'll be looking for a new chassis plate for a WCR eventually, and
trying to work out what is the exact replacement.
Already got the 414M2 & the SSG but someone said those aren't
exactly the same as WCR.
www.PandaGFX.com
www.MelbRC.org
Old 05-18-2004, 03:28 PM   #3070
Registered User
Calvin Ng's Avatar
the diffrence between the 414mII and WRC
is that the 414mII has that extra peice for stick packs.
if you cut them off.... you have a wrc one
Old 05-21-2004, 07:11 PM   #3071
Registered User
Calvin Ng's Avatar
heyy???
umm....
i'm wondering if teh suspension blocks for the 415 fit the 414??
also... the 415 has 4 diffrent suspension blocks
A,B,C,X
are there ones taht dont fit
Old 05-21-2004, 11:23 PM   #3072
AsiaTees's Avatar
Hello,
Anyone knows whether the C-Hubs, Front/Rear knuckles for the TA04 are usuable for TRF414?
Regards,
Jason
www.Asiatees.com
www.AsiaTees.com
Your #1 GPM Racing Store
AsiaTees is offline   Reply With Quote
Old 05-22-2004, 01:10 AM   #3073
Send a message via ICQ to Cobra81li200
Originally posted by AsiaTees
Hello,
Regards,
Jason
www.Asiatees.com
Sure, the suspension is exactly the same.
Cobra81li200 is offline   Reply With Quote
Old 05-23-2004, 07:05 AM   #3074
Super Steve's Avatar
Send a message via AIM to Super Steve
Hey guys,
My friend got a TRF414MII from ebay.
What pinion gear issuitable for healthy gearing with 120 spur and monster stock.
Super Steve is offline   Reply With Quote
Old 05-23-2004, 07:54 PM   #3075
Does anyone have a picture of Jimmy Jacobson's car with the blue,yellow.and white body. Thanks
Nevada is offline   Reply With Quote
414x x414x R/C Items: Wanted to Buy 3 06-30-2010 11:17 AM
looking for a tamiya 414x subaru73 R/C Items: Wanted to Buy 0 06-07-2006 08:50 PM
Tamiya 414x meche R/C Items: For Sale/Trade 2 09-12-2004 06:25 PM
Tamiya 414X icon R/C Items: Wanted to Buy 6 10-02-2002 07:58 PM
Looking for a 414x,414m,or TB Evo grinch77 R/C Items: Wanted to Buy 0 07-24-2002 05:22 PM
